<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-OralB / Bluetooth equipped toothbrush integration]]></title><description><![CDATA[<p dir="auto">Hey, this topic should continue the development of the MMM-OralB module, to integrate the OralB - Bluetooth equipped toothbrushes.<br />
It already started <a href="https://forum.magicmirror.builders/topic/1263/toothbrush-integration">here</a> as a request and changed to a develop specific topic.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1615/mmm-oralb-bluetooth-equipped-toothbrush-integration</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 01:22:34 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1615.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Jan 2017 19:24:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Fri, 21 May 2021 07:51:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oberfragger" aria-label="Profile: oberfragger">@<bdi>oberfragger</bdi></a><br />
Actually the better module currently to work with the toothbrush is <a href="https://github.com/timodejong95/MMM-BluetoothDevices" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-BluetoothDevices</a><br />
I think I have that working.</p>
<p dir="auto">However, pairing is necessary.</p>
<p dir="auto">At which point are you failing, what description have you used?</p>
]]></description><link>https://forum.magicmirror.builders/post/91541</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91541</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 21 May 2021 07:51:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Tue, 18 May 2021 21:35:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> No pairing possible. Maybe my Toothbrush is too new? Oral-B Genius 9000.</p>
<p dir="auto">Do i have to “click” something on the toothbrush to pair? Its already paired with the app.</p>
]]></description><link>https://forum.magicmirror.builders/post/91510</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91510</guid><dc:creator><![CDATA[OberfragGER]]></dc:creator><pubDate>Tue, 18 May 2021 21:35:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Tue, 11 May 2021 21:11:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oberfragger" aria-label="Profile: oberfragger">@<bdi>oberfragger</bdi></a> yeah I had this running.<br />
Might retry these days.</p>
<p dir="auto">You need to pair the toothbrush with your RasPi. If that didn’t work the module itself probably won’t work.</p>
<p dir="auto">Where did it fail?</p>
]]></description><link>https://forum.magicmirror.builders/post/91410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91410</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Tue, 11 May 2021 21:11:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Mon, 10 May 2021 22:27:40 GMT]]></title><description><![CDATA[<p dir="auto">Did anyone got this running.</p>
<p dir="auto">I have tested on MM2 - 2.14 and 2.15. No sucess.<br />
Just the Time runs…</p>
<p dir="auto">Do i have to do anything special like pairing the toothbrush (not possible, pairing nit sucessful).</p>
<p dir="auto">Im using RPI4 with BT build in.</p>
]]></description><link>https://forum.magicmirror.builders/post/91381</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/91381</guid><dc:creator><![CDATA[OberfragGER]]></dc:creator><pubDate>Mon, 10 May 2021 22:27:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Mon, 27 Apr 2020 08:37:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Nice, yeah thats still a thing. I thought it was the way it connects, but the devices automatically disconnects after 20-30 seconds. When disconnected its not able to get the battery status. So what I build that if the devices is disconnected at the first 5 seconds of brushing it’s going to reconnect (1 try). If that succeeds it gets the battery value. If not well, then sadly not.</p>
<p dir="auto">I haven’t figured out a solution to keep it connected throughout the whole session or just forever. My guess is, the brush might expect data to be send to keep the connection active/alive.</p>
<p dir="auto">In the logs I see that the reconnection has failed, do you got that every session? Else I might increase the reconnection attempts to 2.</p>
]]></description><link>https://forum.magicmirror.builders/post/73643</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73643</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Mon, 27 Apr 2020 08:37:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Sat, 25 Apr 2020 22:22:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a> IT WORKED! At least partially, that is.</p>
<pre><code>0|mm  | 00:13:17 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:17.988] [LOG]
0|mm  | 00:13:17 &lt;info&gt; MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
0|mm  | [2020-04-26 00:13:17.995] [LOG]
0|mm  | 00:13:17 &lt;log&gt; MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:21.469] [LOG]
0|mm  | 00:13:21 &lt;log&gt; MMM-BluetoothDevices connected to device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:21.534] [LOG]
0|mm  | 00:13:21 &lt;log&gt; MMM-BluetoothDevices awaiting services for device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
