<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM Google Photos error]]></title><description><![CDATA[<p dir="auto">having troulbe with getting the google photo running</p>
<p dir="auto">i followed the github instruction but seem to be stuck with the black screen of death</p>
<p dir="auto">npm start run  displays</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm start run</p>
<p dir="auto">magicmirror@2.17.1 start /home/pi/MagicMirror<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “run”</p>
<p dir="auto">[21.12.2021 19:41.00.282] [LOG]   Starting MagicMirror: v2.17.1<br />
[21.12.2021 19:41.00.288] [LOG]   Loading config …<br />
[21.12.2021 19:41.00.294] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: MagicMirror is not defined<br />
at Object. (/home/pi/MagicMirror/config/config.js:45:12)<br />
at Module._compile (internal/modules/cjs/loader.js:1078:30)<br />
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1108:10)<br />
at Module.load (internal/modules/cjs/loader.js:935:32)<br />
at Module._load (internal/modules/cjs/loader.js:776:14)<br />
at Function.f._load (electron/js2c/asar_bundle.js:5:12913)<br />
at Module.require (internal/modules/cjs/loader.js:959:19)<br />
at require (internal/modules/cjs/helpers.js:88:18)<br />
at loadConfig (/home/pi/MagicMirror/js/app.js:69:14)<br />
at App.start (/home/pi/MagicMirror/js/app.js:212:3)<br />
[21.12.2021 19:41.00.296] [LOG]   Loading module helpers …<br />
[21.12.2021 19:41.00.313] [LOG]   Initializing new module helper …<br />
[21.12.2021 19:41.00.314] [LOG]   Module helper loaded: updatenotification<br />
[21.12.2021 19:41.00.316] [LOG]   No helper found for module: helloworld.<br />
[21.12.2021 19:41.00.317] [LOG]   All module helpers loaded.<br />
[21.12.2021 19:41.00.473] [LOG]   Starting server on port 8080 …<br />
[21.12.2021 19:41.00.492] [LOG]   Server started …<br />
[21.12.2021 19:41.00.494] [LOG]   Connecting socket for: updatenotification<br />
[21.12.2021 19:41.00.496] [LOG]   Sockets connected &amp; modules started …<br />
[21.12.2021 19:41.00.714] [ERROR] Whoops! There was an uncaught exception…<br />
[21.12.2021 19:41.00.721] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080<br />
at Server.setupListenHandle [as _listen2] (net.js:1318:16)<br />
at listenInCluster (net.js:1366:12)<br />
at GetAddrInfoReqWrap.doListen [as callback] (net.js:1503:7)<br />
at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:69:8) {<br />
code: ‘EADDRINUSE’,<br />
errno: -98,<br />
syscall: ‘listen’,<br />
address: ‘127.0.0.1’,<br />
port: 8080<br />
}<br />
[21.12.2021 19:41.00.729] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
[21.12.2021 19:41.00.730] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
[21.12.2021 19:41.00.770] [LOG]   Launching application.<br />
^C[21.12.2021 19:41.23.180] [LOG]   Shutting down server…<br />
[21.12.2021 19:41.23.185] [LOG]   Stopping module helper: updatenotification</p>
]]></description><link>https://forum.magicmirror.builders/topic/16063/mmm-google-photos-error</link><generator>RSS for Node</generator><lastBuildDate>Fri, 04 Sep 2026 17:47:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16063.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Dec 2021 03:44:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM Google Photos error on Thu, 23 Dec 2021 09:21:17 GMT]]></title><description><![CDATA[<p dir="auto">@sultan-y<br />
Which position did you put the module into? set the position <code>fullscreen_below</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/97741</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97741</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Thu, 23 Dec 2021 09:21:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM Google Photos error on Thu, 23 Dec 2021 07:09:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">apparently i just needed to be patient, it needed to propagate</p>
<p dir="auto">now its working</p>
<p dir="auto">howevver the clokc and some other apps have disappeared</p>
<p dir="auto">is there a way to  have it be in the background, so i can see my clock and calendar?</p>
]]></description><link>https://forum.magicmirror.builders/post/97739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97739</guid><dc:creator><![CDATA[sultan.y]]></dc:creator><pubDate>Thu, 23 Dec 2021 07:09:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM Google Photos error on Thu, 23 Dec 2021 06:54:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">i think i fixed the access but now i get a  503 error</p>
<p dir="auto">22.12.2021 22:51.16.328] [LOG]   /nodehelper/get translation with statuscode-200<br />
[22.12.2021 22:51.16.335] [LOG]   /nodehelper/get arabic with statuscode-200<br />
[22.12.2021 22:51.16.338] [LOG]   /nodehelper/result-An-Naml:77<br />
[22.12.2021 22:51.16.357] [LOG]   200[object Object]<br />
[22.12.2021 22:51.17.516] [ERROR] (node:4593) UnhandledPromiseRejectionWarning: Error: Request failed with status code 503<br />
at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)<br />
at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:17:12)<br />
