<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can’t create nod_modules directory when installing awesome-alexa]]></title><description><![CDATA[<p dir="auto">I follow the installation commands and after running the</p>
<p dir="auto">npm install - - only=prod</p>
<p dir="auto">It does not create then node_modules directory so I get a non such directory when I enter the next command.</p>
<p dir="auto">I have tried the “npm update” and the “ npm init” commands but still no luck.</p>
<p dir="auto">Any advice?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16342/can-t-create-nod_modules-directory-when-installing-awesome-alexa</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 04:45:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16342.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Feb 2022 03:06:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can’t create nod_modules directory when installing awesome-alexa on Tue, 15 Feb 2022 15:07:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tyboderek" aria-label="Profile: tyboderek">@<bdi>tyboderek</bdi></a> did u install mm using sudo?</p>
<p dir="auto">there should be no reason for this problem</p>
<p dir="auto">erase the module folder again and run the script like this</p>
<p dir="auto">bash -x <a href="http://do-install.sh" target="_blank" rel="noopener noreferrer nofollow ugc">do-install.sh</a> &amp;&gt;somefile.txt</p>
<p dir="auto">and send me somefile.txt via email</p>
<p dir="auto">same userid as here at gmail</p>
]]></description><link>https://forum.magicmirror.builders/post/99620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99620</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 15 Feb 2022 15:07:07 GMT</pubDate></item><item><title><![CDATA[Reply to Can’t create nod_modules directory when installing awesome-alexa on Tue, 15 Feb 2022 14:52:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ran your script and was not able to execute the run the next run config command to enter the alexa AS client ID info. Even went back and deleted the complete MMM-awesome-alexa directory and tried again with same result. I get an early warning that my package-lock.json was created  with an old version of npm and it had to retrieve info from the registry.  Warnings and errors start from there.</p>
<p dir="auto">I am fairly new at this but had success installing the google photos module.</p>
<p dir="auto">Would really like to get this alexa module installed but am at a loss.</p>
]]></description><link>https://forum.magicmirror.builders/post/99619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99619</guid><dc:creator><![CDATA[Tyboderek]]></dc:creator><pubDate>Tue, 15 Feb 2022 14:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to Can’t create nod_modules directory when installing awesome-alexa on Mon, 14 Feb 2022 19:43:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tyboderek" aria-label="Profile: tyboderek">@<bdi>tyboderek</bdi></a> there are errors on many of the commands.</p>
<p dir="auto">run my scropt</p>
]]></description><link>https://forum.magicmirror.builders/post/99597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99597</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 14 Feb 2022 19:43:30 GMT</pubDate></item><item><title><![CDATA[Reply to Can’t create nod_modules directory when installing awesome-alexa on Mon, 14 Feb 2022 19:39:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Yes I did.  For some reason it is not creating the node_modules directory so I get an error trying to execute the next command.</p>
]]></description><link>https://forum.magicmirror.builders/post/99596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99596</guid><dc:creator><![CDATA[Tyboderek]]></dc:creator><pubDate>Mon, 14 Feb 2022 19:39:24 GMT</pubDate></item><item><title><![CDATA[Reply to Can’t create nod_modules directory when installing awesome-alexa on Sun, 13 Feb 2022 13:58:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tyboderek" aria-label="Profile: tyboderek">@<bdi>tyboderek</bdi></a> did u change to the module folder after the git clone</p>
<p dir="auto">I turned all the wiki steps into a short script a couple years ago<br />
see<br />
<a href="https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0</a></p>
<p dir="auto">download, make executable</p>
]]></description><link>https://forum.magicmirror.builders/post/99521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99521</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Feb 2022 13:58:52 GMT</pubDate></item></channel></rss>
