<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Solar-Edge module causes black screen]]></title><description><![CDATA[<p dir="auto">I had to rebuild my MM recently and after I was finished my Solar-Edge module causes the MM to give me a black screen. If I remove the solar edge from the config.js, the mirror boots up fine. I used to see a log of sorts on bootup, but now I just see “electron”, so I’m a little lost as to how to troubleshoot. I have tried both solar edge modules in the repo and both give me the same results. It did work great before it crashed and required a rebuild. Can someone assist please? Thank you in advance.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15916/solar-edge-module-causes-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 18:09:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15916.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Nov 2021 16:04:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Solar-Edge module causes black screen on Thu, 25 Nov 2021 20:49:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you! After several hours I finally have things back to working. Whew. For others working on SolarEdge, first, I had to obtain an API key and Site ID from SolarEdge, but to do that, I had to request that my installer reach out to them to give permission. Next I got this to work by using the <a href="https://github.com/bertieuk/MMM-SolarEdge" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bertieuk/MMM-SolarEdge</a> module. After cloning (git clone <a href="https://github.com/bertieuk/MMM-SolarEdge" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bertieuk/MMM-SolarEdge</a> from the module folder), I had to do npm install request. Note, this is deprecated, so it may break again. After that, I am back in business.</p>
<p dir="auto">Hope this can save you the HOURS I just spent. Whew.</p>
]]></description><link>https://forum.magicmirror.builders/post/96800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96800</guid><dc:creator><![CDATA[ssoulages]]></dc:creator><pubDate>Thu, 25 Nov 2021 20:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to Solar-Edge module causes black screen on Thu, 25 Nov 2021 16:05:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ssoulages" aria-label="Profile: ssoulages">@<bdi>ssoulages</bdi></a> probably this<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/96785</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96785</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 25 Nov 2021 16:05:37 GMT</pubDate></item></channel></rss>