0|mm  | [2020-04-26 00:13:21.552] [LOG]    00:13:21 &lt;log&gt; MMM-BluetoothDevices waiting for services to be resolved for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
0|mm  | [2020-04-26 00:13:29.503] [LOG]
0|mm  | 00:13:29 &lt;log&gt; MMM-BluetoothDevices connected to: DIRKS OralB after 1 try (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:29.961] [LOG]
0|mm  | 00:13:29 &lt;log&gt; MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
0|mm  | [2020-04-26 00:13:29.966] [LOG]    00:13:29 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:29.979] [LOG]    00:13:29 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:30.255] [LOG]
0|mm  | 00:13:30 &lt;log&gt; MMM-BluetoothDevices battery updated to: 100% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
0|mm  | [2020-04-26 00:13:30.259] [LOG]    00:13:30 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:31.229] [LOG]
0|mm  | 00:13:31 &lt;log&gt; MMM-BluetoothDevices battery updated to: 99% for: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
0|mm  | [2020-04-26 00:13:31.234] [LOG]    00:13:31 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:31.466] [LOG]
0|mm  | 00:13:31 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:31.520] [LOG]
0|mm  | 00:13:31 &lt;log&gt; MMM-BluetoothDevices connection lost with device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:33.303] [LOG]
0|mm  | 00:13:33 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:33.315] [LOG]
0|mm  | 00:13:33 &lt;info&gt; MMM-BluetoothDevices reconnecting to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
0|mm  | [2020-04-26 00:13:33.318] [LOG]    00:13:33 &lt;log&gt; MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/1 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:43.919] [LOG]
0|mm  | 00:13:43 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:13:54.916] [LOG]
0|mm  | 00:13:54 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:14:05.881] [LOG]
0|mm  | 00:14:05 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:14:13.884] [LOG]
0|mm  | 00:14:13 &lt;info&gt; MMM-BluetoothDevices failed to reconnect to: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:24 Logger.info)
0|mm  | [2020-04-26 00:14:13.886] [LOG]    00:14:13 &lt;log&gt; MMM-BluetoothDevices Error: Error: Couldn't connect to DIRKS OralB after 1 try. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
0|mm  | [2020-04-26 00:14:16.957] [LOG]
0|mm  | 00:14:16 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:14:28.049] [LOG]
0|mm  | 00:14:28 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:14:38.869] [LOG]
0|mm  | 00:14:38 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:14:49.968] [LOG]
0|mm  | 00:14:49 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:15:00.855] [LOG]
0|mm  | 00:15:00 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:15:12.156] [LOG]
0|mm  | 00:15:12 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:15:22.928] [LOG]
0|mm  | 00:15:22 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
0|mm  | [2020-04-26 00:15:33.865] [LOG]
0|mm  | 00:15:33 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
<p dir="auto">Battery updates are there but only in the beginning.<br />
I would assume my battery drains more than this one percent in 2 minutes but may be wrong.<br />
Nothing displayed on the mirror.<br />
Might still be missing?</p>
]]></description><link>https://forum.magicmirror.builders/post/73575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73575</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Sat, 25 Apr 2020 22:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Sat, 25 Apr 2020 14:24:45 GMT]]></title><description><![CDATA[<p dir="auto">I have just pushed some new changes which improve connecting, and a few tests cases for device connection. It requires a <code>npm install</code>.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/djerik" aria-label="Profile: djerik">@<bdi>djerik</bdi></a>  if you have some time could you try it out? Also I though you already had it on but if not it might be handy to enable <code>debugLogs</code>.</p>
<p dir="auto">Also I want to thank you for the time you put into this and help me by providing logs and errors so I can improve the module.</p>
]]></description><link>https://forum.magicmirror.builders/post/73547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73547</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Sat, 25 Apr 2020 14:24:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Thu, 23 Apr 2020 11:39:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Oké check, well no need to try again tonight because your up-to-date then. I will let you know when I have looked at it. For now you can prevent the errors by removing the battery in the tracks array.</p>
]]></description><link>https://forum.magicmirror.builders/post/73377</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73377</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Thu, 23 Apr 2020 11:39:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Thu, 23 Apr 2020 10:40:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a> said in <a href="/post/73374">MMM-OralB / Bluetooth equipped toothbrush integration</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Check I get you. Just to be sure, you did do <code>npm install</code> I changed a package? If not then I will comeback to it when I have tested it myself.</p>
