<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM install New Pi OS error.]]></title><description><![CDATA[<p dir="auto">Hi im trying to do a fresh install of MM on the new pi OS but keep getting this error.</p>
<pre><code>Removing libnode72:armhf (12.22.5~dfsg-2~11u1) ...
(Reading database ... 164644 files and directories currently installed.)
Preparing to unpack .../nodejs_14.18.1-deb-1nodesource1_armhf.deb ...
Unpacking nodejs (14.18.1-deb-1nodesource1) over (12.22.5~dfsg-2~11u1) ...
dpkg: error processing archive /var/cache/apt/archives/nodejs_14.18.1-deb-1nodes
ource1_armhf.deb (--unpack):
 trying to overwrite '/usr/share/doc/nodejs/api/embedding.json.gz', which is als
o in package nodejs-doc 12.22.5~dfsg-2~11u1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Errors were encountered while processing:
 /var/cache/apt/archives/nodejs_14.18.1-deb-1nodesource1_armhf.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
]]></description><link>https://forum.magicmirror.builders/topic/15853/mm-install-new-pi-os-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 18:15:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15853.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Nov 2021 07:18:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM install New Pi OS error. on Fri, 12 Nov 2021 22:25:09 GMT]]></title><description><![CDATA[<p dir="auto">Thanks guy got it working.</p>
]]></description><link>https://forum.magicmirror.builders/post/96343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96343</guid><dc:creator><![CDATA[DJBOOB66]]></dc:creator><pubDate>Fri, 12 Nov 2021 22:25:09 GMT</pubDate></item><item><title><![CDATA[Reply to MM install New Pi OS error. on Fri, 12 Nov 2021 21:28:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bert269" aria-label="Profile: bert269">@<bdi>bert269</bdi></a> said in <a href="/post/96338">MM install New Pi OS error.</a>:</p>
<p dir="auto">code: ‘MODULE_NOT_FOUND’,</p>
<p dir="auto">no.</p>
<p dir="auto">that problem is this</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/96341</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96341</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 12 Nov 2021 21:28:45 GMT</pubDate></item><item><title><![CDATA[Reply to MM install New Pi OS error. on Fri, 12 Nov 2021 20:48:47 GMT]]></title><description><![CDATA[<p dir="auto">Try to install node.js v16 at least. I get the same problem as the installation instructions only states v14.<br />
Also, instead of the installation instructions, follow this link and run the script  - I think that will install v16.<br />
[<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a>](link url)</p>
<p dir="auto">I got mine to work this afternoon with node.js v17, but developer said no-go v17 - so I do not know what to tell you. Mine works fine with v17 - well, most of the modules if I do not get a error:<br />
at Object. (/home/pi/MagicMirror/modules/…<br />
at Module._compile (internal/modules/cjs/loader.js:1078:30)<br />
at Object.Module._extensions…js<br />
internal/modules/cjs/loader.js:1108:10) {<br />
code: ‘MODULE_NOT_FOUND’,<br />
requireStack: [<br />
‘/home/pi/MagicMirror/modules/MMM-…/node_helper.js’,<br />
‘/home/pi/MagicMirror/js/app.js’,<br />
‘/home/pi/MagicMirror/js/electron.js’,<br />
‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,<br />
undefined</p>
<p dir="auto">in some modules.<br />
So there is obviously something going on with node.js.</p>
]]></description><link>https://forum.magicmirror.builders/post/96338</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96338</guid><dc:creator><![CDATA[bert269]]></dc:creator><pubDate>Fri, 12 Nov 2021 20:48:47 GMT</pubDate></item></channel></rss>
