<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Podcast2 - MM doesnt start config.js]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">Since an update from MagicMirror failed, I had to reinstall everything.<br />
Everything works except for Podcast2. I copied it to the modules folder as usual and then chose npm install. After configuring the config.js file (as in the example), the mirror no longer starts. Boots up but doesn’t load the config.js properly.<br />
Does somebody has any idea?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16373/mmm-podcast2-mm-doesnt-start-config-js</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 03:46:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16373.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Feb 2022 09:55:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Podcast2 - MM doesnt start config.js on Thu, 17 Feb 2022 13:30:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/florianrd" aria-label="Profile: florianrd">@<bdi>florianrd</bdi></a> can you sj<br />
how the messages from startup?</p>
<p dir="auto">npm start or pm2 logs if using pm2</p>
]]></description><link>https://forum.magicmirror.builders/post/99672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99672</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 17 Feb 2022 13:30:18 GMT</pubDate></item></channel></rss>