<p dir="auto">Yes I did.<br />
Did it now again (but no new installations) and trying again tonight</p>
]]></description><link>https://forum.magicmirror.builders/post/73375</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73375</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 23 Apr 2020 10:40:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Thu, 23 Apr 2020 10:38:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Check I get you. Just to be sure, you did do <code>npm install</code> I changed a package? If not then I will comeback to it when I have tested it myself.</p>
]]></description><link>https://forum.magicmirror.builders/post/73374</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73374</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Thu, 23 Apr 2020 10:38:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Thu, 23 Apr 2020 10:27:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a> said in <a href="/post/73370">MMM-OralB / Bluetooth equipped toothbrush integration</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> No worries, check I will have a look at this when I find some time, probably this weekend. Seems that the devices couldn’t connect at the first try but failed in de second which is triggered instantly.</p>
<p dir="auto">I don’t have a problem with that. Devices are connecting well as soon as I activate them. Everything works really well except no battery status shown.<br />
Apparently the waitForService process ends unresolved, hence is not able to get the information from the battery service</p>
<pre><code>[2020-04-23 00:52:33.875] [ERROR]  00:52:33  MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
]]></description><link>https://forum.magicmirror.builders/post/73373</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73373</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Thu, 23 Apr 2020 10:27:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Thu, 23 Apr 2020 10:15:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> No worries, check I will have a look at this when I find some time, probably this weekend. Seems that the devices couldn’t connect at the first try but failed in de second which is triggered instantly.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djerik" aria-label="Profile: djerik">@<bdi>djerik</bdi></a> Thanks for sharing</p>
<p dir="auto">I will try and fix the issues you send to be, thanks for sharing and excuses for the bugs! I might write some tests because the manual tests are stacking up and code coverage is always good.</p>
]]></description><link>https://forum.magicmirror.builders/post/73370</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73370</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Thu, 23 Apr 2020 10:15:26 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Wed, 22 Apr 2020 22:55:16 GMT]]></title><description><![CDATA[<p dir="auto">and more debugging messages, sorry for the spamming:</p>
<pre><code>[2020-04-23 00:51:53.902] [LOG]    00:51:53 &lt;log&gt; MMM-BluetoothDevices starting hub (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_helper.js:23 Class.startHub)
[2020-04-23 00:51:58.845] [LOG]    00:51:58 &lt;log&gt; MMM-BluetoothDevices unhandled adapter msg: {"serial":1536,"path":"/org/bluez/hci0","interface":"org.freedesktop.DBus.Properties","member":"PropertiesChanged","signature":"sa{sv}as","sender":":1.8","type":4,"flags":1,"body":["org.bluez.Adapter1",[["UUIDs",[[{"type":"a","child":[{"type":"s","child":[]}]}],[["00001112-0000-1000-8000-00805f9b34fb","00001801-0000-1000-8000-00805f9b34fb","0000110e-0000-1000-8000-00805f9b34fb","00001800-0000-1000-8000-00805f9b34fb","00001200-0000-1000-8000-00805f9b34fb","0000110c-0000-1000-8000-00805f9b34fb","0000110a-0000-1000-8000-00805f9b34fb","0000111f-0000-1000-8000-00805f9b34fb","00001805-0000-1000-8000-00805f9b34fb"]]]]],[]]} (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
[2020-04-23 00:52:01.474] [LOG]    00:52:01 &lt;log&gt; MMM-BluetoothDevices unhandled adapter msg: {"serial":1542,"path":"/org/bluez/hci0","interface":"org.freedesktop.DBus.Properties","member":"PropertiesChanged","signature":"sa{sv}as","sender":":1.8","type":4,"flags":1,"body":["org.bluez.Adapter1",[["Discovering",[[{"type":"b","child":[]}],[true]]]],[]]} (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
[2020-04-23 00:52:01.993] [LOG]    00:52:01 &lt;log&gt; MMM-BluetoothDevices trying to connect to: DIRKS OralB 1/2 (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:52:13.667] [LOG]    00:52:13 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:52:13.834] [LOG]    00:52:13 &lt;log&gt; MMM-BluetoothDevices awaiting services for device: DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:32 Logger.debug)
[2020-04-23 00:52:17.445] [LOG]    00:52:17 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:52:23.028] [LOG]    00:52:23 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:52:33.871] [ERROR]  00:52:33 &lt;error&gt; MMM-BluetoothDevices unhandled exception: (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
