<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Does anyone know how to make the iFrame module refresh periodically?]]></title><description><![CDATA[<p dir="auto">I have a google spreadsheet displayed, but the problem is it only refresh the content when I restart Magic Mirror.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1583/does-anyone-know-how-to-make-the-iframe-module-refresh-periodically</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 07:21:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1583.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Jan 2017 00:08:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Tue, 31 Jan 2017 13:46:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cnelso24" aria-label="Profile: cnelso24">@<bdi>cnelso24</bdi></a></p>
<p dir="auto">I have found a fix for this module which I posted here:</p>
<p dir="auto"><a href="https://github.com/TheBogueRat/MMM-iFrameReload/issues/2" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/TheBogueRat/MMM-iFrameReload/issues/2</a></p>
<p dir="auto">Kev</p>
]]></description><link>https://forum.magicmirror.builders/post/13151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13151</guid><dc:creator><![CDATA[kevsfastz]]></dc:creator><pubDate>Tue, 31 Jan 2017 13:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Fri, 03 Mar 2017 17:14:48 GMT]]></title><description><![CDATA[<p dir="auto">created new thread because this one is solved with the original issue</p>
]]></description><link>https://forum.magicmirror.builders/post/16383</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16383</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Fri, 03 Mar 2017 17:14:48 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Wed, 15 Feb 2017 19:25:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevsfastz" aria-label="Profile: kevsfastz">@<bdi>kevsfastz</bdi></a><br />
Above is a sample of the code(the weird forum framework removed the headd of the html )<br />
Yes it is working very fine in the web browser</p>
<p dir="auto">Does this help you?</p>
<p dir="auto">Thank you in advance !</p>
]]></description><link>https://forum.magicmirror.builders/post/14603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14603</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Wed, 15 Feb 2017 19:25:11 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Wed, 15 Feb 2017 07:16:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a></p>
<p dir="auto">Can you show a sample of your code? I assume the URL is working fine in a web browser?</p>
]]></description><link>https://forum.magicmirror.builders/post/14591</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14591</guid><dc:creator><![CDATA[kevsfastz]]></dc:creator><pubDate>Wed, 15 Feb 2017 07:16:47 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Wed, 15 Feb 2017 07:11:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevsfastz" aria-label="Profile: kevsfastz">@<bdi>kevsfastz</bdi></a> said in <a href="/post/14589">Does anyone know how to make the iFrame module refresh periodically?</a>:</p>
<p dir="auto">This depends on the output of your other Pi. If you already have this output displayed in say HTML format ( I assume that’s what you mean when you say simple homepage?)  you can easily place this in iFrame via local URL.  The best way would be to create its own page so you can control the output, then you can use CSS styles to adjust colors, size, placement etc.</p>
<p dir="auto">Thank you for your answer. I tried of course, but I got only a white line on the screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/14590</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14590</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Wed, 15 Feb 2017 07:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Wed, 15 Feb 2017 06:58:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/14589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14589</guid><dc:creator><![CDATA[kevsfastz]]></dc:creator><pubDate>Wed, 15 Feb 2017 06:58:42 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 13 Feb 2017 18:52:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevsfastz" aria-label="Profile: kevsfastz">@<bdi>kevsfastz</bdi></a> said in <a href="/post/14427">Does anyone know how to make the iFrame module refresh periodically?</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a><br />
The simple answer is yes it is possible. What is your goal specifically?</p>
<p dir="auto">I have another raspberry who gets temperatures with one-wire-sensors.<br />
This i provide in a simple homepage:</p>
<pre><code>    &lt;div&gt;
      &lt;div&gt;
    &lt;h2&gt;...&lt;/h2&gt;
	&lt;p&gt;&lt;b&gt;Temperaturen:&lt;/b&gt;&lt;/p&gt;
    &lt;p&gt;Luft:............ -3.5°&lt;/p&gt;
	&lt;p&gt;Dach:........... -2.5°&lt;/p&gt;
	&lt;p&gt;Pool: ............3.5°&lt;/p&gt;
	&lt;p&gt;&lt;b&gt;Status: &lt;/b&gt;&lt;/p&gt;
	&lt;p&gt;Pumpe:........... &lt;b&gt;Aus&lt;/b&gt;&lt;/p&gt;
    &lt;p&gt;Solarheizung:...&lt;b&gt;Aus&lt;/b&gt;&lt;/p&gt;
    &lt;br /&gt;
	&lt;p&gt;&lt;b&gt;Meta: &lt;/b&gt;&lt;/p&gt;
    &lt;p&gt;System:...........Linux 4.1.19+ armv6l&lt;/p&gt;
	&lt;p&gt;CPU Temp:....14.260°&lt;/p&gt;
	&lt;p&gt;Sensors...........3 x DS18B20 @ 5V &lt;/p&gt;
    &lt;p&gt;Last Update:......Mon 13-02-2017, 19:40:05 Uhr&lt;/p&gt;
	&lt;/div&gt;
	&lt;p&gt;....&lt;/p&gt;
    &lt;/div&gt;
<p dir="auto">how to show this, or parts of it?</p>
<p dir="auto">edit:(the html header will not be shown in this forum framework :walking:</p>
