<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-RING Issue]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Currently got a MagicMirror running on an original Pi Zero and have added MMM-RING but nothing shows.</p>
<p dir="auto">This is the error section of the log…</p>
<p dir="auto">0|mmstart  | [07.12.2021 20:06.15.750] [ERROR] (node:520) ExperimentalWarning: Readable[Symbol.asyncIterator] is an experimental feature. This feature could change at any time<br />
0|mmstart  | [07.12.2021 20:06.24.291] [ERROR] (node:520) UnhandledPromiseReject                             ionWarning: HTTPError: Response code 500 (Internal Server Error)<br />
0|mmstart  |     at Request.request.once (/home/pi/MagicMirror/modules/MMM-Ring/                             node_modules/got/dist/source/as-promise/index.js:117:42)<br />
0|mmstart  |     at process._tickCallback (internal/process/next_tick.js:68:7)<br />
0|mmstart  | [07.12.2021 20:06.24.299] [ERROR] (node:520) UnhandledPromiseReject                             ionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)</p>
<p dir="auto">Can anyone help - I could post more logs if necessary but generally seems that it’s working i.e. it’s renewing the token etc.  I’m wondering if it’s just that the Zero isn’t handling it and needs to be upgraded to a better Raspberry model?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/16121/mmm-ring-issue</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 04:43:51 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16121.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Jan 2022 11:55:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-RING Issue on Sun, 02 Jan 2022 13:42:25 GMT]]></title><description><![CDATA[<p dir="auto">@black-patina I would open an issue on the module GitHub page.</p>
<p dir="auto">but it says deprecated ( discontinued)</p>
]]></description><link>https://forum.magicmirror.builders/post/97956</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/97956</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Jan 2022 13:42:25 GMT</pubDate></item></channel></rss>