[2020-04-23 00:52:33.875] [ERROR]  00:52:33 &lt;error&gt; MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
[2020-04-23 00:52:33.905] [LOG]    00:52:33 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:52:44.875] [LOG]    00:52:44 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:52:55.859] [LOG]    00:52:55 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:53:06.911] [LOG]    00:53:06 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:53:17.884] [LOG]    00:53:17 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:53:28.849] [LOG]    00:53:28 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
]]></description><link>https://forum.magicmirror.builders/post/73350</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73350</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 22 Apr 2020 22:55:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Wed, 22 Apr 2020 22:41:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a><br />
<a href="https://makandracards.com/makandra/28847-dealing-with-typeerror-converting-circular-structure-to-json-on-javascript" target="_blank" rel="noopener noreferrer nofollow ugc">https://makandracards.com/makandra/28847-dealing-with-typeerror-converting-circular-structure-to-json-on-javascript</a></p>
]]></description><link>https://forum.magicmirror.builders/post/73345</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73345</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 22 Apr 2020 22:41:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Wed, 22 Apr 2020 22:40:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a> there are no logs above that.<br />
I get this error before I started the brush</p>
<pre><code>[2020-04-23 00:19:17.258] [ERROR]  00:19:17 &lt;error&gt; MMM-BluetoothDevices unhandled exception: (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
[2020-04-23 00:19:17.263] [ERROR]  00:19:17 &lt;error&gt; MMM-BluetoothDevices Error: Error: Couldn't connect to BABSIS OralB after 2 tries. (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:47 Logger.error)
[2020-04-23 00:19:17.277] [ERROR]  00:19:17 &lt;error&gt; (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
    --&gt; starting at object with constructor 'DBusObject'
    |     property 'proxy' -&gt; object with constructor 'Object'
    |     property 'org.freedesktop.DBus.Introspectable' -&gt; object with constructor 'DBusInterface'
    --- property '$parent' closes the circle
    at JSON.stringify (&lt;anonymous&gt;)
    at /home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/index.js:24:25
    at processTicksAndRejections (internal/process/task_queues.js:89:5) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:19:17.284] [ERROR]  00:19:17 &lt;error&gt; (node:2929) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
[2020-04-23 00:19:17.289] [ERROR]  00:19:17 &lt;error&gt; (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:19:17.293] [ERROR]  00:19:17 &lt;error&gt; (node:2929) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:19:17.296] [ERROR]  00:19:17 &lt;error&gt; (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:19:17.299] [ERROR]  00:19:17 &lt;error&gt; (node:2929) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:23:44.731] [LOG]    00:23:44 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:23:47.096] [LOG]    00:23:47 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:23:57.944] [LOG]    00:23:57 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:24:08.935] [LOG]    00:24:08 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:24:19.917] [LOG]    00:24:19 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:24:30.925] [LOG]    00:24:30 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:24:41.961] [LOG]    00:24:41 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:24:52.927] [LOG]    00:24:52 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:25:03.965] [LOG]    00:25:03 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:25:14.860] [LOG]    00:25:14 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:25:25.926] [LOG]    00:25:25 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:25:36.875] [LOG]    00:25:36 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:25:47.877] [LOG]    00:25:47 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
[2020-04-23 00:25:58.907] [LOG]    00:25:58 &lt;log&gt; MMM-BluetoothDevices received device update for DIRKS OralB (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Logger.js:17 Logger.log)
<p dir="auto">This error vanishes when I deactivate the JSON.stringify function.<br />
I have the feeling that everything is working, but the battery is not showing up at all.</p>
<p dir="auto">Also, when closing the mirror (ctrl+c when I started it with <code>npm start dev </code>) I get these errors:</p>
<pre><code>[2020-04-23 00:38:03.482] [ERROR]  00:38:03 &lt;error&gt; (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
    at Dongle.disconnectDevices (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:223:28)
    at Dongle.destroy (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/Dongle.js:58:17)
