<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gesture control with APDS-9960]]></title><description><![CDATA[<p dir="auto">Since my plan of using a touchfoil blew up in my face due to my own stupid assumptions. I have to look in to other means of controlling my mirror. (No, a IR-frame is sadly not an option due to the shape and size of my mirror.)</p>
<p dir="auto">Searching here there is one Gesture module (MMM-Swipe) that uses the HC-SR04 ultrasonic sensor,<br />
It’s a cheap sensor and most of the work is done, so I have ordered one of those too.<br />
The cons are however that is limited to three inputs, left, right and “push”.</p>
<p dir="auto">The APDS-9960 Sensor ( <a href="https://www.sparkfun.com/products/12787" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.sparkfun.com/products/12787</a> ) However has also swipe up/down,<br />
and it’s a optical sensor, so with a smidge of luck, it might work behind the glass (not counting on it though).<br />
Bad thing is the range is only 10-20cm above (without anything in it’s way), so basically has to swipe on the mirror itself.</p>
<p dir="auto">And, the APDS isn’t MM2 ready, it isn’t really raspberry ready either so it would probably require some long nights tinkering for me. So if the first tests are a success I might need some help getting the sensor to work with the MM2.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1600/gesture-control-with-apds-9960</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 14:02:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1600.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Jan 2017 17:09:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sun, 31 May 2020 17:51:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> , Sweet!  Thanks!!</p>
]]></description><link>https://forum.magicmirror.builders/post/76214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76214</guid><dc:creator><![CDATA[wifibum]]></dc:creator><pubDate>Sun, 31 May 2020 17:51:07 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sat, 30 May 2020 20:34:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> I am using an Apds sensor with other sensors on a Arduino connected to the pi via serial interface. I documented it and wrote a universal module to receive messages on the serial interface. You can find my documentation at <a href="https://github.com/Tom-Hirschberger/MMM-Serial-Notifications/tree/master/examples" target="_blank" rel="noopener noreferrer nofollow ugc">Examples</a></p>
]]></description><link>https://forum.magicmirror.builders/post/76165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76165</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Sat, 30 May 2020 20:34:29 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sat, 30 May 2020 02:49:03 GMT]]></title><description><![CDATA[<p dir="auto">Did you ever get the APDS-9960 working with MM? I happen to have one, would keep me from ordering something else.</p>
]]></description><link>https://forum.magicmirror.builders/post/76119</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/76119</guid><dc:creator><![CDATA[wifibum]]></dc:creator><pubDate>Sat, 30 May 2020 02:49:03 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Thu, 14 Feb 2019 17:12:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bolish" aria-label="Profile: bolish">@<bdi>bolish</bdi></a> that’s exactly what i was thinking but thx for the recommendations… i will even not try an attempt then. i wanted smt “beautiful” as you mentioned but without seeing the sensor…<br />
hmm i’ll think about smt or maybe i’ll check another solution as voice command… with jarvis</p>
]]></description><link>https://forum.magicmirror.builders/post/52357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52357</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Thu, 14 Feb 2019 17:12:03 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Thu, 14 Feb 2019 12:21:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a><br />
I’ve already made some trials with 1mm thin wood. Forget about it.<br />
You will find the product data sheet with some recommandation at the bottom of below page :<br />
<a href="http://wiki.seeedstudio.com/Grove-Gesture_v1.0/" target="_blank" rel="noopener noreferrer nofollow ugc">link text</a></p>
<p dir="auto">I’ve tried behing 2mm wood, with a hole (3mm diameter), it works fine. Not so ugly…</p>
<p dir="auto">Let’s see.</p>
<p dir="auto">Regards</p>
]]></description><link>https://forum.magicmirror.builders/post/52345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52345</guid><dc:creator><![CDATA[bolish]]></dc:creator><pubDate>Thu, 14 Feb 2019 12:21:15 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Wed, 13 Feb 2019 17:51:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bolish" aria-label="Profile: bolish">@<bdi>bolish</bdi></a> i thought about it meantimes i am waiting for delivery… i was thinking to make a kind of slot in one of the wooden frame side, just enough to make so that the wood layer is so thin that i hope it will let pass the gesture but it will be difficult to do as my mirror is already build now and i can’s say for now if it will work. if you come up with another idea… feel free to share :)</p>
]]></description><link>https://forum.magicmirror.builders/post/52297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52297</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Wed, 13 Feb 2019 17:51:36 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Tue, 12 Feb 2019 20:25:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I’ve the PAJ7620u2 one.<br />
I’m experiencing some stability issue with it (it always stops working after some minutes) but overall it’s great. I will post about the stability issue later on.</p>
<p dir="auto">I’m interested into how you guys are using the sensor in a "beautiful way).<br />
Before buying it, I thought I could cover it with some “speaker fabric” but it’s not working neither…</p>
<p dir="auto">Do you have some smart ideas on your side on how to hide it?</p>
]]></description><link>https://forum.magicmirror.builders/post/52209</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/52209</guid><dc:creator><![CDATA[bolish]]></dc:creator><pubDate>Tue, 12 Feb 2019 20:25:03 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sun, 20 Jan 2019 16:19:32 GMT]]></title><description><![CDATA[<p dir="auto">@sean said in <a href="/post/50456">Gesture control with APDS-9960</a>:</p>
