<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Notification help]]></title><description><![CDATA[<p dir="auto">So I’m trying to stop the notification alert for a Pacific module.<br />
So when I follow the instructions on magic mirror website. It doesn’t seem to work. So here’s the configuration just in case I’m doing it wrong</p>
<pre><code>module: "updatenotification",
position: "top_center",
ignoreModules: ["MMM-mymodule"]
<p dir="auto">So if I’m doing something wrong. I don’t know what it is.<br />
This module is not part of the default modules of magic mirror</p>
<p dir="auto">So I hope someone can help</p>
]]></description><link>https://forum.magicmirror.builders/topic/15990/notification-help</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 14:14:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15990.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 09 Dec 2021 16:45:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Notification help on Thu, 09 Dec 2021 17:19:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> okay I understand. I thought it was something else I thought you could add notification somehow and disable it that way</p>
<p dir="auto">But it’s working now. I appreciate your help</p>
]]></description><link>https://forum.magicmirror.builders/post/97322</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97322</guid><dc:creator><![CDATA[Ray]]></dc:creator><pubDate>Thu, 09 Dec 2021 17:19:41 GMT</pubDate></item><item><title><![CDATA[Reply to Notification help on Thu, 09 Dec 2021 17:17:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ray" aria-label="Profile: ray">@<bdi>ray</bdi></a> here are the settings for a module OUTSIDE the config:{}<br />
<a href="https://docs.magicmirror.builders/modules/configuration.html#module-configuration" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/configuration.html#module-configuration</a></p>
<p dir="auto">disabled:true means that module will not be used  in this startup</p>
]]></description><link>https://forum.magicmirror.builders/post/97321</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97321</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Dec 2021 17:17:34 GMT</pubDate></item><item><title><![CDATA[Reply to Notification help on Thu, 09 Dec 2021 17:13:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Under the Pacific module in the config.js<br />
I heard there was something I can add their that would do the same thing. Is that true<br />
where you would just enter disable true or false</p>
]]></description><link>https://forum.magicmirror.builders/post/97320</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97320</guid><dc:creator><![CDATA[Ray]]></dc:creator><pubDate>Thu, 09 Dec 2021 17:13:38 GMT</pubDate></item><item><title><![CDATA[Reply to Notification help on Thu, 09 Dec 2021 17:05:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ooooo ok I see it now. I can’t believe I missed that<br />
thanks for helping a blind man:grinning_squinting_face:</p>
]]></description><link>https://forum.magicmirror.builders/post/97319</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97319</guid><dc:creator><![CDATA[Ray]]></dc:creator><pubDate>Thu, 09 Dec 2021 17:05:20 GMT</pubDate></item><item><title><![CDATA[Reply to Notification help on Thu, 09 Dec 2021 17:00:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ray" aria-label="Profile: ray">@<bdi>ray</bdi></a> oops…</p>
<p dir="auto">gotta have the config:{} block to pass info to module</p>
<pre><code>config: {
]]></description><link>https://forum.magicmirror.builders/post/97318</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97318</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Dec 2021 17:00:45 GMT</pubDate></item><item><title><![CDATA[Reply to Notification help on Thu, 09 Dec 2021 16:59:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ray" aria-label="Profile: ray">@<bdi>ray</bdi></a> said in <a href="/post/97316">Notification help</a>:</p>
<p dir="auto">“MMM-mymodule”</p>
<p dir="auto">exact case spelling, yes?</p>
]]></description><link>https://forum.magicmirror.builders/post/97317</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97317</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Dec 2021 16:59:18 GMT</pubDate></item></channel></rss>