    at Class.stop (/home/pi/MagicMirror/modules/MMM-BluetoothDevices/node_helper.js:46:23)
    at App.stop (/home/pi/MagicMirror/js/app.js:252:16)
    at App.&lt;anonymous&gt; (/home/pi/MagicMirror/js/electron.js:108:7)
    at App.emit (events.js:200:13) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:38:03.486] [ERROR]  00:38:03 &lt;error&gt; (node:4615) UnhandledPromiseRejectionWarning: TypeError: device.destroy is not a function
[2020-04-23 00:38:03.489] [ERROR]  00:38:03 &lt;error&gt; (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:38:03.495] [ERROR]  00:38:03 &lt;error&gt; (node:4615) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 4) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:38:03.503] [ERROR]  00:38:03 &lt;error&gt; (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
[2020-04-23 00:38:03.509] [ERROR]  00:38:03 &lt;error&gt; (node:4615) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
]]></description><link>https://forum.magicmirror.builders/post/73344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73344</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Wed, 22 Apr 2020 22:40:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Wed, 22 Apr 2020 17:44:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a><br />
I have removed the module, installed again and added the extra piece of configuration. The updated UI is working fine, but there is no battery indicator. Is this the log you are looking for?</p>
<p dir="auto">[2020-04-22 19:40:43.278] [LOG]    MMM-BluetoothDevices received device update for OralB<br />
[2020-04-22 19:40:43.389] [LOG]    MMM-BluetoothDevices trying to connect to: OralB 1/2<br />
[2020-04-22 19:40:53.451] [LOG]    MMM-BluetoothDevices received device update for OralB<br />
[2020-04-22 19:40:53.673] [LOG]    MMM-BluetoothDevices trying to connect to: OralB 2/2<br />
[2020-04-22 19:40:59.444] [LOG]    MMM-BluetoothDevices received device update for OralB<br />
[2020-04-22 19:41:10.482] [LOG]    MMM-BluetoothDevices received device update for OralB<br />
[2020-04-22 19:41:13.767] [ERROR]  MMM-BluetoothDevices unhandled exception:<br />
[2020-04-22 19:41:13.771] [ERROR]  MMM-BluetoothDevices Error: Error: waitForServicesResolved: timeout exceeded<br />
[2020-04-22 19:41:13.774] [ERROR]  MMM-BluetoothDevices {“troubleshooting”:“devices#resolve-services”,“extra”:{}}<br />
[2020-04-22 19:41:21.451] [LOG]    MMM-BluetoothDevices received device update for OralB<br />
[2020-04-22 19:41:32.477] [LOG]    MMM-BluetoothDevices received device update for OralB<br />
[2020-04-22 19:41:43.546] [LOG]    MMM-BluetoothDevices received device update for OralB<br />
[2020-04-22 19:41:54.482] [LOG]    MMM-BluetoothDevices received device update for OralB</p>
]]></description><link>https://forum.magicmirror.builders/post/73328</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73328</guid><dc:creator><![CDATA[djerik]]></dc:creator><pubDate>Wed, 22 Apr 2020 17:44:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Mon, 20 Apr 2020 09:42:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Damm ashame, could you post the logs above the error? If correct there should be 2 more error logs, and just to be sure it still works when you remove the battery track, right?</p>
]]></description><link>https://forum.magicmirror.builders/post/73120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73120</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Mon, 20 Apr 2020 09:42:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Mon, 20 Apr 2020 08:09:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a> No luck yet.<br />
No Battery status to be seen and this error in the logs</p>
<pre><code>0|mm       | [2020-04-20 01:21:08.432] [ERROR]  01:21:08 &lt;error&gt; (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
0|mm       |     --&gt; starting at object with constructor 'DBusObject'
0|mm       |     |     property 'proxy' -&gt; object with constructor 'Object'
0|mm       |     |     property 'org.freedesktop.DBus.Introspectable' -&gt; object with constructor 'DBusInterface'
0|mm       |     --- property '$parent' closes the circle
0|mm       |     at JSON.stringify (&lt;anonymous&gt;)
0|mm       |     at /home/pi/MagicMirror/modules/MMM-BluetoothDevices/src/index.js:24:25
0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:89:5) (/home/pi/MagicMirror/internal/process/warning.js:27 writeOut)
0|mm       | [2020-04-20 01:21:08.435] [ERROR]  01:21:08 &lt;error&gt; (node:23220) UnhandledPromiseRejectionWarning: TypeError: Converting circular structure to JSON
]]></description><link>https://forum.magicmirror.builders/post/73117</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73117</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Mon, 20 Apr 2020 08:09:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Sun, 19 Apr 2020 19:10:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Oke I have pushed some changes, see: <a href="https://github.com/timodejong95/MMM-BluetoothDevices" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/timodejong95/MMM-BluetoothDevices</a>. Don’t forget <code>npm install</code>.</p>
