<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Jeedom - align to left]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">The module displays information with “CustomTitle” align to left, and value of idx align to right (see on bottom_right)</p>
<p dir="auto">For 2 other MMM-Jeedom (positionned on bottom_left), I want the result align to left.</p>
<p dir="auto"><img src="https://i.ibb.co/617pG86/jeedom-align.png" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto">Is it possible ?<br />
Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/topic/15996/mmm-jeedom-align-to-left</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 05:43:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/15996.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Dec 2021 12:38:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 19:58:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it’s ok, thx</p>
]]></description><link>https://forum.magicmirror.builders/post/97361</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97361</guid><dc:creator><![CDATA[selyjohns]]></dc:creator><pubDate>Fri, 10 Dec 2021 19:58:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 19:47:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/selyjohns" aria-label="Profile: selyjohns">@<bdi>selyjohns</bdi></a> little warning. if u add a module to the list in front of those two, their identifiers will change</p>
]]></description><link>https://forum.magicmirror.builders/post/97359</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97359</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 10 Dec 2021 19:47:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 19:12:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/97355">MMM-Jeedom - align to left</a>:</p>
<p dir="auto">#identifier   .time.align-right  {<br />
text-align: left;<br />
}</p>
<p dir="auto">yep<br />
Works perfectly with the identifier of the two module</p>
<pre><code class="language-css">#module_9_MMM-Jeedom .time.align-right  {
text-align: left;
#module_10_MMM-Jeedom .time.align-right  {
text-align: left;
<p dir="auto">Thank you…again :) !<br />
Have a nice week-end</p>
]]></description><link>https://forum.magicmirror.builders/post/97356</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97356</guid><dc:creator><![CDATA[selyjohns]]></dc:creator><pubDate>Fri, 10 Dec 2021 19:12:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 19:04:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/selyjohns" aria-label="Profile: selyjohns">@<bdi>selyjohns</bdi></a> read this and the next two posts</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/15967/weather-vs-weather-forecast-font/2?_=1638979293900">https://forum.magicmirror.builders/topic/15967/weather-vs-weather-forecast-font/2?_=1638979293900</a></p>
<pre><code>#identifier   .time.align-right  {
text-align: left;
]]></description><link>https://forum.magicmirror.builders/post/97355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97355</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 10 Dec 2021 19:04:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 19:00:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi again,<br />
Finally, I’ve a problem.</p>
<p dir="auto">The modification is applied to all jeedom module, not only on the bottom left one.</p>
<p dir="auto">Is anything possible to apply only the align left to the jeedom module on bottom left only ?</p>
<p dir="auto">I want to keep the align right for the jeedom module on bottom_right</p>
<p dir="auto">Thx.</p>
]]></description><link>https://forum.magicmirror.builders/post/97354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97354</guid><dc:creator><![CDATA[selyjohns]]></dc:creator><pubDate>Fri, 10 Dec 2021 19:00:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 16:37:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> all css goes in custom.css</p>
<p dir="auto">never change main.css</p>
<p dir="auto">never change any files mm ships</p>
]]></description><link>https://forum.magicmirror.builders/post/97344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97344</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 10 Dec 2021 16:37:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 16:35:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/97341">MMM-Jeedom - align to left</a>:</p>
<p dir="auto">.MMM-Jeedom .time.align-right<br />
{<br />
}</p>
<p dir="auto">Works great, in custom.css instead main.css :)<br />
Thank you for your help</p>
]]></description><link>https://forum.magicmirror.builders/post/97343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97343</guid><dc:creator><![CDATA[selyjohns]]></dc:creator><pubDate>Fri, 10 Dec 2021 16:35:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 16:26:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/97341">MMM-Jeedom - align to left</a>:</p>
{<br />
}</p>
<p dir="auto">Should go into custom.css and not main.css right?</p>
]]></description><link>https://forum.magicmirror.builders/post/97342</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97342</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Fri, 10 Dec 2021 16:26:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 16:24:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/selyjohns" aria-label="Profile: selyjohns">@<bdi>selyjohns</bdi></a> said in <a href="/post/97340">MMM-Jeedom - align to left</a>:</p>
<p dir="auto">.region.bottom.left .time.align-right<br />
{<br />
}</p>
<pre><code>.MMM-Jeedom .time.align-right
  text-align: left;
]]></description><link>https://forum.magicmirror.builders/post/97341</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97341</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 10 Dec 2021 16:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Jeedom - align to left on Fri, 10 Dec 2021 16:19:36 GMT]]></title><description><![CDATA[<p dir="auto">With the inspector, I’ve been able to do this :)</p>
<p dir="auto">in main.css</p>
<pre><code class="language-css">.region.bottom.left .time.align-right
  text-align: left;
<p dir="auto">I think it’s not the best optimisation.<br />
I don’t found how to apply only this parameter to Jeedom module, only on bottom_left.</p>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/97340</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97340</guid><dc:creator><![CDATA[selyjohns]]></dc:creator><pubDate>Fri, 10 Dec 2021 16:19:36 GMT</pubDate></item></channel></rss>
