<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help getting MagicMirror going.]]></title><description><![CDATA[<p dir="auto">getting magic mirror going</p>
]]></description><link>https://forum.magicmirror.builders/topic/162/help-getting-magicmirror-going</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 16:03:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/162.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 28 May 2016 00:37:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Help getting MagicMirror going. on Sat, 28 May 2016 01:25:22 GMT]]></title><description><![CDATA[<p dir="auto">Sorry about that my internet here went out for a few minutes.<br />
Here is the rest of what I was trying to add to my first post…</p>
<p dir="auto">I would like some help getting my pi2 running Rasbian jessie working.<br />
I think that i installed all I need to but am not 100% sure, the auto installer failed and i attempted to install manually.</p>
<p dir="auto">My first thought was that Electron was not installed or not installed correctly so i tried running the “node serveronly” option but that failed too. from the results of that i am lead to believe that it has something to do with the modules. I had originally try to customize my the config for the modules but i now have all the default settings in place.</p>
<hr />
<p dir="auto">I have also included the log file from the last error <a href="/uploads/files/1464396953752-npm-debug.log">0_1464396891025_npm-debug.log</a></p>
<hr />
<p dir="auto"><strong>This is the error that i get when i try “npm start”.</strong></p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.0.0 start /home/pi/MagicMirror<br />
electron js/electron.js</p>
<p dir="auto">/home/pi/MagicMirror/node_modules/electron-prebuilt/dist/electron: relocation error: /home/pi/MagicMirror/node_modules/electron-prebuilt/dist/electron: symbol t4lessIjESaIS2_EE17_M_insert_unique_IS2_EESt17_Rb_tree_iteratorIS2_ESt23_Rb_tree_const_iteratorIS2_EOT_, version GLIBC_2.4 not defined in file libm.so.6 with link time reference</p>
<p dir="auto">npm ERR! Linux 4.1.13-v7+<br />
npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”<br />
npm ERR! node v6.2.0<br />
npm ERR! npm  v3.8.9<br />
npm ERR! file sh<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! errno ENOENT<br />
npm ERR! syscall spawn<br />
npm ERR! magicmirror@2.0.0 start: <code>electron js/electron.js</code><br />
npm ERR! spawn ENOENT<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.<br />
npm ERR! Make sure you have the latest version of node.js and npm installed.<br />
npm ERR! If you do, this is most likely a problem with the magicmirror package,<br />
npm ERR! not with npm itself.<br />
npm ERR! Tell the author that this fails on your system:<br />
npm ERR!     electron js/electron.js<br />
npm ERR! You can get information on how to open an issue for this project with:<br />
npm ERR!     npm bugs magicmirror<br />
npm ERR! Or if that isn’t available, you can get their info via:<br />
npm ERR!     npm owner ls magicmirror<br />
npm ERR! There is likely additional logging output above.</p>
<p dir="auto">npm ERR! Please include the following file with any support request:<br />
npm ERR!     /home/pi/MagicMirror/npm-debug.log</p>
<hr />
<p dir="auto"><strong>This is what i get when i run “node serveronly”</strong></p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ node serveronly<br />
module.js:442<br />
throw err;<br />
^</p>
<p dir="auto">Error: Cannot find module ‘finalhandler’<br />
at Function.Module._resolveFilename (module.js:440:15)<br />
at Function.Module._load (module.js:388:25)<br />
at Module.require (module.js:468:17)<br />
at require (internal/module.js:20:19)<br />
at Object. (/home/pi/MagicMirror/node_modules/express/lib/application.js:16:20)<br />
at Module._compile (module.js:541:32)<br />
at Object.Module._extensions…js (module.js:550:10)<br />
at Module.load (module.js:458:32)<br />
at tryModuleLoad (module.js:417:12)<br />
at Function.Module._load (module.js:409:3)</p>
]]></description><link>https://forum.magicmirror.builders/post/1165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1165</guid><dc:creator><![CDATA[jam]]></dc:creator><pubDate>Sat, 28 May 2016 01:25:22 GMT</pubDate></item><item><title><![CDATA[Reply to Help getting MagicMirror going. on Sat, 28 May 2016 00:40:41 GMT]]></title><description><![CDATA[<p dir="auto">Please read the instructions available at <a href="https://github.com/MichMich/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror</a> (scroll down). Tell us what you’ve done, what you’ve tried, what hardware you’re on, version of operating system, and what’s not working.</p>
]]></description><link>https://forum.magicmirror.builders/post/1152</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1152</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Sat, 28 May 2016 00:40:41 GMT</pubDate></item></channel></rss>
