<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use the PIR Sensor or the HC-SR04 Sensor to close the screensaver]]></title><description><![CDATA[<p dir="auto">Hi together…</p>
<p dir="auto">Does anybody know if there is a possibility to use one of the modules in topic to get the screensaver closed? I mean its not possible that the mm is awake maybe in the middle of the night.</p>
<p dir="auto">Thanks a lot</p>
]]></description><link>https://forum.magicmirror.builders/topic/15861/use-the-pir-sensor-or-the-hc-sr04-sensor-to-close-the-screensaver</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 12:23:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15861.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Nov 2021 18:54:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Use the PIR Sensor or the HC-SR04 Sensor to close the screensaver on Sun, 16 Jan 2022 02:28:49 GMT]]></title><description><![CDATA[<p dir="auto">This one --&gt;  <a href="https://github.com/bugsounet/MMM-NewPIR" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bugsounet/MMM-NewPIR</a></p>
]]></description><link>https://forum.magicmirror.builders/post/98636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98636</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 16 Jan 2022 02:28:49 GMT</pubDate></item><item><title><![CDATA[Reply to Use the PIR Sensor or the HC-SR04 Sensor to close the screensaver on Sat, 13 Nov 2021 20:11:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/johnbachini" aria-label="Profile: johnbachini">@<bdi>johnbachini</bdi></a> to use it with the PIR sensor…</p>
]]></description><link>https://forum.magicmirror.builders/post/96357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96357</guid><dc:creator><![CDATA[Dinschal]]></dc:creator><pubDate>Sat, 13 Nov 2021 20:11:26 GMT</pubDate></item><item><title><![CDATA[Reply to Use the PIR Sensor or the HC-SR04 Sensor to close the screensaver on Sat, 13 Nov 2021 15:43:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dinschal" aria-label="Profile: dinschal">@<bdi>dinschal</bdi></a></p>
<p dir="auto">To turn off monitor ? Mmm-newpir might be what u want</p>
]]></description><link>https://forum.magicmirror.builders/post/96353</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96353</guid><dc:creator><![CDATA[JohnBachini]]></dc:creator><pubDate>Sat, 13 Nov 2021 15:43:03 GMT</pubDate></item></channel></rss>
