<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My Bathroom Mirror]]></title><description><![CDATA[<p dir="auto">Last year i decided to start the project.<br />
Now its finished. Maybe some extra modules but …its finished.</p>
<p dir="auto">The goal was i big mirror in the bathroom. It should look like a regular mirror an no PIR e.g. in sight and the outer frame should not be visible. It also should have background lights as well! So lets start.</p>
<p dir="auto">I build a new frame, completly by myself. I did some woodwork in my workshop.!<br />
<img src="/assets/uploads/files/1640257032213-img_5982.jpeg" alt="IMG_5982.jpeg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1640257050571-108b81e9-db34-45fd-9f70-8b1574064145.jpg" alt="108B81E9-DB34-45FD-9F70-8B1574064145.jpg" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1640257054532-9f1f81fe-f74d-4158-9302-3700d424211a.jpg" alt="9F1F81FE-F74D-4158-9302-3700D424211A.jpg" class=" img-fluid img-markdown" /><br />
I createt with the saw a bevel to fit the LED-Stripe. I also have some experience with Hyperion… so i tought… okay… its  anice idea to use the leftover LEDs for this project (in the end… i had 3 LEDs over ;), 1872 pieces mountet).</p>
<p dir="auto"><img src="/assets/uploads/files/1640257260478-8d6d2958-dffd-4bfb-97f9-ad6a6641d0cb.jpg" alt="8D6D2958-DFFD-4BFB-97F9-AD6A6641D0CB.jpg" class=" img-fluid img-markdown" /><br />
Here you see the old mirror which was there for some time (i had this always in my mind). And do you see the Alexa? I didnt want to see Alexa anymore but want to hera the music.</p>
<p dir="auto">To mount it i decided to use a french cleat. Pretty easy to build, install and very reliable.<br />
<img src="/assets/uploads/files/1640257516045-img_6362.jpeg" alt="IMG_6362.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I didnt have nice Wifi… so i decided a few week ago to make some hole in the wall and install a LAN-cable and also a wall plug.<br />
<img src="/assets/uploads/files/1640258106368-img_9417.jpeg" alt="IMG_9417.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then go for the paint jobs. I tried different things. Paintbrush, paint roll and spray can. With the brush and roller i had a lot of blobs in the surface, so i used the spray can. Not perfect… i want that glossy surface. But as an amateur- its okay. The color is RAL 7016. Same color like the closet.<br />
<img src="/assets/uploads/files/1640257748044-img_6008.jpeg" alt="IMG_6008.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I mounted a plywood in it an cut the monitor out. You already see the hanger from the french cleat an the monitor - 27" QHD! On top of the plywood i placed black paperboard.<br />
<img src="/assets/uploads/files/1640257960050-img_6365.jpeg" alt="IMG_6365.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">First of all i brought for the mirror the Mirastar Chrome Spy. I was very brown and dark, so i brought an extra one from the forum from <a class="plugin-mentions-user plugin-mentions-a" href="/user/goldjunge_chriz" aria-label="Profile: Goldjunge_Chriz">@<bdi>Goldjunge_Chriz</bdi></a> . Its okay…but still a bit dark.</p>
<p dir="auto">Lets see the cables and stuff. Here is the nearly finished version. The cables für the LED-stripes are o the top.<img src="/assets/uploads/files/1640258346153-img_9417a.jpeg" alt="IMG_9417A.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">After a time testing with the MagicMirror Alexa i realized that it pretty hard to get the microfone in a good quality and als that its no longer possible to stream music to non Alexa-devices. So i 3Dprinted a mounting for the Echo Dot 3.</p>
<p dir="auto">The are 2 PSU- One 12V (the white one) for the Echo Dot to have a slim fit in back and also a 5V for the LED stripe and the Raspberry Pi4. I also added a StepUp converter to have stable 5v for the RPI to prevent errors. You also see the PIR-Sensor case. Created and 3D printed by myself.<br />
<img src="/assets/uploads/files/1640258631088-2b1409c4-76a9-4430-b742-fcac2f9bd5ef-image.png" alt="2b1409c4-76a9-4430-b742-fcac2f9bd5ef-image.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1640258665020-img_9525.jpeg" alt="IMG_9525.jpeg" class=" img-fluid img-markdown" /><br />
I also created a smal bracket to hold the RPI in place. But noch back-picture yet.</p>
<p dir="auto">I use the following modules with very small customisations:<br />
<img src="/assets/uploads/files/1640258805615-41783379-21b6-425e-a344-874d0a999d1c-image.png" alt="41783379-21b6-425e-a344-874d0a999d1c-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Tada! Here is the mirror:<br />
