<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GoogleMapsTraffic: &quot;For Development purposes only&quot;]]></title><description><![CDATA[<p dir="auto">Hello, everyone,</p>
<p dir="auto">I inserted the GoogleMaps map, it works too. A valid API is used for all functions as well as a billing account.<br />
The map is displayed normally at first, followed by an error message that the page could not be loaded correctly. I can confirm this but still have the message in the card that turns slightly greyish “For Development purposes only”<br />
What is wrong? My Config is:</p>
<pre><code>{
			module: 'MMM-GoogleMapsTraffic',
			position: 'bottom_right',
				apiKey: 'My Key' ,
				lat: 49.56324,
				lng: 11.34776,
				styleMapType: "dark",
				disableDefaultUI: true,
				backgroundColor: "rgba(0, 0, 0, 0)",
				updateInterval: 15000,
				height: '450px',
				width: '450px'
<p dir="auto">Thanks for help.</p>
<p dir="auto">Best regards</p>
<p dir="auto">Fufu1408</p>
]]></description><link>https://forum.magicmirror.builders/topic/15790/mmm-googlemapstraffic-for-development-purposes-only</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:46:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15790.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Oct 2021 11:46:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic: &quot;For Development purposes only&quot; on Mon, 25 Oct 2021 19:11:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fufu1408" aria-label="Profile: fufu1408">@<bdi>fufu1408</bdi></a> yep, one little typo will do that to you…</p>
<p dir="auto">I tested and see the same results, used the dev window and see the error,<br />
checked the module and sure enough…</p>
<p dir="auto">i’ll give u a hint…  what is the spelling of the apikey parameter?</p>
]]></description><link>https://forum.magicmirror.builders/post/95781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95781</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Oct 2021 19:11:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic: &quot;For Development purposes only&quot; on Fri, 05 Nov 2021 23:37:03 GMT]]></title><description><![CDATA[<p dir="auto">it’s key:<br />
not apikey:</p>
]]></description><link>https://forum.magicmirror.builders/post/96060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96060</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Nov 2021 23:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic: &quot;For Development purposes only&quot; on Mon, 25 Oct 2021 19:11:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fufu1408" aria-label="Profile: fufu1408">@<bdi>fufu1408</bdi></a> yep, one little typo will do that to you…</p>
]]></description><link>https://forum.magicmirror.builders/post/95781</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95781</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Oct 2021 19:11:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic: &quot;For Development purposes only&quot; on Mon, 25 Oct 2021 12:48:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i change the updating thanks. but same problem with the development purposes only</p>
]]></description><link>https://forum.magicmirror.builders/post/95764</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95764</guid><dc:creator><![CDATA[Fufu1408]]></dc:creator><pubDate>Mon, 25 Oct 2021 12:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleMapsTraffic: &quot;For Development purposes only&quot; on Mon, 25 Oct 2021 12:29:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fufu1408" aria-label="Profile: fufu1408">@<bdi>fufu1408</bdi></a> u are updating every 15 seconds? 15000 milliseconds…</p>
<p dir="auto">I would say a MINIMUM of 5 minutes</p>
<p dir="auto">5 * 60 * 1000</p>
<p dir="auto">but 10 or 15 mins might be better</p>
]]></description><link>https://forum.magicmirror.builders/post/95763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/95763</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Oct 2021 12:29:51 GMT</pubDate></item></channel></rss>
