<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[v2.18.0]]></title><description><![CDATA[<h2>[2.18.0] - 2022-01-01</h2>
<p dir="auto">Special thanks to the following contributors: <a class="plugin-mentions-user plugin-mentions-a" href="/user/ampiorosso" aria-label="Profile: AmpioRosso">@<bdi>AmpioRosso</bdi></a>, @eouia, @fewieden, @jupadin, @khassel, <a class="plugin-mentions-user plugin-mentions-a" href="/user/kolbyjack" aria-label="Profile: kolbyjack">@<bdi>kolbyjack</bdi></a>, <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a>, @MariusVaice, <a class="plugin-mentions-user plugin-mentions-a" href="/user/rejas" aria-label="Profile: rejas">@<bdi>rejas</bdi></a>, <a class="plugin-mentions-user plugin-mentions-a" href="/user/rico24" aria-label="Profile: rico24">@<bdi>rico24</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>.</p>
<h3>Added</h3>
<ul>
<li>Added test for calendar recurring event with checks the correct date displayed (related to #2752).</li>
</ul>
<h3>Updated</h3>
<ul>
<li>ESLint version supports now ECMAScript 2018.</li>
<li>Cleaned up <code>updatenotification</code> module and switched to nunjuck template.</li>
<li>Moved calendar tests from category <code>electron</code> to <code>e2e</code>.</li>
<li>Update missed translations for Korean language (ko.json).</li>
<li>Update missed translations for Dutch language (nl.json).</li>
<li>Cleaned up <code>alert</code> module and switched to nunjuck template.</li>
<li>Moved weather tests from category <code>electron</code> to <code>e2e</code>.</li>
<li>Updated github actions.</li>
<li>Replace spectron with playwright, update dependencies including electron update to v16.</li>
<li>Added lithuanian language to translations.js.</li>
<li>Show info message if newsfeed is empty (fixes #2731).</li>
<li>Added dangerouslyDisableAutoEscaping config option for newsfeed templates (fixes #2712).</li>
<li>Added missing shebang to <code>installers/mm.sh</code>.</li>
<li>Node versions in templates and github workflows.</li>
</ul>
<h3>Fixed</h3>
<ul>
<li>Fixed wrong file <code>kr.json</code> to <code>ko.json</code>. Use language code ‘ko’ instead of ‘kr’ for Korean language.</li>
<li>Fixed <code>feels_like</code> data from openweathermaps current weather being ignored (#2678).</li>
<li>Fixed chaotic newsfeed display after network connection loss thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/jalibu" aria-label="Profile: jalibu">@<bdi>jalibu</bdi></a> (#2638).</li>
<li>Fixed incorrect time zone correction of recurring full day events (#2632 and #2634).</li>
<li>Fixed e2e tests by increasing testTimeout.</li>
<li>Revert node-ical update due to missing luxon package.</li>
<li>Fixed User-Agent-Header for newsfeed and calendar module (#2729).</li>
<li>Replace broken shields in Readme and use https for links.</li>
<li>Fixed electron tests with retry.</li>
<li>Fixed Calendar recurring cross timezone error (add/subtract a day, not just offset hours) (#2632).</li>
<li>Fixed Calendar showEnd and Full Date overlay (#2629).</li>
<li>Fixed regression on #2632, #2752.</li>
<li>Broadcast custom symbols in CALENDAR_EVENTS.</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/16116/v2-18-0</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 14:58:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16116.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Jan 2022 18:42:34 GMT</pubDate><ttl>60</ttl></channel></rss>
