<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black Screen Of Death After Couple of Hours]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/9228/black-screen-of-death-after-couple-of-hours">Black Screen Of Death After Couple of Hours</a></p>
<p dir="auto">I have the same problem. I do get a black screen of death after a couple of hours of flawlessly running the mm.<br />
The logs show the following errors:</p>
<pre><code>Client: [813:0207/081301.113752:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=139
Client: [813:0207/081307.156628:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=139
Client: [813:0207/081324.670017:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=139
Client: [935:0207/081331.151481:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
Client: [935:0208/081622.102905:ERROR:connection.cc(66)] X connection error received.
[935:0208/081622.103292:ERROR:connection.cc(66)] X connection error received.
Client: Gdk-Message: 08:16:22.439: electron: Fatal IO error 11 (Die Ressource ist zur Zeit nicht verfügbar) on X server :0.
<p dir="auto">Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16333/black-screen-of-death-after-couple-of-hours</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 03:38:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16333.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Feb 2022 09:05:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sun, 13 Feb 2022 18:41:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a></p>
<p dir="auto">I think it might be in correlation with 2.18.0 of mm or with updating the containers with watchtower?!</p>
<p dir="auto">I think the client crashes when you update the container image because updating the container means it will be restarted.</p>
]]></description><link>https://forum.magicmirror.builders/post/99557</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99557</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sun, 13 Feb 2022 18:41:52 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sun, 13 Feb 2022 13:55:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a> right  but u can do the start browser instead of start mm client.</p>
<p dir="auto">just a way to test in the short term…  if it stays running or not</p>
<p dir="auto">if you use chromium u can get the command line from my <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> script I use when electron is not available.</p>
<p dir="auto">see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/99540</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99540</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Feb 2022 13:55:14 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sun, 13 Feb 2022 13:49:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Well by default the pi bootens up and MagicMirror shows in full screen mode until the screen goes black again after a couple of hours.<br />
But I havent started a browser in full screen mode manually yet.</p>
]]></description><link>https://forum.magicmirror.builders/post/99538</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99538</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Sun, 13 Feb 2022 13:49:39 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sun, 13 Feb 2022 13:37:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a> can you open a browser on the pi and connect to mm server, full screen  no title bar</p>
]]></description><link>https://forum.magicmirror.builders/post/99533</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99533</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Feb 2022 13:37:28 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sun, 13 Feb 2022 09:51:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
I am running the client on a Raspberry Pi. There I do get the electron errors and the screen goes black.<br />
]]></description><link>https://forum.magicmirror.builders/post/99524</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99524</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Sun, 13 Feb 2022 09:51:15 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sat, 12 Feb 2022 21:53:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> unless he is running mm client on the other machine, vs running chrome to the server</p>
]]></description><link>https://forum.magicmirror.builders/post/99517</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99517</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Feb 2022 21:53:22 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sat, 12 Feb 2022 21:23:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">now I’m totally lost. He is running mm <code>server only</code> on his synology and he postet client errors related to electron …</p>
]]></description><link>https://forum.magicmirror.builders/post/99516</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99516</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 12 Feb 2022 21:23:40 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sat, 12 Feb 2022 21:18:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> if they are running client, then not electron</p>
]]></description><link>https://forum.magicmirror.builders/post/99515</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99515</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Feb 2022 21:18:29 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sat, 12 Feb 2022 19:30:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a></p>
<p dir="auto">then it’s no server problem, no idea why the client crashes. Is this new with mm version v2.18.0 (because it contains new electron version)?</p>
]]></description><link>https://forum.magicmirror.builders/post/99512</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99512</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 12 Feb 2022 19:30:54 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Sat, 12 Feb 2022 09:31:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a></p>
<pre><code>docker ps
<p dir="auto">the status says “Up 3 days”. This is due to Watchtower I think as the container got updated.<br />
When this happens and the screen gets black, I do restart the client which continues to produce black screens.</p>
<p dir="auto">Here is the output of</p>
<pre><code>docker logs magicmirror
<p dir="auto">I can only find one starting sequence.</p>
<pre><code>copy default modules to host ...
rm: cannot remove '/opt/magic_mirror/modules/default/compliments': Device or resource busy
copy css files to host ...
chown modules and config folder ...
timezone is Europe/Berlin
start magicmirror
&gt; magicmirror@2.18.0 server
&gt; node ./serveronly
[09.02.2022 07:01.18.543] [LOG]   Starting MagicMirror: v2.18.0
[09.02.2022 07:01.18.547] [LOG]   Loading config ...
[09.02.2022 07:01.18.612] [LOG]   Loading module helpers ...
[09.02.2022 07:01.18.613] [LOG]   No helper found for module: alert.
[09.02.2022 07:01.18.620] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.18.624] [LOG]   Module helper loaded: updatenotification
[09.02.2022 07:01.18.626] [LOG]   No helper found for module: clock.
[09.02.2022 07:01.18.628] [LOG]   No helper found for module: MMM-Traffic.
[09.02.2022 07:01.18.671] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.18.672] [LOG]   Module helper loaded: MMM-RMV
[09.02.2022 07:01.18.797] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.18.797] [LOG]   Module helper loaded: MMM-Tankerkoenig
[09.02.2022 07:01.19.242] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.19.242] [LOG]   Module helper loaded: MMM-Formula1
[09.02.2022 07:01.19.289] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.19.290] [LOG]   Module helper loaded: MMM-soccer
[09.02.2022 07:01.19.312] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.19.313] [LOG]   Module helper loaded: MagicMirror-FootballLeagues
[09.02.2022 07:01.19.314] [LOG]   No helper found for module: weather.
