<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My Mirror reboots for no reason]]></title><description><![CDATA[<p dir="auto">I am using the PIR Sensor on my Mirror and it seems to work fine.  But I find that<br />
sometimes the screen will turn on in the middle of the night with no one around.<br />
It will also do a total reboot for no reason at all.</p>
]]></description><link>https://forum.magicmirror.builders/topic/16361/my-mirror-reboots-for-no-reason</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 06:29:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16361.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Feb 2022 19:43:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My Mirror reboots for no reason on Wed, 16 Feb 2022 16:26:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lhops" aria-label="Profile: lhops">@<bdi>lhops</bdi></a> for a small protocoll add the following lines to crontab<br />
(enter crontab -e at the prompt):</p>
<p dir="auto">@reboot echo “---- start ----”                 &gt;&gt; proto.txt<br />
*/5 * * * * date                                       &gt;&gt; proto.txt<br />
*/5 * * * * vcgencmd measure_temp &gt;&gt; proto.txt</p>
<p dir="auto">That moves the date and the temperature to a file called proto.txt every 5 minutes (and an eyecatcher at the start of the raspberry)</p>
]]></description><link>https://forum.magicmirror.builders/post/99645</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99645</guid><dc:creator><![CDATA[thgmirror]]></dc:creator><pubDate>Wed, 16 Feb 2022 16:26:28 GMT</pubDate></item><item><title><![CDATA[Reply to My Mirror reboots for no reason on Wed, 16 Feb 2022 14:09:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fribse" aria-label="Profile: fribse">@<bdi>fribse</bdi></a></p>
<p dir="auto">I will install a fan to the Raspberry and see if that solves the problem. Thanks for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/99643</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99643</guid><dc:creator><![CDATA[lhops]]></dc:creator><pubDate>Wed, 16 Feb 2022 14:09:19 GMT</pubDate></item><item><title><![CDATA[Reply to My Mirror reboots for no reason on Tue, 15 Feb 2022 22:01:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lhops" aria-label="Profile: lhops">@<bdi>lhops</bdi></a> Try to log your temperature, the reboot sounds like a temp issue.<br />
It would also suit the PiR that registers a rising temperature.</p>
]]></description><link>https://forum.magicmirror.builders/post/99632</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99632</guid><dc:creator><![CDATA[fribse]]></dc:creator><pubDate>Tue, 15 Feb 2022 22:01:11 GMT</pubDate></item></channel></rss>
