<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SolarEdge not running]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/6953/solaredge-module">SolarEdge Module</a></p>
<p dir="auto">Hi, I installed the MMM-SolarEdge module and inserted the config. I get this error and MM does not run. What is wrong and how can I fix it?</p>
<p dir="auto">[20.12.2021 20:03.39.959] [ERROR] App threw an error during load<br />
[20.12.2021 20:03.39.962] [ERROR] Error: Cannot find module ‘request’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/MMM-SolarEdge/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
<li>at Module._resolveFilename (internal/modules/cjs/loader.js:887:15)<br />
at Function.n._resolveFilename (electron/js2c/browser_init.js:257:1128)<br />
at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (internal/modules/cjs/loader.js:732:27)<br />
at Function.f._load (electron/js2c/asar_bundle.js:5:12913)<br />
at Module.require (internal/modules/cjs/loader.js:959:19)<br />
at require (internal/modules/cjs/helpers.js:88:18)<br />
at Object. (/home/pi/MagicMirror/modules/MMM-SolarEdge/node_helper.js:2:15)<br />
at Module._compile (internal/modules/cjs/loader.js:1078:30)<br />
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)<br />
[20.12.2021 20:03.39.967] [ERROR] Whoops! There was an uncaught exception…<br />
[20.12.2021 20:03.39.973] [ERROR] Error: Cannot find module ‘request’<br />
Require stack:</li>
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10) {<br />
code: ‘MODULE_NOT_FOUND’,<br />
requireStack: [<br />
‘/home/pi/MagicMirror/modules/MMM-SolarEdge/node_helper.js’,<br />
‘/home/pi/MagicMirror/js/app.js’,<br />
‘/home/pi/MagicMirror/js/electron.js’,<br />
‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,<br />
undefined</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/16050/mmm-solaredge-not-running</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 12:34:36 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16050.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Dec 2021 19:24:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SolarEdge not running on Mon, 20 Dec 2021 20:54:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/digied" aria-label="Profile: digied">@<bdi>digied</bdi></a></p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/97665</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97665</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Mon, 20 Dec 2021 20:54:35 GMT</pubDate></item></channel></rss>
