<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-NetworkScanner]]></title><description><![CDATA[<p dir="auto">Is there a way to have two columns side by side of output to the screen?<br />
I have more in the module being checked than will fit on the screen in one column.<br />
I have even made the font smaller so I could get the important ones to show.<img src="/assets/uploads/files/1644785739373-networkscanner.jpg" alt="NetworkScanner.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/16349/mmm-networkscanner</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 05:05:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16349.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Feb 2022 20:56:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-NetworkScanner on Mon, 14 Feb 2022 00:17:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks for looking I was afraid of that.   I will put a request in for a hopeful change by the maker…</p>
]]></description><link>https://forum.magicmirror.builders/post/99570</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99570</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Mon, 14 Feb 2022 00:17:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Wed, 19 Jul 2023 22:56:18 GMT]]></title><description><![CDATA[<p dir="auto">I finally figured out that I can use 2 instances of this module.  Like so and they show up side by side on the screen allowing me to run 20 or so in this module.<br />
{<br />
module: “MMM-NetworkScanner”,<br />
position: “top_left”,<br />
header: “”,<br />
config: {<br />
devices: [<br />
{ ipAddress:<br />
{<br />
position: “top_right”,<br />
header: “”,<br />
config: {<br />
devices: [<br />
{ ipAddress:</p>
]]></description><link>https://forum.magicmirror.builders/post/110310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/110310</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Wed, 19 Jul 2023 22:56:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Sun, 13 Mar 2022 21:02:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xadamxk" aria-label="Profile: xadamxk">@<bdi>xadamxk</bdi></a></p>
<p dir="auto">Thank you for the information,  I am still having issues with the list going off the screen.  I am trying different areas on the screen to see if that makes a differance.</p>
]]></description><link>https://forum.magicmirror.builders/post/100263</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100263</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Sun, 13 Mar 2022 21:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Sun, 13 Mar 2022 01:32:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> I was going to do it, but the module doesn’t use a template for the design. They do it all in javascript, so it wouldn’t be as easy as I was hoping.</p>
<p dir="auto">The developer of this module hasn’t made updates for over 2 years, so you’d be better off trying this fork that has been updated to allow column layouts: <a href="https://github.com/spitzlbergerj/MMM-NetworkScanner" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/spitzlbergerj/MMM-NetworkScanner</a></p>
]]></description><link>https://forum.magicmirror.builders/post/100239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100239</guid><dc:creator><![CDATA[xadamxk]]></dc:creator><pubDate>Sun, 13 Mar 2022 01:32:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Sat, 12 Mar 2022 22:17:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xadamxk" aria-label="Profile: xadamxk">@<bdi>xadamxk</bdi></a><br />
You gonna fix this problem for me.?  I have done a little research on it and it is way above my pay grade…</p>
]]></description><link>https://forum.magicmirror.builders/post/100236</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100236</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Sat, 12 Mar 2022 22:17:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Sun, 06 Mar 2022 21:44:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xadamxk" aria-label="Profile: xadamxk">@<bdi>xadamxk</bdi></a><br />
Please do fork and fix it for me</p>
]]></description><link>https://forum.magicmirror.builders/post/100129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100129</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Sun, 06 Mar 2022 21:44:05 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Tue, 01 Mar 2022 03:24:25 GMT]]></title><description><![CDATA[<p dir="auto">Is anyone working on this? I can fork the project with the changes you requested - just let me know.</p>
]]></description><link>https://forum.magicmirror.builders/post/100014</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100014</guid><dc:creator><![CDATA[xadamxk]]></dc:creator><pubDate>Tue, 01 Mar 2022 03:24:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Mon, 14 Feb 2022 01:15:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> last updated in  2019, so don’t hold your breath.</p>
<p dir="auto">learn js and html…</p>
<p dir="auto">make it configurable<br />
use list,<br />
divide by configured columns</p>
]]></description><link>https://forum.magicmirror.builders/post/99573</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99573</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 14 Feb 2022 01:15:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Mon, 14 Feb 2022 00:17:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
]]></description><link>https://forum.magicmirror.builders/post/99570</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99570</guid><dc:creator><![CDATA[plainbroke]]></dc:creator><pubDate>Mon, 14 Feb 2022 00:17:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-NetworkScanner on Sun, 13 Feb 2022 23:08:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/plainbroke" aria-label="Profile: plainbroke">@<bdi>plainbroke</bdi></a> looking at the code, it creates a table w only 1 column.</p>
<p dir="auto">so someone would have to change the code</p>
]]></description><link>https://forum.magicmirror.builders/post/99564</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99564</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 13 Feb 2022 23:08:49 GMT</pubDate></item></channel></rss>
