<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[electron security warning issue]]></title><description><![CDATA[<p dir="auto">My problem is I cannot read content of newsfeed article on the magic mirror display. Some content briefly flashes on screen, then nothing but the errors as described below.</p>
<p dir="auto">Whenever I send the ‘newsfeed’ module the ‘ARTICLE_MORE_DETAILS’ command two or more times, I get the following error…<em>"Refused to frame ‘<a href="https://www.cnn.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.cnn.com/</a>’ Because an ancestor violates the following Content Security Policy directive: "frame-ancestors ‘self’ https://</em>.cnn.com:<em>"</em>…etc</p>
<p dir="auto">I see this error when I run the <strong>npm run start:dev</strong> command.</p>
<p dir="auto">Also, please note I am seeing a warning message as soon as I start the magic mirror display. The warning message says: <em>“Electron Security Warning (Insecure Content-Security-Policy) This render process has either no Content Security. Policy set or a policy with “unsafe-eval” enabled. This exposes uses of this app to unnecessary security risks.”</em></p>
<p dir="auto">I am attempting to access article content from the following RSS feed: “<a href="http://rss.cnn.com/rss/cnn_topstories.rss" target="_blank" rel="noopener noreferrer nofollow ugc">http://rss.cnn.com/rss/cnn_topstories.rss</a>”</p>
<p dir="auto">Any help to resolve this issue is appreciated!</p>
]]></description><link>https://forum.magicmirror.builders/topic/16010/electron-security-warning-issue</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 21:58:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16010.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Dec 2021 03:34:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to electron security warning issue on Tue, 14 Dec 2021 14:06:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stevencarp102" aria-label="Profile: stevencarp102">@<bdi>stevencarp102</bdi></a> I would open an issue on the MagicMirror gitHub issues page</p>
<p dir="auto">I know they were working on a couple content security issues for next release ( Jan 1)</p>
]]></description><link>https://forum.magicmirror.builders/post/97489</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97489</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Dec 2021 14:06:40 GMT</pubDate></item><item><title><![CDATA[Reply to electron security warning issue on Tue, 14 Dec 2021 03:59:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am using the MMM-GroveGestures module with the Grove Gesture Sensor (PAJ7620u2). I configured it so when I gesture “Up” in front of the sensors a  'ARTICLE_MORE_DETAILS’ command is sent to the newsfeed module. ```<br />
<a href="https://github.com/eouia/MMM-GroveGestures" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/eouia/MMM-GroveGestures</a></p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/97477</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97477</guid><dc:creator><![CDATA[stevencarp102]]></dc:creator><pubDate>Tue, 14 Dec 2021 03:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to electron security warning issue on Mon, 13 Dec 2021 13:14:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stevencarp102" aria-label="Profile: stevencarp102">@<bdi>stevencarp102</bdi></a> I do not. have never tried that, don’t know how it’s supposed to work.</p>
<p dir="auto">how did u send the notification?</p>
]]></description><link>https://forum.magicmirror.builders/post/97454</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97454</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Dec 2021 13:14:05 GMT</pubDate></item><item><title><![CDATA[Reply to electron security warning issue on Mon, 13 Dec 2021 12:40:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> also, do you have an example config.js perhaps in which the “view more details of the article” feature works?</p>
<p dir="auto">FYI, I am using the “Up” gesture with the MMM-GroveGestures module to indicate when the ‘ARTICLE_MORE_DETAILS’ command is sent to the default newsfeed module.</p>
<p dir="auto">Thanks for your help by the way!</p>
]]></description><link>https://forum.magicmirror.builders/post/97453</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97453</guid><dc:creator><![CDATA[stevencarp102]]></dc:creator><pubDate>Mon, 13 Dec 2021 12:40:05 GMT</pubDate></item><item><title><![CDATA[Reply to electron security warning issue on Mon, 13 Dec 2021 12:31:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Yes, I am using the default newfeed module. I don’t mind having the security warning, but I thought there seems to be a connection to the error that occurs when the software tries to execute the 'ARTICLE_MORE_DETAILS’ command.</p>
<p dir="auto">Do you have an RSS feeds URL that you know works when trying to bring up the whole article on the screen with this command?</p>
]]></description><link>https://forum.magicmirror.builders/post/97452</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97452</guid><dc:creator><![CDATA[stevencarp102]]></dc:creator><pubDate>Mon, 13 Dec 2021 12:31:33 GMT</pubDate></item><item><title><![CDATA[Reply to electron security warning issue on Mon, 13 Dec 2021 04:43:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stevencarp102" aria-label="Profile: stevencarp102">@<bdi>stevencarp102</bdi></a> are you using the default newsfeed module of something else?</p>
]]></description><link>https://forum.magicmirror.builders/post/97444</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97444</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Dec 2021 04:43:20 GMT</pubDate></item><item><title><![CDATA[Reply to electron security warning issue on Mon, 13 Dec 2021 04:41:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stevencarp102" aria-label="Profile: stevencarp102">@<bdi>stevencarp102</bdi></a> I can’t answer the question, but the security warning is nothing we can do anything about, and doesn’t impact execution</p>
]]></description><link>https://forum.magicmirror.builders/post/97443</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97443</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Dec 2021 04:41:33 GMT</pubDate></item></channel></rss>
