<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Having issues with pm2]]></title><description><![CDATA[<p dir="auto">Node_modules/ .bin/electron: not found</p>
]]></description><link>https://forum.magicmirror.builders/topic/16348/having-issues-with-pm2</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 19:49:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16348.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Feb 2022 14:51:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Having issues with pm2 on Sun, 13 Feb 2022 15:51:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Ok thanks much I’ll try</p>
]]></description><link>https://forum.magicmirror.builders/post/99551</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99551</guid><dc:creator><![CDATA[delta 1]]></dc:creator><pubDate>Sun, 13 Feb 2022 15:51:36 GMT</pubDate></item><item><title><![CDATA[Reply to Having issues with pm2 on Sun, 13 Feb 2022 15:24:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delta-1" aria-label="Profile: delta-1">@<bdi>delta-1</bdi></a> when did u build the SD card?<br />
show results of</p>
<pre><code>uname -a
node -v
npm -v
lsb_release - a
<p dir="auto">maybe try the automated scripts, from a fresh flash ( the newer ones are picky if they get trouble)<br />
see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/99548</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99548</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Feb 2022 15:24:29 GMT</pubDate></item><item><title><![CDATA[Reply to Having issues with pm2 on Sun, 13 Feb 2022 15:21:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I’m following the steps  on the magic mirror central website</p>
]]></description><link>https://forum.magicmirror.builders/post/99547</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99547</guid><dc:creator><![CDATA[delta 1]]></dc:creator><pubDate>Sun, 13 Feb 2022 15:21:35 GMT</pubDate></item><item><title><![CDATA[Reply to Having issues with pm2 on Sun, 13 Feb 2022 15:18:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I’m using a pie 3 module B v1.2</p>
]]></description><link>https://forum.magicmirror.builders/post/99546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99546</guid><dc:creator><![CDATA[delta 1]]></dc:creator><pubDate>Sun, 13 Feb 2022 15:18:21 GMT</pubDate></item><item><title><![CDATA[Reply to Having issues with pm2 on Sun, 13 Feb 2022 15:14:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delta-1" aria-label="Profile: delta-1">@<bdi>delta-1</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/99545</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99545</guid><dc:creator><![CDATA[delta 1]]></dc:creator><pubDate>Sun, 13 Feb 2022 15:14:26 GMT</pubDate></item><item><title><![CDATA[Reply to Having issues with pm2 on Sun, 13 Feb 2022 15:09:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delta-1" aria-label="Profile: delta-1">@<bdi>delta-1</bdi></a> what pi?</p>
<p dir="auto">how did u install mm?</p>
]]></description><link>https://forum.magicmirror.builders/post/99544</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99544</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Feb 2022 15:09:59 GMT</pubDate></item></channel></rss>
