<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Podcast2 - deprecated package request]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">while trying to build my first magicmirror I’m struggeling on the usage of MMM-Podcast2.<br />
I noticed that since MM Release 2.15.0 the package <em><strong>request</strong></em> is removed as it’s deprecated.</p>
<p dir="auto">As MMM-Podcast 2 makes use of this package MM is showing this error on startup:</p>
<pre><code>[11.12.2021 18:18.30.091] [ERROR] Error: Cannot find module 'request'
Require stack:
- /home/pi/MagicMirror/modules/MMM-Podcast2/node_helper.js
    at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)
    at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)
    at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
    at Module._load (internal/modules/cjs/loader.js:732:27)
    at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
    at Module.require (internal/modules/cjs/loader.js:959:19)
    at require (internal/modules/cjs/helpers.js:88:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Podcast2/node_helper.js:11:17)
    at Module._compile (internal/modules/cjs/loader.js:1078:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
<p dir="auto">So, my question is: Does anyone maybe already replaced the usage package request with e.g. node-fetch (it’s stated as successor in the release notes) in MMM-Podcast2?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16005/mmm-podcast2-deprecated-package-request</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:23:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16005.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Dec 2021 17:40:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Podcast2 - deprecated package request on Sat, 11 Dec 2021 18:07:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oggo" aria-label="Profile: oggo">@<bdi>oggo</bdi></a> until someone changes the code, you can only install request to use this module</p>
]]></description><link>https://forum.magicmirror.builders/post/97407</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97407</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Dec 2021 18:07:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-Podcast2 - deprecated package request on Sat, 11 Dec 2021 17:44:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oggo" aria-label="Profile: oggo">@<bdi>oggo</bdi></a> see this<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/97406</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97406</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 11 Dec 2021 17:44:09 GMT</pubDate></item></channel></rss>