<p dir="auto">I updated the configuration see docs. You need to add a track key to the device config with the value ‘battery’:</p>
<p dir="auto">example:</p>
<pre><code>devices: [
  { type: 'OralBToothbrush', name: 'oralb', mac: 'xxx', tracks: ['battery'], format: 'formatted' },
<p dir="auto">It’s still a bit buggy let me know what your experience is!</p>
]]></description><link>https://forum.magicmirror.builders/post/73089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73089</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Sun, 19 Apr 2020 19:10:15 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Sat, 18 Apr 2020 21:30:13 GMT]]></title><description><![CDATA[<p dir="auto">I have been debugging it and it seems that the devices is ‘just’ being disconnected:</p>
<pre><code>HCI Event: Disconn Complete (0x05) plen 4
    status 0x00 handle 64 reason 0x13
    Reason: Remote User Terminated Connection
<p dir="auto">I do not know why :/</p>
]]></description><link>https://forum.magicmirror.builders/post/73017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73017</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Sat, 18 Apr 2020 21:30:13 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Sat, 18 Apr 2020 17:38:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a></p>
<p dir="auto">Haha thanks man.</p>
<p dir="auto">I have made some big changes, improved connecting devices, GATT service, characteristics and some more. I have also managed to get the battery value, but I have an issue: after around 15-30 seconds after connection successfully to the device the connection drops:</p>
<pre><code class="language-json">{"ServicesResolved":false,"Connected":false}
<p dir="auto">I haven’t figured out why this happens, all the normal data is still received. Only the battery status not, it needs to be connected. I haven’t push anything to the repo yet. First I want to look if I can get it working (fully).</p>
<p dir="auto">Are you experiencing the same with noble or can you get the battery status after 30 seconds or 1 minute plus?</p>
<p dir="auto">I keep you updated.</p>
]]></description><link>https://forum.magicmirror.builders/post/73008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/73008</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Sat, 18 Apr 2020 17:38:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Fri, 17 Apr 2020 08:25:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a> Well according to the gitlab code we’re looking for this:</p>
<pre><code>Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c
        a0f0ff05-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002f
        00002901-0000-1000-8000-00805f9b34fb
        Characteristic User Description
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char002c/desc002e
        00002902-0000-1000-8000-00805f9b34fb
        Client Characteristic Configuration
<p dir="auto">The characteristic is the one the referenced noble code is filtering for.</p>
<p dir="auto">Now GO Timo!<br />
Make brushing great again!</p>
]]></description><link>https://forum.magicmirror.builders/post/72927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72927</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 17 Apr 2020 08:25:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Fri, 17 Apr 2020 08:16:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timodejong95" aria-label="Profile: timodejong95">@<bdi>timodejong95</bdi></a> I used <a href="https://gitlab.com/snippets/1928948" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> gitlab snippet. Don’t remember how I got there. I guess from the homeassistant forum which is also working on that.<br />
For more follow-up see my <a href="https://forum.magicmirror.builders/post/69497">post</a> in this thread</p>
<p dir="auto">When I use bluetoothctl on my RasPi I am getting lots of output form the brush recently. I’m not sure why exactly, maybe because my Pi is coupled with the brush.</p>
<pre><code>Primary Service
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050
        a0f0ff20-5047-4d53-8208-4f72616c2d42
        Vendor specific
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070
        a0f0ff2b-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0070/desc0072
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d
        a0f0ff2a-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006d/desc006f
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a
        a0f0ff29-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char006a/desc006c
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067
        a0f0ff28-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0067/desc0069
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064
        a0f0ff27-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0064/desc0066
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061
        a0f0ff26-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0061/desc0063
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e
        a0f0ff25-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005e/desc0060
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b
        a0f0ff24-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char005b/desc005d
