<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM - Error GPU_Process_Host]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I just started playing around with MM (awseome) and some other modules.  It would occasionally freeze the whole Pi3B+.  No network, no keyboard/mouse, I would have to press the power button on the switch that came with the CanaKit.</p>
<p dir="auto">So I flipped back to the sample config.js and still  get the error.  Here’s what I get.</p>
<p dir="auto">[8818:0218/065006.349453:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=11</p>
<p dir="auto">[8818:0218/065007.220429:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=11</p>
<p dir="auto">[8818:0218/065008.067653:ERROR:gpu_process_host.cc(968)] GPU process exited unexpectedly: exit_code=11</p>
<p dir="auto">[8913:0218/065008.551741:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.</p>
<p dir="auto">I found google links for VSCode, but I can’t figure out if that applies with MM and if so, what I need to do.</p>
<p dir="auto">Any suggestions?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16378/mm-error-gpu_process_host</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 01:03:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16378.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Feb 2022 12:32:23 GMT</pubDate><ttl>60</ttl></channel></rss>
