<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Blank screen on start when installing modules]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I just installed MM on my Pi 400 and it was working fine until i tried installing 3rd party modules. When I start it up i get the following code:</p>
<pre><code>&gt; magicmirror@2.17.1 start
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "run"
App threw an error during load
Error: Cannot find module 'logger'
Require stack:
    at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
    at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Module._load (internal/modules/cjs/loader.js:732:27)
    at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
    at Module.require (internal/modules/cjs/loader.js:959:19)
    at require (internal/modules/cjs/helpers.js:88:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/app.js:13:13)
    at Module._compile (internal/modules/cjs/loader.js:1078:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
A JavaScript error occurred in the main process
Uncaught Exception:
Require stack:
^C/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
<p dir="auto">Thank you for your help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15894/blank-screen-on-start-when-installing-modules</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 13:39:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15894.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Nov 2021 00:38:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Blank screen on start when installing modules on Sun, 21 Nov 2021 04:37:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/natebrown" aria-label="Profile: natebrown">@<bdi>natebrown</bdi></a> i don’t think it applies here at the moment (unless there was a mistake in the module installation and it overlayed some MM files)  delete MagicMirror/node_modules and redo npm install in the MagicMirror folder</p>
<p dir="auto">but see this <a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/96614</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96614</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 21 Nov 2021 04:37:45 GMT</pubDate></item><item><title><![CDATA[Reply to Blank screen on start when installing modules on Sun, 21 Nov 2021 00:50:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/natebrown" aria-label="Profile: natebrown">@<bdi>natebrown</bdi></a> I would do another<br />
npm install<br />
]]></description><link>https://forum.magicmirror.builders/post/96613</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96613</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 21 Nov 2021 00:50:13 GMT</pubDate></item></channel></rss>
