<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Carousel w&#x2F; Slide Navigation]]></title><description><![CDATA[<p dir="auto">Hi all, I installed the MMM-Carousel w/ Slide Navigation module…but now it doesn’t show me the “Slides”…here’s my config:</p>
<pre><code>{
            module: 'MMM-Carousel',
                transitionInterval: 45000,
                showPageIndicators: true,
                showPageControls: true,
                ignoreModules: ['clock', 'alert', 'calendar', 'MMM-Fuel', 'MMM-OpenmapWeather', 'weatherforecast', 'newsfeed', 'compliments', 'MMM-Tools', 'MMM-Traffic'],
                mode: 'slides',
                slides: {
                    main: ['calendar', 'compliments', 'currentweather'],
                    "Slide 2": ['MMM-PublicTransportHafas', 'MMM-Formula1'],
                    "Slide 3": ['MMM-COVID19-AMPEL', 'MMM-Tankerkoenig', 'MMM-ioBroker', 'MMM-SoccerLiveScore']
<p dir="auto">Can you please explain what I am doing wrong?</p>
<p dir="auto">I only have a small display and I just want to be able to display the other modules one after the other with the slides.</p>
<p dir="auto">About eien feedback thank you very much.</p>
<p dir="auto">Greetings</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm run config:check
&gt; magicmirror@2.17.1 config:check /home/pi/MagicMirror
&gt; node js/check_config.js
[23.12.2021 15:16.43.363] [INFO]  Checking file...  /home/pi/MagicMirror/config/config.js
[23.12.2021 15:16.43.969] [INFO]  Your configuration file doesn't contain syntax errors :)
]]></description><link>https://forum.magicmirror.builders/topic/16075/mmm-carousel-w-slide-navigation</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 10:46:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16075.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 23 Dec 2021 13:49:10 GMT</pubDate><ttl>60</ttl></channel></rss>
