<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Auto-start not working on Pi Zero W]]></title><description><![CDATA[<p dir="auto">I’ve been troubleshooting many different installers and methods for installer Magic Mirror on the Pi Zero W, and I finally got one to work. However, after booting, the Pi launches the web browser, but I have to manually click the Magic Mirror shortcut in the browser. I used <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> script for the installation, which includes pm2 auto start. After I found the issue, I disabled the preinstalled pm2 auto-start and made my own based on <a href="https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> guide. Unfortunately, I get the same problem where the pi launches the browser, but not Magic Mirror. To be clear, I can manually start Magic Mirror, but on reboot, only the browser launches. Any ideas? I’m not too experienced working with Raspberry Pi’s, so if you could dumb down the answers that’d be ideal.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15910/auto-start-not-working-on-pi-zero-w</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 19:49:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15910.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Nov 2021 01:17:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Thu, 16 Dec 2021 02:45:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jaspertheweasel2" aria-label="Profile: jaspertheweasel2">@<bdi>jaspertheweasel2</bdi></a> run the fixuppm2 script,</p>
<p dir="auto">happens occasionally  don’t know why</p>
]]></description><link>https://forum.magicmirror.builders/post/97540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97540</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 16 Dec 2021 02:45:06 GMT</pubDate></item><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Wed, 15 Dec 2021 15:56:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> So how can I fix this? Everything else works except it doesn’t automatically start.</p>
]]></description><link>https://forum.magicmirror.builders/post/97539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97539</guid><dc:creator><![CDATA[JasperTheWeasel2]]></dc:creator><pubDate>Wed, 15 Dec 2021 15:56:22 GMT</pubDate></item><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Sun, 12 Dec 2021 22:14:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jaspertheweasel2" aria-label="Profile: jaspertheweasel2">@<bdi>jaspertheweasel2</bdi></a> only one thing to install</p>
<p dir="auto">later when new mm release use upgrade</p>
<p dir="auto">if u said no to pm2 during install then fixup lets you add it later.</p>
<p dir="auto">no need to run them all at once</p>
]]></description><link>https://forum.magicmirror.builders/post/97439</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97439</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Dec 2021 22:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Sun, 12 Dec 2021 18:09:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I used your guide on Github. I ran the master script, then the upgrade-script and upgrade-script apply, then screensaveroff, and last fixuppm2.</p>
]]></description><link>https://forum.magicmirror.builders/post/97437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97437</guid><dc:creator><![CDATA[JasperTheWeasel2]]></dc:creator><pubDate>Sun, 12 Dec 2021 18:09:48 GMT</pubDate></item><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Sat, 11 Dec 2021 18:38:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jaspertheweasel2" aria-label="Profile: jaspertheweasel2">@<bdi>jaspertheweasel2</bdi></a> how did u install pm2</p>
]]></description><link>https://forum.magicmirror.builders/post/97410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97410</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Dec 2021 18:38:10 GMT</pubDate></item><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Sat, 11 Dec 2021 18:28:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I was having the same problem with mine. I tried the pm2 start and it gave me this error [PM2][ERROR] File ecosystem.config.js not found.</p>
]]></description><link>https://forum.magicmirror.builders/post/97408</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97408</guid><dc:creator><![CDATA[JasperTheWeasel2]]></dc:creator><pubDate>Sat, 11 Dec 2021 18:28:37 GMT</pubDate></item><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Thu, 25 Nov 2021 02:42:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I test my script on the pi0w (and w2) and have to make a special setup on the pi0w as there is no Electron version for armv6l now…</p>
<p dir="auto">so I download a script to use to launch MM as server mode and then launch chromium over that as the UI component</p>
<p dir="auto">looks and acts the same</p>
<p dir="auto">pi0w needs more memory, so u have to increase the swap space</p>
<p dir="auto">as the documented platform is FULL desktop, chromium-browser is installed and usable</p>
]]></description><link>https://forum.magicmirror.builders/post/96769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96769</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 25 Nov 2021 02:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to Auto-start not working on Pi Zero W on Thu, 25 Nov 2021 01:52:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mason-0" aria-label="Profile: mason-0">@<bdi>mason-0</bdi></a> my setup script configures pm2 to launch installers/mm.sh</p>
<p dir="auto">which does npm start</p>
<p dir="auto">can u send me the install.log<br />
same userid at gmail</p>
<p dir="auto">pm2 has lots of options</p>
<p dir="auto">status<br />
info</p>
<p dir="auto">pm2 --help will show u all the options</p>
<p dir="auto">to do start at boot<br />
you do pm2 start<br />
and then pm2 save<br />
to make that restartable at boot</p>
]]></description><link>https://forum.magicmirror.builders/post/96766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96766</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 25 Nov 2021 01:52:14 GMT</pubDate></item></channel></rss>