]]></description><link>https://forum.magicmirror.builders/post/14471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14471</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Mon, 13 Feb 2017 18:52:48 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 13 Feb 2017 17:42:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitch1138" aria-label="Profile: Mitch1138">@<bdi>Mitch1138</bdi></a></p>
<p dir="auto">I see what you mean with the URL, any variables you add at the end even a  ? will result in displaying all zeros on the output. You can get around this by using a site such as<a href="http://www.refreshthis.com/refreshthis.php?url=http%3A%2F%2Ftides.tidegraph.com%2Fapi%2Ftidegraph.php%3Fbg%3Dblack%26scale%3D.8%26station%3DOld%2520Frenchtown%2520Wharf%2C%2520Elk%2520River%2C%2520Maryland&amp;sec=30" target="_blank" rel="noopener noreferrer nofollow ugc">THIS</a> to refresh this URL for you instead of using iFrame to call a refresh.  Of course all these sites will have advertisments which you do not want displayed on your mirror… so what you COULD do is reposition the iframe so the advertisment is hidden in one of the top corners. For example you can add margins with negative values to the iframe style:</p>
<p dir="auto">iframe.style = “border:0;margin-bottom:-110px;margin-left:-10px;;width:500px;height:450px;filter:invert(100%);”</p>
<p dir="auto">Of course this is not the best nor the most clean solution… maybe someone else has some ideas?</p>
]]></description><link>https://forum.magicmirror.builders/post/14468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14468</guid><dc:creator><![CDATA[kevsfastz]]></dc:creator><pubDate>Mon, 13 Feb 2017 17:42:06 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 13 Feb 2017 17:11:30 GMT]]></title><description><![CDATA[<p dir="auto">My mistake, I thought this was updated in the .git.  I added the timestamp as you suggested (iframe.src =  this.config.url + new Date().getTime();).  The url does update now, but since the url displays the tides at a location embedded in the url, it looks like the timestamp is appended to the location.  With this added, it is not a valid location and the tides don’t display.</p>
<p dir="auto">Again, many thanks for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/14458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14458</guid><dc:creator><![CDATA[Mitch1138]]></dc:creator><pubDate>Mon, 13 Feb 2017 17:11:30 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 13 Feb 2017 16:20:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mitch1138" aria-label="Profile: Mitch1138">@<bdi>Mitch1138</bdi></a></p>
<p dir="auto">As mentioned above, I have provided a fix or adjustment by adjusting the MMM-IframeReload.js below:</p>
]]></description><link>https://forum.magicmirror.builders/post/14446</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14446</guid><dc:creator><![CDATA[kevsfastz]]></dc:creator><pubDate>Mon, 13 Feb 2017 16:20:30 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 13 Feb 2017 16:12:46 GMT]]></title><description><![CDATA[<p dir="auto">Many thanks, I have bee looking for a way to do this for some time.  I loaded iFrameReload with the following url.  It will load, but not update.  Any suggestions as to what I am missing?</p>
<p dir="auto">url: “<a href="http://tides.tidegraph.com/api/tidegraph.php?bg=black&amp;scale=.8&amp;station=Old" target="_blank" rel="noopener noreferrer nofollow ugc">http://tides.tidegraph.com/api/tidegraph.php?bg=black&amp;scale=.8&amp;station=Old</a> Frenchtown Wharf, Elk River, Maryland”,</p>
<p dir="auto">Many thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/14443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14443</guid><dc:creator><![CDATA[Mitch1138]]></dc:creator><pubDate>Mon, 13 Feb 2017 16:12:46 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 13 Feb 2017 10:45:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fox" aria-label="Profile: fox">@<bdi>fox</bdi></a><br />
]]></description><link>https://forum.magicmirror.builders/post/14427</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14427</guid><dc:creator><![CDATA[kevsfastz]]></dc:creator><pubDate>Mon, 13 Feb 2017 10:45:29 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Sun, 12 Feb 2017 15:11:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevsfastz" aria-label="Profile: kevsfastz">@<bdi>kevsfastz</bdi></a> is it possible to show simple html content and update periodically?</p>
]]></description><link>https://forum.magicmirror.builders/post/14342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/14342</guid><dc:creator><![CDATA[fox]]></dc:creator><pubDate>Sun, 12 Feb 2017 15:11:13 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Thu, 02 Feb 2017 01:21:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevsfastz" aria-label="Profile: kevsfastz">@<bdi>kevsfastz</bdi></a></p>
<p dir="auto">Just got a chance to try this. Works like a charm! Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/13304</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13304</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Thu, 02 Feb 2017 01:21:45 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Tue, 31 Jan 2017 15:25:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kevsfastz" aria-label="Profile: kevsfastz">@<bdi>kevsfastz</bdi></a></p>
<p dir="auto">Thank you!! I will check it out when I get home.</p>
