<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with MYCalendar Module]]></title><description><![CDATA[<p dir="auto">Hello everyone, since I set up my MM again, my MyCalendar module no longer works, no matter what I do, the screen stays black (you only see a mouse pointer). I copied the data for it from the config.js (which I used earlier). If the MyCalendar module is deactivated, everything goes as normal<br />
Command npm run config: check says: Your configuration file doesn’t contain syntax errors 🙂 so no error is shown to me here.<br />
Does anyone else have the problem with the MyCalendar module?</p>
<p dir="auto"><a href="https://github.com/jclarke0000/MMM-MyCalendar" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jclarke0000/MMM-MyCalendar</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/16117/problem-with-mycalendar-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Apr 2026 04:59:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16117.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 01 Jan 2022 20:08:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with MYCalendar Module on Sun, 06 Feb 2022 16:14:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sil3ntstorm" aria-label="Profile: sil3ntstorm">@<bdi>sil3ntstorm</bdi></a> yes<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
<p dir="auto">u can install multiple things at once if u know</p>
<p dir="auto">npm install x y</p>
]]></description><link>https://forum.magicmirror.builders/post/99384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99384</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 06 Feb 2022 16:14:50 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MYCalendar Module on Sun, 06 Feb 2022 16:12:48 GMT]]></title><description><![CDATA[<p dir="auto">solution: But for it to work properly, I still had to run npm install request and npm install valid-url These were removed in the last MagicMirror updates. Now works :thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/99382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99382</guid><dc:creator><![CDATA[sil3ntstorm]]></dc:creator><pubDate>Sun, 06 Feb 2022 16:12:48 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MYCalendar Module on Mon, 03 Jan 2022 12:22:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sil3ntstorm" aria-label="Profile: sil3ntstorm">@<bdi>sil3ntstorm</bdi></a> no. it needs a library which we removed a couple releases ago. the library uses a library that is discontinued (deprecated) due to a security issue</p>
<p dir="auto">just follow the instructions in the linked topic and u can fix it.</p>
]]></description><link>https://forum.magicmirror.builders/post/98013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98013</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 03 Jan 2022 12:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MYCalendar Module on Mon, 03 Jan 2022 09:16:00 GMT]]></title><description><![CDATA[<p dir="auto">It looks like this module is not compatible with MM 2.18. Older versions will work with it, but the latest will no longer work. I have now switched to the standard module</p>
]]></description><link>https://forum.magicmirror.builders/post/98009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98009</guid><dc:creator><![CDATA[sil3ntstorm]]></dc:creator><pubDate>Mon, 03 Jan 2022 09:16:00 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MYCalendar Module on Sun, 02 Jan 2022 13:26:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sil3ntstorm" aria-label="Profile: sil3ntstorm">@<bdi>sil3ntstorm</bdi></a> the linked topic shows u how to discover the cause of the black screen and how to fix it</p>
]]></description><link>https://forum.magicmirror.builders/post/97954</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97954</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Jan 2022 13:26:58 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MYCalendar Module on Sun, 02 Jan 2022 09:52:14 GMT]]></title><description><![CDATA[<p dir="auto">I don’t understand exactly how to proceed.</p>
<p dir="auto">Or are there other modules that show my calendar like this</p>
<p dir="auto"><img src="/assets/uploads/files/1641117128032-8caa1f34-2eac-4af2-a8a2-0a15b7031d0d-image.png" alt="8caa1f34-2eac-4af2-a8a2-0a15b7031d0d-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/97947</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97947</guid><dc:creator><![CDATA[sil3ntstorm]]></dc:creator><pubDate>Sun, 02 Jan 2022 09:52:14 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with MYCalendar Module on Sat, 01 Jan 2022 21:24:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sil3ntstorm" aria-label="Profile: sil3ntstorm">@<bdi>sil3ntstorm</bdi></a></p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/97940</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97940</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 01 Jan 2022 21:24:51 GMT</pubDate></item></channel></rss>