at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:236:11)<br />
at IncomingMessage.emit (events.js:327:22)<br />
at endReadableNT (internal/streams/readable.js:1327:12)<br />
at processTicksAndRejections (internal/process/task_queues.js:80:21)<br />
(Use <code>electron --trace-warnings ...</code> to show where the warning was created)<br />
[22.12.2021 22:51.17.523] [ERROR] (node:4593) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag <code>--unhandled-rejections=strict</code> (see <a href="https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode</a>). (rejection id: 2)<br />
[22.12.2021 22:51.17.526] [ERROR] (node:4593) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.</p>
]]></description><link>https://forum.magicmirror.builders/post/97738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97738</guid><dc:creator><![CDATA[sultan.y]]></dc:creator><pubDate>Thu, 23 Dec 2021 06:54:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM Google Photos error on Wed, 22 Dec 2021 12:36:33 GMT]]></title><description><![CDATA[<p dir="auto">@sultan-y said in <a href="/post/97713">MMM Google Photos error</a>:</p>
<p dir="auto">Request failed with status code 403<br />
at createError</p>
<p dir="auto">you are getting a permission denied 403 error<br />
from google</p>
]]></description><link>https://forum.magicmirror.builders/post/97719</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97719</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 22 Dec 2021 12:36:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM Google Photos error on Wed, 22 Dec 2021 07:28:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">1.12.2021 23:16.00.533] [ERROR] (node:2556) UnhandledPromiseRejectionWarning: Error: Request failed with status code 403<br />
[21.12.2021 23:16.00.534] [ERROR] (node:2556) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag <code>--unhandled-rejections=strict</code> (see <a href="https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode" target="_blank" rel="noopener noreferrer nofollow ugc">https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode</a>). (rejection id: 2)<br />
[21.12.2021 23:16.00.535] [ERROR] (node:2556) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.</p>
<p dir="auto">modules: [<br />
{<br />
module: “MMM-GooglePhotos”,<br />
position: “fullscreen_below”,<br />
config: {<br />
albums: [“MagicMirror”], // Set your album name. like [“My wedding”, “family share”, “Travle to Paris”]<br />
updateInterval: 1000 * 60, // minimum 10 seconds.<br />
sort: “new”, // “old”, “random”<br />
uploadAlbum: null, // Only album created by <code>create_uploadable_album.js</code>.<br />
condition: {<br />
fromDate: null, // Or “2018-03”, RFC … format available<br />
toDate: null, // Or “2019-12-25”,<br />
minWidth: null, // Or 400<br />
maxWidth: null, // Or 8000<br />
minHeight: null, // Or 400<br />
maxHeight: null, // Or 8000<br />
minWHRatio: null,<br />
maxWHRatio: null,<br />
// WHRatio = Width/Height ratio ( ==1 : Squared Photo,   &lt; 1 : Portraited Photo, &gt; 1 : Landscaped Photo)<br />
},<br />
showWidth: 1080, // These values will be used for quality of downloaded photos to show. real size to show in your MagicMirror region is recommended.<br />
showHeight: 1920,<br />
timeFormat: “YYYY/MM/DD HH:mm”, // Or <code>relative</code> can be used.<br />
}<br />
},</p>
]]></description><link>https://forum.magicmirror.builders/post/97713</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97713</guid><dc:creator><![CDATA[sultan.y]]></dc:creator><pubDate>Wed, 22 Dec 2021 07:28:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM Google Photos error on Wed, 22 Dec 2021 04:35:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">EADDRINUSE got fixed the  configurtion error remains</p>
<p dir="auto">[21.12.2021 19:41.00.294] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: MagicMirror is not defined<br />
at Module.require (internal/modules/cjs/loader.js:959:</p>
]]></description><link>https://forum.magicmirror.builders/post/97712</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97712</guid><dc:creator><![CDATA[sultan.y]]></dc:creator><pubDate>Wed, 22 Dec 2021 04:35:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM Google Photos error on Wed, 22 Dec 2021 03:54:04 GMT]]></title><description><![CDATA[<p dir="auto">@sultan-y said in <a href="/post/97709">MMM Google Photos error</a>:</p>
<p dir="auto">[21.12.2021 19:41.00.721] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080</p>
<p dir="auto">how did you install MM?</p>
<p dir="auto">this means another instance is running…</p>
<p dir="auto">if pm2 started one, then pm2 status  will show you</p>
<p dir="auto">then pm2 stop xx<br />
where xx is the number or the name on the row of the thing u want to stop<br />
(ps pm2 can run lots of things at once)</p>
]]></description><link>https://forum.magicmirror.builders/post/97710</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97710</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 22 Dec 2021 03:54:04 GMT</pubDate></item></channel></rss>
