<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding a delayed &quot;display off&quot; to the PIR Sensor module.]]></title><description><![CDATA[<p dir="auto">Hoping someone can assist.  I’m finishing up my first MagicMirror project and need a bit of help with the PIR-Sensor module(<a href="https://forum.magicmirror.builders/topic/52/pir-sensor-put-your-mirror-to-sleep-if-not-used/6">https://forum.magicmirror.builders/topic/52/pir-sensor-put-your-mirror-to-sleep-if-not-used/6</a>).</p>
<p dir="auto">I’d like to modify the code to have a delay on turning the display off so that it turns off 20 seconds after the last “USER_PRESENCE” is detected.  Right now it turns off immediately.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/1636/adding-a-delayed-display-off-to-the-pir-sensor-module</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 06:09:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1636.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Feb 2017 14:42:05 GMT</pubDate><ttl>60</ttl></channel></rss>
