<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Sequel of MMM-PublicTransportBerlin only displays "Loading..."]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
my <a href="https://github.com/deg0nz/MMM-PublicTransportBerlin" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-PublicTransportBerlin</a> module refuses to load again. I did all the things of my <a href="https://forum.magicmirror.builders/post/96320">previous post</a>, but I didn’t succeed.<br />
But there is a difference this time: when I stop my magic mirror I am able to see some error messages concerning the module saying something like</p>
<ul>
<li>
<p dir="auto">“unhandled promise rejection” and</p>
</li>
<li>
<p dir="auto">“error while fetching departures: FetchError: invalid json response body at <a href="http://bvg-apps-ext.hafas.de/bin/mgate.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://bvg-apps-ext.hafas.de/bin/mgate.exe</a>? reason: Unexpected end of JSON input”.</p>
</li>
</ul>
<p dir="auto">My magic mirror is up and running, internet connection is available, all other modules are working fine. I didn’t do any changes before the error occurred…<br />
My NPM version is 6.14 - maybe this is too old?<br />
Does anyone know what the above error messages mean? What did I do wrong?</p>
<p dir="auto">Thank you very much.<br />
May the code be with you<br />
-kai</p>
]]></description><link>https://forum.magicmirror.builders/topic/16179/sequel-of-mmm-publictransportberlin-only-displays-loading</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 14:51:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16179.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Jan 2022 10:59:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Sequel of MMM-PublicTransportBerlin only displays "Loading..." on Wed, 12 Jan 2022 13:52:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kai" aria-label="Profile: kai">@<bdi>kai</bdi></a> - I have the same issue and I noticed there is a <a href="https://github.com/deg0nz/MMM-PublicTransportBerlin/issues/66" target="_blank" rel="noopener noreferrer nofollow ugc">problem with the BVG API service</a>.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> just added a pull request. I guess, as soon as you do a <code>git pull</code> in the folder MMM-PublicTransportBerlin  it should work.</p>
]]></description><link>https://forum.magicmirror.builders/post/98432</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98432</guid><dc:creator><![CDATA[MZ-BER]]></dc:creator><pubDate>Wed, 12 Jan 2022 13:52:52 GMT</pubDate></item><item><title><![CDATA[Reply to Sequel of MMM-PublicTransportBerlin only displays "Loading..." on Fri, 14 Jan 2022 08:41:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mz-ber" aria-label="Profile: MZ-BER">@<bdi>MZ-BER</bdi></a>,</p>
<p dir="auto">today my MM showed that there is an update of the <a href="https://github.com/deg0nz/MMM-PublicTransportBerlin" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-PublicTransportBerlin</a> module. Hence a <code> git pull</code> and an <code>npm install</code> solved the problem. :thumbs_up_medium-light_skin_tone:</p>
<p dir="auto">Many thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a>, <a href="https://github.com/deg0nz" target="_blank" rel="noopener noreferrer nofollow ugc">@deg0nz</a> and all who work so diligently in the background to keep the MM running!</p>
<p dir="auto">May the code be with you<br />
-kai</p>
]]></description><link>https://forum.magicmirror.builders/post/98529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98529</guid><dc:creator><![CDATA[kai]]></dc:creator><pubDate>Fri, 14 Jan 2022 08:41:42 GMT</pubDate></item><item><title><![CDATA[Reply to Sequel of MMM-PublicTransportBerlin only displays "Loading..." on Wed, 12 Jan 2022 18:14:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mz-ber" aria-label="Profile: mz-ber">@<bdi>mz-ber</bdi></a>,</p>
<p dir="auto">thanks a lot, but unfortunately this didn’t work for me. :disappointed_face:<br />
It just says “already up to date” (“<em>Bereits aktuell</em>”) and that’s it. Seems like I have to wait until the cause of the error message is found…<br />
I’ll be patient. :slightly_smiling_face:</p>
<p dir="auto">Thank you very much for sharing the <a href="https://github.com/deg0nz/MMM-PublicTransportBerlin/issues/66" target="_blank" rel="noopener noreferrer nofollow ugc">link to the fetcher errors</a>. :thumbs_up_light_skin_tone:</p>
]]></description><link>https://forum.magicmirror.builders/post/98438</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98438</guid><dc:creator><![CDATA[kai]]></dc:creator><pubDate>Wed, 12 Jan 2022 18:14:15 GMT</pubDate></item><item><title><![CDATA[Reply to Sequel of MMM-PublicTransportBerlin only displays "Loading..." on Wed, 12 Jan 2022 13:52:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kai" aria-label="Profile: kai">@<bdi>kai</bdi></a> - I have the same issue and I noticed there is a <a href="https://github.com/deg0nz/MMM-PublicTransportBerlin/issues/66" target="_blank" rel="noopener noreferrer nofollow ugc">problem with the BVG API service</a>.</p>
]]></description><link>https://forum.magicmirror.builders/post/98432</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/98432</guid><dc:creator><![CDATA[MZ-BER]]></dc:creator><pubDate>Wed, 12 Jan 2022 13:52:52 GMT</pubDate></item></channel></rss>