[09.02.2022 07:01.19.314] [LOG]   No helper found for module: MMM-WeatherChart.
[09.02.2022 07:01.19.341] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.19.341] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
[09.02.2022 07:01.19.438] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.19.439] [LOG]   Module helper loaded: calendar
[09.02.2022 07:01.19.439] [LOG]   No helper found for module: MMM-WiFiPassword.
[09.02.2022 07:01.19.440] [LOG]   No helper found for module: compliments.
[09.02.2022 07:01.19.688] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.19.689] [LOG]   Module helper loaded: MMM-NewsAPI
[09.02.2022 07:01.20.305] [LOG]   Initializing new module helper ...
[09.02.2022 07:01.20.306] [LOG]   Module helper loaded: MMM-COVID19-AMPEL
[09.02.2022 07:01.20.306] [LOG]   All module helpers loaded.
[09.02.2022 07:01.20.383] [LOG]   Starting server on port 8080 ...
[09.02.2022 07:01.20.387] [WARN]  You're using a full whitelist configuration to allow for all IPs
[09.02.2022 07:01.20.392] [LOG]   Server started ...
[09.02.2022 07:01.20.393] [LOG]   Connecting socket for: updatenotification
[09.02.2022 07:01.20.394] [LOG]   Starting module helper: updatenotification
[09.02.2022 07:01.20.394] [LOG]   Connecting socket for: MMM-RMV
[09.02.2022 07:01.20.395] [LOG]   node helper: MMM-RMV
[09.02.2022 07:01.20.395] [LOG]   Connecting socket for: MMM-Tankerkoenig
[09.02.2022 07:01.20.396] [LOG]   Starting module helper: MMM-Tankerkoenig
[09.02.2022 07:01.20.396] [LOG]   Connecting socket for: MMM-Formula1
[09.02.2022 07:01.20.396] [LOG]   Starting module: MMM-Formula1
[09.02.2022 07:01.20.397] [LOG]   Connecting socket for: MMM-soccer
[09.02.2022 07:01.20.397] [LOG]   Starting module helper: MMM-soccer
[09.02.2022 07:01.20.398] [LOG]   Connecting socket for: MagicMirror-FootballLeagues
[09.02.2022 07:01.20.398] [LOG]   MagicMirror-FootballLeagues Started...
[09.02.2022 07:01.20.399] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
[09.02.2022 07:01.20.399] [LOG]   MMM-DWD-WarnWeather helper started...
[09.02.2022 07:01.20.400] [LOG]   Connecting socket for: calendar
[09.02.2022 07:01.20.400] [LOG]   Starting node helper for: calendar
[09.02.2022 07:01.20.401] [LOG]   Connecting socket for: MMM-NewsAPI
[09.02.2022 07:01.20.401] [LOG]   Starting node_helper for module: MMM-NewsAPI
[09.02.2022 07:01.20.402] [LOG]   Connecting socket for: MMM-COVID19-AMPEL
[09.02.2022 07:01.20.402] [LOG]   Starting node helper for: MMM-COVID19-AMPEL
[09.02.2022 07:01.20.403] [LOG]   Sockets connected &amp; modules started ...
Ready to go! Please point your browser to: http://0.0.0.0:8080
<p dir="auto">In the docker UI “activate automatic restart” is disabled.</p>
]]></description><link>https://forum.magicmirror.builders/post/99505</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99505</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Sat, 12 Feb 2022 09:31:42 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Thu, 10 Feb 2022 19:41:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a></p>
<p dir="auto">so here the client is crashing.</p>
<p dir="auto">But may because the server crashed, can you take a look at <code>docker ps</code> on the synology if in the <code>status</code> columm is something like <code>restarted</code>. And may examine the logs with <code>docker logs mm</code> if you find the starting sequence <code>Starting MagicMirror: v2.18.0</code> more than once?</p>
<p dir="auto">The docker setup has <code>restart: unless-stopped</code> (if not changed by the user) so the container will restart automatically after a crash.</p>
]]></description><link>https://forum.magicmirror.builders/post/99469</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99469</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Thu, 10 Feb 2022 19:41:12 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Thu, 10 Feb 2022 19:27:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a><br />
OS is Buster<br />
Raspberry Pi 3 Model B Rev 1.2<br />
MagicMirror Version 2.18.0<br />
Running as a client with PM2 on startup.<br />
Connecting to your MagicMirror Docker on a Synology as a server.</p>
]]></description><link>https://forum.magicmirror.builders/post/99468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99468</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Thu, 10 Feb 2022 19:27:03 GMT</pubDate></item><item><title><![CDATA[Reply to Black Screen Of Death After Couple of Hours on Thu, 10 Feb 2022 18:47:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a></p>
<p dir="auto">what is your setup (e.g. pi version, os version (buster), docker)?</p>
<p dir="auto">which modules are running?</p>
]]></description><link>https://forum.magicmirror.builders/post/99467</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99467</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Thu, 10 Feb 2022 18:47:19 GMT</pubDate></item></channel></rss>