<img src="/assets/uploads/files/1640258969324-6c5a21fa-816b-495d-b760-97bcd23c4e82-image.png" alt="6c5a21fa-816b-495d-b760-97bcd23c4e82-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1640258874185-df9f21dc-da39-482e-9e99-dcb5bae66c2e-image.png" alt="df9f21dc-da39-482e-9e99-dcb5bae66c2e-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1640259324303-img_9523.jpeg" alt="IMG_9523.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1640259500381-img_9657.jpeg" alt="IMG_9657.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now to hyperion and smart home:<br />
I also have an ioBroker instace with MQTT.  I installed behind the regular double switch in the bathroom a Shelly in detached mode. So i get the information when the switch is pressed. The other switch is for the regular light. So i can switch the mirror on/of (MMM-Remote-Control) with the switch…and also the backlight goes on/off with a small effect.</p>
<p dir="auto">When the PIR is starting -&gt; MQTT-Message -&gt; Knight rider effect starts for 10 Seconds. Just for fun and because its possible ;)</p>
<p dir="auto"><img src="/assets/uploads/files/1640259527589-img_9644.jpeg" alt="IMG_9644.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Last but not least- when motion in the camera is detected- the videostream from MMM-Motioneye is displayed automatically for 1 minute (when i brush my teeth… i see before when the doorbell rings.</p>
<p dir="auto">I hope you like it. Feel free to ask.</p>
]]></description><link>https://forum.magicmirror.builders/topic/16073/my-bathroom-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 06 Sep 2026 23:52:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16073.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Dec 2021 11:40:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My Bathroom Mirror on Sun, 22 Oct 2023 06:59:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Youre right!</p>
]]></description><link>https://forum.magicmirror.builders/post/111922</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111922</guid><dc:creator><![CDATA[OberfragGER]]></dc:creator><pubDate>Sun, 22 Oct 2023 06:59:51 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Sun, 15 Oct 2023 10:08:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sil3ntstorm" aria-label="Profile: sil3ntstorm">@<bdi>sil3ntstorm</bdi></a> That should be MMM-OpenWeatherForecast<br />
<a href="https://github.com/jclarke0000/MMM-OpenWeatherForecast" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jclarke0000/MMM-OpenWeatherForecast</a></p>
]]></description><link>https://forum.magicmirror.builders/post/111755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111755</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Sun, 15 Oct 2023 10:08:32 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Sun, 15 Oct 2023 06:53:20 GMT]]></title><description><![CDATA[<p dir="auto">at the top right, is that one weather module or two? And what are these called exactly? Could you post the config entry here?</p>
]]></description><link>https://forum.magicmirror.builders/post/111749</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/111749</guid><dc:creator><![CDATA[sil3ntstorm]]></dc:creator><pubDate>Sun, 15 Oct 2023 06:53:20 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Wed, 12 Jan 2022 06:23:56 GMT]]></title><description><![CDATA[<p dir="auto">Just a stunning mirror. Genuinely emotional over how brilliant this looks. I really like it and  can try to do the same.</p>
]]></description><link>https://forum.magicmirror.builders/post/98423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98423</guid><dc:creator><![CDATA[bigschucks]]></dc:creator><pubDate>Wed, 12 Jan 2022 06:23:56 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Wed, 29 Dec 2021 12:34:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oberfragger" aria-label="Profile: oberfragger">@<bdi>oberfragger</bdi></a> Congrats to your wonderful built! It’s very impressive how much effort you put into that! Wished I had knew a few years earlier about MM…that would have saved me lots of discussion with my better half about which mirror should have been installed in our new bathroom. :grinning_face_with_sweat:</p>
]]></description><link>https://forum.magicmirror.builders/post/97857</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97857</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Wed, 29 Dec 2021 12:34:47 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Mon, 27 Dec 2021 14:04:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/digidadbod" aria-label="Profile: digidadbod">@<bdi>digidadbod</bdi></a> We dont have any fog inside the bathroom. Only the window gets foggy sometimes.<br />
The bathroom is always warm enoug and so the mirror too. We have floor heating. Maybei thats why…</p>
