<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1]]></title><description><![CDATA[<p dir="auto">After updating to latest version of MM using git pull &amp;&amp; npm install - nothing is working, looks like npm is broken.</p>
<p dir="auto">Using npm start 0 I get error message: npm does not support Node.js v10.24.1<br />
<img src="/assets/uploads/files/1641942155431-162020d6-c10d-4f7a-aca5-1ae121ca6ff5-image.png" alt="162020d6-c10d-4f7a-aca5-1ae121ca6ff5-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Using pm2 start 0 i get this table</p>
<p dir="auto"><img src="/assets/uploads/files/1641942055244-06416ea4-6fd8-45a3-8184-58d497904c2c-image.png" alt="06416ea4-6fd8-45a3-8184-58d497904c2c-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any help is appreciate</p>
]]></description><link>https://forum.magicmirror.builders/topic/16177/error-on-v-2-18-update-magicmirror-npm-does-not-support-node-js-v10-24-1</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 13:37:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16177.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Jan 2022 23:02:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Thu, 27 Jan 2022 00:21:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks!!  All works fine now. :clapping_hands:</p>
]]></description><link>https://forum.magicmirror.builders/post/99072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99072</guid><dc:creator><![CDATA[MrDondoT]]></dc:creator><pubDate>Thu, 27 Jan 2022 00:21:21 GMT</pubDate></item><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Wed, 12 Jan 2022 15:11:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdondot" aria-label="Profile: mrdondot">@<bdi>mrdondot</bdi></a> yep, see the link in the prior post</p>
]]></description><link>https://forum.magicmirror.builders/post/98431</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98431</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Jan 2022 15:11:07 GMT</pubDate></item><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Wed, 12 Jan 2022 13:01:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
after deleting the pm2 that’s the result of log:</p>
<pre><code>/home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
1|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
1|MagicMir | -
1|MagicMir | [12.01.2022 13:12.37.327] [ERROR] App threw an error during load
1|MagicMir | [12.01.2022 13:12.37.330] [ERROR] Error: Cannot find module 'valid-url'
1|MagicMir | Require stack:
1|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js
1|MagicMir | - /home/pi/MagicMirror/js/app.js
1|MagicMir | - /home/pi/MagicMirror/js/electron.js
1|MagicMir | -
1|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
1|MagicMir |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
1|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
1|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
1|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
1|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
1|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
1|MagicMir |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js:9:16)
1|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
1|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
1|MagicMir | [12.01.2022 13:12.37.332] [ERROR] Whoops! There was an uncaught exception...
1|MagicMir | [12.01.2022 13:12.37.339] [ERROR] Error: Cannot find module 'valid-url'
1|MagicMir | -
1|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
1|MagicMir |   code: 'MODULE_NOT_FOUND',
1|MagicMir |   requireStack: [
1|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
1|MagicMir |     '/home/pi/MagicMirror/js/app.js',
1|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
1|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
1|MagicMir |     undefined
1|MagicMir |   ]
1|MagicMir | }
1|MagicMir | [12.01.2022 13:12.37.340] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
1|MagicMir | [12.01.2022 13:12.37.341] [ERROR] If you think this really is an is sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
1|MagicMir | [1030:0112/131240.512560:ERROR:service_worker_storage.cc(1899)] Failed to delete the database: Database IO error
]]></description><link>https://forum.magicmirror.builders/post/98430</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98430</guid><dc:creator><![CDATA[MrDondoT]]></dc:creator><pubDate>Wed, 12 Jan 2022 13:01:29 GMT</pubDate></item><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Wed, 12 Jan 2022 12:41:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdondot" aria-label="Profile: mrdondot">@<bdi>mrdondot</bdi></a> ok  use pm2 delete 0 to remove 1</p>
<p dir="auto">then pm2 logs --lines=50</p>
<p dir="auto">to dump the logs so we can see what is going on.</p>
<p dir="auto">if you did an upgrade  then see this<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/98429</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98429</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Jan 2022 12:41:53 GMT</pubDate></item><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Wed, 12 Jan 2022 08:03:48 GMT]]></title><description><![CDATA[<p dir="auto">thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> .<br />
The npm install went well with no errors, thus on restart I can only have a black screen and 2 instances of mm</p>
<p dir="auto"><img src="/assets/uploads/files/1641974595260-9536d0fa-3d55-4525-ae87-7077683c7bd7-image.png" alt="9536d0fa-3d55-4525-ae87-7077683c7bd7-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/98424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98424</guid><dc:creator><![CDATA[MrDondoT]]></dc:creator><pubDate>Wed, 12 Jan 2022 08:03:48 GMT</pubDate></item><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Wed, 12 Jan 2022 00:12:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdondot" aria-label="Profile: mrdondot">@<bdi>mrdondot</bdi></a> after upgrade node/npm</p>
<p dir="auto">you need to redo the npm install of mm</p>
<pre><code>cd ~/MagicMirror
rm -rf node_modules
rm package-lock.json
npm install
]]></description><link>https://forum.magicmirror.builders/post/98419</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98419</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 12 Jan 2022 00:12:13 GMT</pubDate></item><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Tue, 11 Jan 2022 23:25:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
after updating it (btw i thought it was already updated) i got this:</p>
<p dir="auto"><img src="/assets/uploads/files/1641943519872-d7975564-813b-42ac-b1c7-958bff7e95de-image.png" alt="d7975564-813b-42ac-b1c7-958bff7e95de-image.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1641943456422-d5e2afcc-90d0-4b78-90eb-de9d37d7ef21-image.png" alt="d5e2afcc-90d0-4b78-90eb-de9d37d7ef21-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/98416</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98416</guid><dc:creator><![CDATA[MrDondoT]]></dc:creator><pubDate>Tue, 11 Jan 2022 23:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1 on Tue, 11 Jan 2022 23:12:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mrdondot" aria-label="Profile: mrdondot">@<bdi>mrdondot</bdi></a></p>
<p dir="auto">min. Version for node is v14, recommended v16. You have to update node.</p>
]]></description><link>https://forum.magicmirror.builders/post/98415</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98415</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Tue, 11 Jan 2022 23:12:20 GMT</pubDate></item></channel></rss>
