<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMPM Guided Setup problem]]></title><description><![CDATA[<p dir="auto">I have followed the instructions but I can’t get the setup guide to start, I get can’t find the command. Any advice?</p>
]]></description><link>https://forum.magicmirror.builders/topic/15961/mmpm-guided-setup-problem</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 07:43:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15961.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 Dec 2021 02:32:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMPM Guided Setup problem on Thu, 09 Dec 2021 14:50:52 GMT]]></title><description><![CDATA[<p dir="auto">U have to install the mmpm module into config.js to have the communications work</p>
<p dir="auto"><a href="https://github.com/Bee-Mar/mmpm/wiki/MMPM-Installation#or-manually-enable-the-features-yourself" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Bee-Mar/mmpm/wiki/MMPM-Installation#or-manually-enable-the-features-yourself</a></p>
<p dir="auto">apparently guided install didn’t do its thing</p>
<p dir="auto">step 3, install as module</p>
<p dir="auto">(base) sam@sams:~$  mmpm install --as-module<br />
Are you sure you want to install the MMPM module? [yes/y] or [no/n]: y</p>
<ul>
<li>Creating MMPM module in MagicMirror modules directory ✓<br />
Run <code>mmpm open --config</code> and append { module: “mmpm” } to the modules array, then restart MagicMirror if running</li>
</ul>
<pre><code> {   module:'mmpm' }
<p dir="auto">and restart mm</p>
]]></description><link>https://forum.magicmirror.builders/post/97313</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97313</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Dec 2021 14:50:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMPM Guided Setup problem on Wed, 08 Dec 2021 19:57:44 GMT]]></title><description><![CDATA[<p dir="auto">I think you will get no answer here, I recommend to open an issue in the Github repo.</p>
<p dir="auto">There are already several issues with this problem, may you find already a solution there:</p>
<ul>
<li><a href="https://github.com/Bee-Mar/mmpm/issues/76" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Bee-Mar/mmpm/issues/76</a></li>
<li><a href="https://github.com/Bee-Mar/mmpm/issues/67" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Bee-Mar/mmpm/issues/67</a></li>
<li><a href="https://github.com/Bee-Mar/mmpm/issues/60" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Bee-Mar/mmpm/issues/60</a></li>
<li><a href="https://github.com/Bee-Mar/mmpm/issues/53" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Bee-Mar/mmpm/issues/53</a></li>
<li><a href="https://github.com/Bee-Mar/mmpm/issues/52" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/Bee-Mar/mmpm/issues/52</a></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/97301</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97301</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 08 Dec 2021 19:57:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMPM Guided Setup problem on Tue, 07 Dec 2021 12:41:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andzie82" aria-label="Profile: andzie82">@<bdi>andzie82</bdi></a> I am getting this same error…came here looking for help. Following.</p>
]]></description><link>https://forum.magicmirror.builders/post/97231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97231</guid><dc:creator><![CDATA[pingywon]]></dc:creator><pubDate>Tue, 07 Dec 2021 12:41:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMPM Guided Setup problem on Sun, 05 Dec 2021 22:40:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickthebeer" aria-label="Profile: nickthebeer">@<bdi>nickthebeer</bdi></a> suddenly it worked, strange. How ever i cant see the modules if you know what´s wrong?<br />
<img src="/assets/uploads/files/1638744055965-sk%C3%A4rmklipp.png" alt="Skärmklipp.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/97182</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97182</guid><dc:creator><![CDATA[andzie82]]></dc:creator><pubDate>Sun, 05 Dec 2021 22:40:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMPM Guided Setup problem on Sun, 05 Dec 2021 07:48:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andzie82" aria-label="Profile: andzie82">@<bdi>andzie82</bdi></a> can you show us a screenshot of the issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/97152</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97152</guid><dc:creator><![CDATA[nickthebeer]]></dc:creator><pubDate>Sun, 05 Dec 2021 07:48:16 GMT</pubDate></item></channel></rss>