<p dir="auto">PAJ7620u2</p>
<p dir="auto">no idea as well… waiting on my sensor APDS… once received, i’ll test with your module :thumbs_up_medium-light_skin_tone:</p>
]]></description><link>https://forum.magicmirror.builders/post/50457</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50457</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 20 Jan 2019 16:19:32 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sun, 20 Jan 2019 16:13:37 GMT]]></title><description><![CDATA[<p dir="auto">I’m not sure whether it is compatible with APDS-9960, but I made a module for GroveGesture Sensor(PAJ7620u2 compatible)<br />
<a href="https://github.com/eouia/MMM-GroveGestures" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-GroveGestures</a></p>
<p dir="auto"><a href="https://youtu.be/BcpZvkcrfHU" target="_blank" rel="noopener noreferrer nofollow ugc"><img src="https://img.youtube.com/vi/BcpZvkcrfHU/0.jpg" alt="2.1.0 demo" class=" img-fluid img-markdown" /></a></p>
<p dir="auto"><img src="https://github.com/eouia/MMM-GroveGestures/raw/master/Gesture_sensor_3.png" alt="image" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/50456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50456</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 20 Jan 2019 16:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sun, 20 Jan 2019 16:08:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> yea haven’t neither think about room for it while building my one… :smiling_face_with_open_mouth_cold_sweat:</p>
]]></description><link>https://forum.magicmirror.builders/post/50455</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50455</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 20 Jan 2019 16:08:25 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sun, 20 Jan 2019 15:21:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bibi" aria-label="Profile: bibi">@<bdi>bibi</bdi></a> It’s on hold, the big drawback is that I haven’t included space for any sensor in the frame, so any addon would “stick out” and look wonky.<br />
So maybe I’ll just add some physical buttons and make a tree style menu instead.</p>
]]></description><link>https://forum.magicmirror.builders/post/50448</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50448</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 20 Jan 2019 15:21:32 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Sun, 20 Jan 2019 15:17:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> did you find any suitable solution or stopped your project?</p>
]]></description><link>https://forum.magicmirror.builders/post/50447</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/50447</guid><dc:creator><![CDATA[bibi]]></dc:creator><pubDate>Sun, 20 Jan 2019 15:17:01 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Mon, 06 Feb 2017 14:45:21 GMT]]></title><description><![CDATA[<p dir="auto">Okey guys, I’d really need some guidance. My head goes round in circles and I don’t know where to start.</p>
<p dir="auto">As mentioned before I’ve gotten the sensor to work with the help of wiringPi and a c library converted for the pi.</p>
<p dir="auto">Then I Found this : <a href="https://github.com/jiahuang/apds-gesture" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jiahuang/apds-gesture</a><br />
a control driver for node, but that is using a Tessel and I can’t really understand how to replace the tessel line with Raspberry.</p>
<p dir="auto">I’m guessing I need an i2c module to let the apds-gesture connect to the raspberrys pins?</p>
]]></description><link>https://forum.magicmirror.builders/post/13761</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13761</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Mon, 06 Feb 2017 14:45:21 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Fri, 03 Feb 2017 18:54:03 GMT]]></title><description><![CDATA[<p dir="auto">Well, It doesn’t work through the glass. But it works!</p>
<p dir="auto">and it’s somewhat sensitive to get the motions right, maybe that is a software issue and not hardware, BUT it does read side to side and up down. Which is good and opens up to navigate modules easier.</p>
<p dir="auto">But it bugs me that I have to build a box for it outside the mirror.</p>
]]></description><link>https://forum.magicmirror.builders/post/13461</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13461</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:54:03 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Mon, 30 Jan 2017 22:55:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> Let us all know if it does :)</p>
]]></description><link>https://forum.magicmirror.builders/post/13083</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13083</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 30 Jan 2017 22:55:07 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Mon, 30 Jan 2017 17:38:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> Yeah I saw that one to when I was looking around,<br />
It works basically on the same principle as the touch foil I have besides me right now, so anything of metal would disrupt it I think, (I’m really hopeful the optical sensor will work through the mirror glass)</p>
]]></description><link>https://forum.magicmirror.builders/post/13050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13050</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Mon, 30 Jan 2017 17:38:50 GMT</pubDate></item><item><title><![CDATA[Reply to Gesture control with APDS-9960 on Mon, 30 Jan 2017 17:35:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/broberg" aria-label="Profile: broberg">@<bdi>broberg</bdi></a> looking forward to your results</p>
<p dir="auto">i think this could be also interesting <a href="http://www.exp-tech.de/pimoroni-skywriter-hat-3d-gesture-sensor-raspberry-pi" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.exp-tech.de/pimoroni-skywriter-hat-3d-gesture-sensor-raspberry-pi</a></p>
]]></description><link>https://forum.magicmirror.builders/post/13049</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13049</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Mon, 30 Jan 2017 17:35:15 GMT</pubDate></item></channel></rss>
