<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform]]></title><description><![CDATA[<p dir="auto">MMM-BackgroundSlideshow doesn’t seem to work.</p>
<pre><code>/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
[13.12.2021 00:33.17.130] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
[13.12.2021 00:33.17.155] [ERROR] App threw an error during load
[13.12.2021 00:33.17.158] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
    at Object.hasVendoredLibvips (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/libvips.js:82:13)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/constructor.js:7:22)
    at Module._compile (internal/modules/cjs/loader.js:1078:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)
    at Module.load (internal/modules/cjs/loader.js:935:32)
    at Module._load (internal/modules/cjs/loader.js:776:14)
    at Function.f._load (electron/js2c/asar_bundle.js:5:12913)
    at Module.require (internal/modules/cjs/loader.js:959:19)
    at require (internal/modules/cjs/helpers.js:88:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-BackgroundSlideshow/node_modules/sharp/lib/index.js:3:15)
[13.12.2021 00:33.17.161] [ERROR] Whoops! There was an uncaught exception...
[13.12.2021 00:33.17.169] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
<p dir="auto">Any clue what might be going on here?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16014/mmm-backgroundslideshow-linux-armv7-binaries-cannot-be-used-on-the-linux-armvdefault-platform</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 12:46:37 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16014.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Dec 2021 08:11:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Mon, 10 Jan 2022 21:55:36 GMT]]></title><description><![CDATA[<p dir="auto">For me it worked to install a self compiled version of vips…</p>
<pre><code>sudo apt install -y build-essential libglib2.0 libjpeg9 libopenjp2-7 librsvg2-dev imagemagick libtiff5-dev
wget https://github.com/libvips/libvips/releases/download/v8.12.1/vips-8.12.1.tar.gz
tar xfvz vips-8.12.1.tar.gz
cd vips-8.12.1
./configure
make
sudo make install
sudo ldconfig
npm install
<p dir="auto">It will take a while to compile the library and a lot of disk space will be used.</p>
]]></description><link>https://forum.magicmirror.builders/post/98366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98366</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Mon, 10 Jan 2022 21:55:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Sun, 02 Jan 2022 14:22:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: bkeyport">@<bdi>bkeyport</bdi></a> I think one would have to set the parms on install per the sharp doc</p>
<p dir="auto"><a href="https://sharp.pixelplumbing.com/install" target="_blank" rel="noopener noreferrer nofollow ugc">https://sharp.pixelplumbing.com/install</a></p>
<p dir="auto">looks like prebuilt binaries are not produced for 32bit os systems (raspi os)</p>
]]></description><link>https://forum.magicmirror.builders/post/97959</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97959</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Jan 2022 14:22:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Sun, 02 Jan 2022 05:39:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> FWIW, I downgraded to buster and it does it there as well, I’ve disabled the module for the short term.</p>
]]></description><link>https://forum.magicmirror.builders/post/97946</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97946</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sun, 02 Jan 2022 05:39:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Tue, 14 Dec 2021 18:44:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> yes, that is the one I linked to. but it says armv6, not armv7…</p>
]]></description><link>https://forum.magicmirror.builders/post/97498</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97498</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Dec 2021 18:44:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Tue, 14 Dec 2021 17:52:50 GMT]]></title><description><![CDATA[<p dir="auto">there is already an issue in the <a href="https://github.com/darickc/MMM-BackgroundSlideshow/issues/101" target="_blank" rel="noopener noreferrer nofollow ugc">github repo</a></p>
]]></description><link>https://forum.magicmirror.builders/post/97495</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97495</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Tue, 14 Dec 2021 17:52:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Tue, 14 Dec 2021 03:44:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brandoney" aria-label="Profile: brandoney">@<bdi>brandoney</bdi></a> thx. this looks like a problem with bullseye and node</p>
<p dir="auto">here is similar sharp problem<br />
<a href="https://github.com/lovell/sharp/issues/2287" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/lovell/sharp/issues/2287</a></p>
<p dir="auto">I don’t know what to do about this</p>
]]></description><link>https://forum.magicmirror.builders/post/97475</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97475</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Dec 2021 03:44:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Tue, 14 Dec 2021 03:29:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/97473">MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform</a>:</p>
<p dir="auto">node -v<br />
and npm -v</p>
v14.18.2<br />
pi@raspberrypi:~/MagicMirror/config $ npm -v<br />
6.14.15</p>
]]></description><link>https://forum.magicmirror.builders/post/97474</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97474</guid><dc:creator><![CDATA[Brandoney]]></dc:creator><pubDate>Tue, 14 Dec 2021 03:29:37 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Tue, 14 Dec 2021 03:19:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brandoney" aria-label="Profile: brandoney">@<bdi>brandoney</bdi></a> yes, I saw your report before…</p>
<p dir="auto">can u also do</p>
and npm -v</p>
]]></description><link>https://forum.magicmirror.builders/post/97473</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97473</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 14 Dec 2021 03:19:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Tue, 14 Dec 2021 03:18:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I have this issue.</p>
<pre><code> uname -a
Linux raspberrypi 5.10.63-v7l+ #1488 SMP Thu Nov 18 16:15:28 GMT 2021 armv7l GNU/Linux
pi@raspberrypi:~/MagicMirror/config $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
<pre><code>[31mSyntaxError: Unexpected identifier[39m
[31m    at wrapSafe (internal/modules/cjs/loader.js:986:16)[39m
[31m    at Module._compile (internal/modules/cjs/loader.js:1034:27)[39m
[31m    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1108:10)[39m
[31m    at Module.load (internal/modules/cjs/loader.js:935:32)[39m
[31m    at Module._load (internal/modules/cjs/loader.js:776:14)[39m
[31m    at Function.f._load (electron/js2c/asar_bundle.js:5:12913)[39m
[31m    at Module.require (internal/modules/cjs/loader.js:959:19)[39m
[31m    at require (internal/modules/cjs/helpers.js:88:18)[39m
[31m    at loadConfig (/home/pi/MagicMirror/js/app.js:69:14)[39m
[31m    at App.start (/home/pi/MagicMirror/js/app.js:212:3)[39m
[13.12.2021 21:11.52.510] [ERROR] [31mWARNING! Could not load config file. Starting with default configuration. Error found: Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.[39m
[13.12.2021 21:11.52.533] [ERROR] App threw an error during load
[13.12.2021 21:11.52.535] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
[13.12.2021 21:11.52.536] [ERROR] Whoops! There was an uncaught exception...
[13.12.2021 21:11.52.539] [ERROR] Error: 'linux-armv7' binaries cannot be used on the 'linux-armvdefault' platform. Please remove the 'node_modules/sharp' directory and run 'npm install' on the 'linux-armvdefault' platform.
[13.12.2021 21:11.52.540] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[13.12.2021 21:11.52.540] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
]]></description><link>https://forum.magicmirror.builders/post/97471</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97471</guid><dc:creator><![CDATA[Brandoney]]></dc:creator><pubDate>Tue, 14 Dec 2021 03:18:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-BackgroundSlideshow 'linux-armv7' binaries cannot be used on the "linux-armvdefault platform on Mon, 13 Dec 2021 13:15:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/katai" aria-label="Profile: katai">@<bdi>katai</bdi></a> tell us more</p>
<p dir="auto">output of<br />
uname -a<br />
and<br />
lsb_release -a</p>
]]></description><link>https://forum.magicmirror.builders/post/97455</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97455</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 13 Dec 2021 13:15:42 GMT</pubDate></item></channel></rss>