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058
        a0f0ff23-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0058/desc005a
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055
        a0f0ff22-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0055/desc0057
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051
        a0f0ff21-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0054
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0050/char0051/desc0053
Primary Service
        a0f0ff00-5047-4d53-8208-4f72616c2d42
        Vendor specific
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c
        a0f0ff0d-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004f
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char004c/desc004e
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048
        a0f0ff0c-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004b
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0048/desc004a
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044
        a0f0ff0b-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0047
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0044/desc0046
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040
        a0f0ff0a-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0043
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0040/desc0042
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c
        a0f0ff09-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003f
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char003c/desc003e
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038
        a0f0ff08-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003b
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0038/desc003a
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034
        a0f0ff07-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0037
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0034/desc0036
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030
        a0f0ff06-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0033
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0030/desc0032
Characteristic
        Vendor specific
Descriptor
Descriptor
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028
        a0f0ff04-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002b
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0028/desc002a
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025
        a0f0ff03-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0025/desc0027
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022
        a0f0ff02-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char0022/desc0024
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f
        a0f0ff01-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service001e/char001f/desc0021
Primary Service
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010
        a0f0fff0-5047-4d53-8208-4f72616c2d42
        Vendor specific
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b
        a0f0fff4-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char001b/desc001d
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018
        a0f0fff3-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0018/desc001a
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015
        a0f0fff2-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0015/desc0017
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011
        a0f0fff1-5047-4d53-8208-4f72616c2d42
        Vendor specific
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0014
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service0010/char0011/desc0013
Primary Service
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c
        Generic Attribute Profile
Characteristic
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d
        00002a05-0000-1000-8000-00805f9b34fb
        Service Changed
Descriptor
        /org/bluez/hci0/dev_58_7A_62_3F_63_80/service000c/char000d/desc000f
<p dir="auto">Do we have to look into one of these characteristics/desricptors for the value?</p>
]]></description><link>https://forum.magicmirror.builders/post/72925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72925</guid><dc:creator><![CDATA[lavolp3]]></dc:creator><pubDate>Fri, 17 Apr 2020 08:16:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OralB / Bluetooth equipped toothbrush integration on Fri, 17 Apr 2020 06:43:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lavolp3" aria-label="Profile: lavolp3">@<bdi>lavolp3</bdi></a>  Thanks, I will have a look at that this weekend.</p>
<p dir="auto">Also managed to connect to the services and characteristics. But how did you know the one you needed?</p>
<p dir="auto">Because you only connecting to the 3th key in the services array and a hardcoded uuid for the characteristics. I am curious how you find the one you needed.</p>
]]></description><link>https://forum.magicmirror.builders/post/72921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/72921</guid><dc:creator><![CDATA[timodejong95]]></dc:creator><pubDate>Fri, 17 Apr 2020 06:43:08 GMT</pubDate></item></channel></rss>
