<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GmailFeed]]></title><description><![CDATA[<p dir="auto">So I ran into a problem</p>
<p dir="auto">when I installed the new update for MMM-GmailFeedand that’s when I ran into a problem<br />
I have Googleassistant from bugsounet installed on my magic mirror<br />
when magic mirror starts and MMM-GmailFeed loads and checked my email. But the problem is, it blocking Googleassistant from loading .<br />
I tested this several ways<br />
I stopped the updates on GmailFeed and Googleassistant worked.<br />
I also did a disable of the module and again Googleassistant worked .<br />
It’s whatever GmailFeed starts Google assistance does not load<br />
I loaded the previous version of GmailFeed and everything works perfectly. So there is  something in the new version is causing the problem</p>
<p dir="auto">Has anyone else had this problem</p>
]]></description><link>https://forum.magicmirror.builders/topic/16364/mmm-gmailfeed</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 22:11:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16364.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Feb 2022 23:45:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GmailFeed on Fri, 18 Feb 2022 09:24:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ray" aria-label="Profile: ray">@<bdi>ray</bdi></a> I’ve reported an issue I was having with the update to this module and linked this thread, there’s been an update to hopefully address the issues and the issue tracker has been enabled on the github page.</p>
]]></description><link>https://forum.magicmirror.builders/post/99707</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99707</guid><dc:creator><![CDATA[unfriendlydevice]]></dc:creator><pubDate>Fri, 18 Feb 2022 09:24:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GmailFeed on Fri, 04 Mar 2022 14:34:46 GMT]]></title><description><![CDATA[<p dir="auto">Sorry it took so long to reply back. I’ve been kinda busy<br />
I finally had time to upgrade MMM-GmailFeed<br />
everything went fine and is running perfectly :beaming_face_with_smiling_eyes:</p>
<p dir="auto">Thank you everyone for your help :thumbs_up:</p>
]]></description><link>https://forum.magicmirror.builders/post/100081</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100081</guid><dc:creator><![CDATA[Ray]]></dc:creator><pubDate>Fri, 04 Mar 2022 14:34:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GmailFeed on Fri, 18 Feb 2022 15:14:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/unfriendlydevice" aria-label="Profile: unfriendlydevice">@<bdi>unfriendlydevice</bdi></a> thanks for that. I will look into it and reinstall it and see what happens</p>
]]></description><link>https://forum.magicmirror.builders/post/99716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99716</guid><dc:creator><![CDATA[Ray]]></dc:creator><pubDate>Fri, 18 Feb 2022 15:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GmailFeed on Fri, 18 Feb 2022 09:24:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ray" aria-label="Profile: ray">@<bdi>ray</bdi></a> I’ve reported an issue I was having with the update to this module and linked this thread, there’s been an update to hopefully address the issues and the issue tracker has been enabled on the github page.</p>
]]></description><link>https://forum.magicmirror.builders/post/99707</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99707</guid><dc:creator><![CDATA[unfriendlydevice]]></dc:creator><pubDate>Fri, 18 Feb 2022 09:24:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GmailFeed on Wed, 16 Feb 2022 17:31:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I actually tried the 1st, but I could not find a place to open up an issue.<br />
That’s why I posted here. Hopefully, he would see it</p>
]]></description><link>https://forum.magicmirror.builders/post/99648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99648</guid><dc:creator><![CDATA[Ray]]></dc:creator><pubDate>Wed, 16 Feb 2022 17:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GmailFeed on Wed, 16 Feb 2022 01:30:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ray" aria-label="Profile: ray">@<bdi>ray</bdi></a> I would open an issue on the modules GitHub page, to engage the module author.</p>
<p dir="auto">many times this is an accidental global  variable collision.</p>
]]></description><link>https://forum.magicmirror.builders/post/99636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99636</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 16 Feb 2022 01:30:35 GMT</pubDate></item></channel></rss>