]]></description><link>https://forum.magicmirror.builders/post/97803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97803</guid><dc:creator><![CDATA[OberfragGER]]></dc:creator><pubDate>Mon, 27 Dec 2021 14:04:38 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Sun, 26 Dec 2021 16:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oberfragger" aria-label="Profile: oberfragger">@<bdi>oberfragger</bdi></a> nice. So can you read everything when it gets fogged up?</p>
]]></description><link>https://forum.magicmirror.builders/post/97792</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97792</guid><dc:creator><![CDATA[DigiDadbod]]></dc:creator><pubDate>Sun, 26 Dec 2021 16:45:24 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Sun, 26 Dec 2021 14:39:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kusselin" aria-label="Profile: kusselin">@<bdi>kusselin</bdi></a> sure. My MMM_page config:</p>
<pre><code>    {
      module: 'MMM-pages',
      disabled: false,
            'newsfeed',
            'MMM-OpenWeatherForecast',
            'calendar',
            'calendar_monthly',
            'MMM-WiFiPassword'
            'compliments',
            'MMM-Globe',
            'MMM-DWD-Pollen',
            'MMM-DWD-WarnWeather',
            'MMM-WeatherChart',
            'MMM-OpenmapWeather',
			'MMM-SystemStats',
            'weatherforecast',
        fixed: [
          'updatenotification',
          'MMM-page-indicator',
          'alert',
          'clock',
          'MMM-MotionEye',
		  'MMM-GoogleBirthdaysProvider',
		  'MMM-NewPIR',
		  'MMM-UserPresenceToMQTT',
          'MMM-Remote-Control'
        animationTime: 2500,
        rotationTime: 60000
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stoffbeuteluwe" aria-label="Profile: Stoffbeuteluwe">@<bdi>Stoffbeuteluwe</bdi></a> Yes. It updates. But i use pages do i have a refresh every 2 minutes. Maybe thats the key</p>
]]></description><link>https://forum.magicmirror.builders/post/97791</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97791</guid><dc:creator><![CDATA[OberfragGER]]></dc:creator><pubDate>Sun, 26 Dec 2021 14:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Sun, 26 Dec 2021 10:09:48 GMT]]></title><description><![CDATA[<p dir="auto">Pretty cool.</p>
<p dir="auto">I am working on a similar bath mirror project and will definitely test some of the modules you are using.</p>
<p dir="auto">Maybe for some inspiration here are the modules I am currently using besides clock, calendar and newsfeed:</p>
<p dir="auto">MMM-pages<br />
MMM-UpdateNotification<br />
MMM-TelegramBot<br />
MMM-Volume<br />
MMM-Tools<br />
MMM-Detector<br />
MMM-GoogleAssistant<br />
MMM-DWD-WarnWeather<br />
MMM-MplayerRadio<br />
MMM-DarkSkyForecast<br />
MMM-DWD-Pollen<br />
MMM-bergfex<br />
MMM-GroveGestures</p>
]]></description><link>https://forum.magicmirror.builders/post/97786</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97786</guid><dc:creator><![CDATA[lxne]]></dc:creator><pubDate>Sun, 26 Dec 2021 10:09:48 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Sat, 25 Dec 2021 06:06:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi does the Globe update …for me the module does not update automatically only when I restart the mirror .</p>
]]></description><link>https://forum.magicmirror.builders/post/97774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97774</guid><dc:creator><![CDATA[Stoffbeuteluwe]]></dc:creator><pubDate>Sat, 25 Dec 2021 06:06:31 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Fri, 24 Dec 2021 12:54:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi, can you put here the config from your mmm-pages please.</p>
]]></description><link>https://forum.magicmirror.builders/post/97766</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97766</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Fri, 24 Dec 2021 12:54:20 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Fri, 24 Dec 2021 11:08:02 GMT]]></title><description><![CDATA[<p dir="auto">Nice, looks good</p>
]]></description><link>https://forum.magicmirror.builders/post/97763</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97763</guid><dc:creator><![CDATA[Zoltan]]></dc:creator><pubDate>Fri, 24 Dec 2021 11:08:02 GMT</pubDate></item><item><title><![CDATA[Reply to My Bathroom Mirror on Thu, 23 Dec 2021 21:41:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oberfragger" aria-label="Profile: oberfragger">@<bdi>oberfragger</bdi></a> I think it looks great… nice job… well done…</p>
]]></description><link>https://forum.magicmirror.builders/post/97759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97759</guid><dc:creator><![CDATA[N6NG]]></dc:creator><pubDate>Thu, 23 Dec 2021 21:41:50 GMT</pubDate></item></channel></rss>
