<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pls help with install]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">Just wondering if anyone has experience installing MMM-VoiceCommander? <a href="https://github.com/TheStigh/MMM-VoiceCommander" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/TheStigh/MMM-VoiceCommander</a></p>
<p dir="auto">After some searching its the perfect module for me although cant even install the damn thing…</p>
<p dir="auto">I get the following error on Linux Mint</p>
<pre><code>[STEP 1/5] Installing Packages
[sudo] password for smartmirror:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'python-dev-is-python2' instead of 'python-dev'
Package python-pip is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
python3-pip
E: Package 'python-pip' has no installation candidate
[STEP 1/5] Installing Packages | Failed
]]></description><link>https://forum.magicmirror.builders/topic/15844/pls-help-with-install</link><generator>RSS for Node</generator><lastBuildDate>Wed, 10 Jun 2026 09:27:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15844.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Nov 2021 21:06:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pls help with install on Tue, 09 Nov 2021 23:40:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alyx" aria-label="Profile: alyx">@<bdi>alyx</bdi></a> u need to change the install and usage to use python3. looks like the author has not</p>
<p dir="auto">not sure this was a ever tried on Mint</p>
<p dir="auto">generally only on pi os</p>
]]></description><link>https://forum.magicmirror.builders/post/96198</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96198</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 09 Nov 2021 23:40:12 GMT</pubDate></item></channel></rss>
