<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar text alignment other than module alignment?]]></title><description><![CDATA[<p dir="auto">Hi!  I’m using the default Calendar module and its working fine. However, I use position top_center, but the events are also centered. I want the events to be left aligned but keep the top_center position of the module. Is that possible?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16354/calendar-text-alignment-other-than-module-alignment</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 15:47:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16354.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Feb 2022 09:10:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar text alignment other than module alignment? on Mon, 14 Feb 2022 18:02:59 GMT]]></title><description><![CDATA[<p dir="auto">@hango Thanks! Works like a charm.</p>
]]></description><link>https://forum.magicmirror.builders/post/99592</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99592</guid><dc:creator><![CDATA[digied]]></dc:creator><pubDate>Mon, 14 Feb 2022 18:02:59 GMT</pubDate></item></channel></rss>
