<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Touch Problem]]></title><description><![CDATA[<p dir="auto">Hello, how are you?</p>
<p dir="auto">I have a 55 inch infrared frame that worked perfectly on my other magic mirror.</p>
<p dir="auto">Now I bought a new one and went to use the same frame, but the calibration is not accurate (I used the windows system to calibrate), what could be causing this problem?</p>
]]></description><link>https://forum.magicmirror.builders/topic/15867/touch-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 15:41:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15867.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Nov 2021 04:21:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Touch Problem on Tue, 16 Nov 2021 11:03:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vlogsmath" aria-label="Profile: vlogsmath">@<bdi>vlogsmath</bdi></a> I hate to say this but…</p>
<p dir="auto">Do you have the frame correctly oriented?  I have a 32" IR touch frame and never had to run any kind of calibration on mine.  I just installed it with the usb plug in the lower right corner.</p>
]]></description><link>https://forum.magicmirror.builders/post/96462</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96462</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Tue, 16 Nov 2021 11:03:16 GMT</pubDate></item><item><title><![CDATA[Reply to Touch Problem on Mon, 15 Nov 2021 12:29:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I bought a new mirror, but it’s the same frame as the other one.</p>
<p dir="auto">When I go to calibrate in windows itself, the touch seems to be already saved and it doesn’t go where I touch.</p>
]]></description><link>https://forum.magicmirror.builders/post/96439</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96439</guid><dc:creator><![CDATA[vlogsmath]]></dc:creator><pubDate>Mon, 15 Nov 2021 12:29:41 GMT</pubDate></item><item><title><![CDATA[Reply to Touch Problem on Mon, 15 Nov 2021 04:32:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/vlogsmath" aria-label="Profile: vlogsmath">@<bdi>vlogsmath</bdi></a> said in <a href="/post/96431">Touch Problem</a>:</p>
<p dir="auto">i don’t understand what you said there</p>
<p dir="auto">Now I bought a new one<br />
ok, now you have 2</p>
<p dir="auto">and went to use the same frame,</p>
<p dir="auto">eh?? but u said u bought a new one…</p>
<p dir="auto">but the calibration is not accurate</p>
<p dir="auto">what could be causing this problem?</p>
<p dir="auto">did u calibrate this frame on this machine?<br />
I think u have to calibrate every frame separately…</p>
]]></description><link>https://forum.magicmirror.builders/post/96432</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96432</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Nov 2021 04:32:19 GMT</pubDate></item></channel></rss>
