<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problems with bring app Module]]></title><description><![CDATA[<p dir="auto">Since a few weeks or months I have problems with my bring module - since a few days I try now to solve it unfortunately I am not able to<br />
I hope someone can help me with that.<br />
The MM is not showing nothing. Later I will post a screenshot of the logs.</p>
<p dir="auto">Error: Unexpected Error during download of the catalog Error: connect ETIMEOUT</p>
]]></description><link>https://forum.magicmirror.builders/topic/16172/problems-with-bring-app-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 06:08:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16172.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Jan 2022 11:36:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problems with bring app Module on Sun, 16 Jan 2022 17:53:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I’ve been using this app and module for a few months. When it works it’s great. There was an issue a few weeks ago when the HTTPS connections no longer worked due to problem with a verifying site. This was resolved by another Bring user to use HHTP connections instead and has worked until the last few weeks. Now the module does not work at all although the app still works well. Apparently the app does not have an official API and the owners have changed the way the app and data works together.  I do not have sufficient knowledge of node.js to begin to resolve this issue and have therefore resorted to using the google sheets module as a reminder list. it’s not as easy to use but it is reliable and uses the google official API.<br />
Hope this is informative and possibly helpful.</p>
]]></description><link>https://forum.magicmirror.builders/post/98660</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98660</guid><dc:creator><![CDATA[BigTJ]]></dc:creator><pubDate>Sun, 16 Jan 2022 17:53:45 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Fri, 14 Jan 2022 05:21:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jagsi" aria-label="Profile: jagsi">@<bdi>jagsi</bdi></a> I use MMM-Bring <a href="https://github.com/werthdavid/MMM-Bring" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/werthdavid/MMM-Bring</a><br />
Have no problems with it</p>
]]></description><link>https://forum.magicmirror.builders/post/98524</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98524</guid><dc:creator><![CDATA[Fozi]]></dc:creator><pubDate>Fri, 14 Jan 2022 05:21:03 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Thu, 13 Jan 2022 20:01:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jagsi" aria-label="Profile: jagsi">@<bdi>jagsi</bdi></a> I do not… as moderator I generally try to help with install and setup issues… try to ctach any recurring problems,</p>
<p dir="auto">but don’t get into individual modules much… too many to know what they do , how best to use them , etc.</p>
]]></description><link>https://forum.magicmirror.builders/post/98523</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98523</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Jan 2022 20:01:04 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Thu, 13 Jan 2022 19:58:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hmm ok I will try - maybe you know an other module for Bring?</p>
]]></description><link>https://forum.magicmirror.builders/post/98522</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98522</guid><dc:creator><![CDATA[Jagsi]]></dc:creator><pubDate>Thu, 13 Jan 2022 19:58:39 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Thu, 13 Jan 2022 19:47:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jagsi" aria-label="Profile: jagsi">@<bdi>jagsi</bdi></a> said in <a href="/post/98519">Problems with bring app Module</a>:</p>
<p dir="auto">“Bring List”</p>
<p dir="auto">well, technically its called</p>
<p dir="auto">MMM-bringList</p>
<p dir="auto">and is located here</p>
<p dir="auto"><a href="https://github.com/rseidt/MMM-bringList" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/rseidt/MMM-bringList</a></p>
<p dir="auto">as the author updated something a couple months ago, I would suggest you open an issue there to engage him in the problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/98520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98520</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Jan 2022 19:47:59 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Thu, 13 Jan 2022 19:44:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
its called “Bring List”</p>
]]></description><link>https://forum.magicmirror.builders/post/98519</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98519</guid><dc:creator><![CDATA[Jagsi]]></dc:creator><pubDate>Thu, 13 Jan 2022 19:44:42 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Thu, 13 Jan 2022 19:40:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jagsi" aria-label="Profile: jagsi">@<bdi>jagsi</bdi></a> said in <a href="/post/98516">Problems with bring app Module</a>:</p>
<p dir="auto">Bring Module</p>
<p dir="auto">what is the name of the module,? there are multiple with ‘bring’ in their names</p>
]]></description><link>https://forum.magicmirror.builders/post/98518</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98518</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 13 Jan 2022 19:40:01 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Thu, 13 Jan 2022 19:36:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/98410">Problems with bring app Module</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jagsi" aria-label="Profile: jagsi">@<bdi>jagsi</bdi></a> sounds like the server the module is trying to connect to is down.  (timeout)</p>
<p dir="auto">thats the Bring Module" nobody else has this issue?</p>
]]></description><link>https://forum.magicmirror.builders/post/98516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98516</guid><dc:creator><![CDATA[Jagsi]]></dc:creator><pubDate>Thu, 13 Jan 2022 19:36:15 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Tue, 11 Jan 2022 21:38:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jagsi" aria-label="Profile: jagsi">@<bdi>jagsi</bdi></a> sounds like the server the module is trying to connect to is down.  (timeout)</p>
<p dir="auto">what module is that?</p>
]]></description><link>https://forum.magicmirror.builders/post/98410</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98410</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 11 Jan 2022 21:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to Problems with bring app Module on Tue, 11 Jan 2022 19:42:26 GMT]]></title><description><![CDATA[<p dir="auto">here is the screenshot of the logs</p>
<p dir="auto"><img src="/assets/uploads/files/1641930128791-bring_fehler-resized.jpg" alt="Bring_Fehler.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">please help</p>
]]></description><link>https://forum.magicmirror.builders/post/98403</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98403</guid><dc:creator><![CDATA[Jagsi]]></dc:creator><pubDate>Tue, 11 Jan 2022 19:42:26 GMT</pubDate></item></channel></rss>