]]></description><link>https://forum.magicmirror.builders/post/13160</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13160</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Tue, 31 Jan 2017 15:25:02 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Tue, 31 Jan 2017 13:46:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cnelso24" aria-label="Profile: cnelso24">@<bdi>cnelso24</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/13151</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13151</guid><dc:creator><![CDATA[kevsfastz]]></dc:creator><pubDate>Tue, 31 Jan 2017 13:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 30 Jan 2017 09:26:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cnelso24" aria-label="Profile: cnelso24">@<bdi>cnelso24</bdi></a> the problem is probably that there isnt a change detected when updating the dom, try to add a timestamp attribute to the iframe.</p>
]]></description><link>https://forum.magicmirror.builders/post/12986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12986</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Mon, 30 Jan 2017 09:26:25 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Mon, 30 Jan 2017 00:27:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a></p>
<p dir="auto">Thanks for the suggestion. I wouldn’t know where to start with that though. I tried <a href="https://github.com/TheBogueRat/MMM-iFrameReload" target="_blank" rel="noopener noreferrer nofollow ugc">this module</a> which did not work refresh for me either.</p>
]]></description><link>https://forum.magicmirror.builders/post/12953</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12953</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Mon, 30 Jan 2017 00:27:48 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Sun, 29 Jan 2017 21:12:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peppapigkilla" aria-label="Profile: PeppaPigKilla">@<bdi>PeppaPigKilla</bdi></a> the code that was added by you is after the return, so the code will never be reached.</p>
<p dir="auto">I suggest an interval which calls <code>updateDom</code>, which will be created after the <code>DOM_OBJECTS_CREATED</code> broadcast</p>
]]></description><link>https://forum.magicmirror.builders/post/12930</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12930</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 29 Jan 2017 21:12:35 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Sun, 29 Jan 2017 19:42:25 GMT]]></title><description><![CDATA[<p dir="auto">I tried it and cant get it to work either. best reaching out to the author,</p>
]]></description><link>https://forum.magicmirror.builders/post/12925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12925</guid><dc:creator><![CDATA[PeppaPigKilla]]></dc:creator><pubDate>Sun, 29 Jan 2017 19:42:25 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Sun, 29 Jan 2017 19:19:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peppapigkilla" aria-label="Profile: PeppaPigKilla">@<bdi>PeppaPigKilla</bdi></a><br />
Sorry the forum seems to be overloaded. I put this in my code and still no refreshing. I believe the problem is my iFrame does not have a specified name. I am only able to input the scr=“URL”. Not sure where to put iframe name = “name”. When generating an iFrame from google sheets it does not specify a name either.</p>
]]></description><link>https://forum.magicmirror.builders/post/12924</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12924</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Sun, 29 Jan 2017 19:19:12 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Sun, 29 Jan 2017 18:45:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peppapigkilla" aria-label="Profile: PeppaPigKilla">@<bdi>PeppaPigKilla</bdi></a></p>
<p dir="auto">Thank you for taking the time to help! Although, I put this into the module code and still no updates after letting it sit for 15 minutes. I also put the</p>
]]></description><link>https://forum.magicmirror.builders/post/12921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12921</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Sun, 29 Jan 2017 18:45:35 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Sun, 29 Jan 2017 11:18:30 GMT]]></title><description><![CDATA[<p dir="auto">on the config part I believe its just the URL. But on the iframe.js file, i think extra code would needed to be added.</p>
<pre><code>
/* global Module */
/* Magic Mirror
 * Module: iFrame
 * By Ben Williams http://desertblade.com
 * MIT Licensed.
Module.register("iFrame",{
		// Default module config.
		defaults: {
				height:"300px",
				width:"100%"
	// Override dom generator.
	getDom: function() {
		var iframe = document.createElement("IFRAME");
		iframe.style = "border:0"
		iframe.width = this.config.width;
		iframe.height = this.config.height;
		iframe.src =  this.config.url;
		return iframe;
    window.setInterval("reloadIFrame();", 30000);
function reloadIFrame() {
 document.frames["frameNameHere"].location.reload();
]]></description><link>https://forum.magicmirror.builders/post/12879</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12879</guid><dc:creator><![CDATA[PeppaPigKilla]]></dc:creator><pubDate>Sun, 29 Jan 2017 11:18:30 GMT</pubDate></item><item><title><![CDATA[Reply to Does anyone know how to make the iFrame module refresh periodically? on Sun, 29 Jan 2017 01:46:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peppapigkilla" aria-label="Profile: PeppaPigKilla">@<bdi>PeppaPigKilla</bdi></a></p>
<p dir="auto"><a href="https://github.com/desertblade/iFrame" target="_blank" rel="noopener noreferrer nofollow ugc">link text</a></p>
<p dir="auto">The one listed on the MagicMirror website</p>
]]></description><link>https://forum.magicmirror.builders/post/12856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/12856</guid><dc:creator><![CDATA[cnelso24]]></dc:creator><pubDate>Sun, 29 Jan 2017 01:46:20 GMT</pubDate></item></channel></rss>
