<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[question about MMM-MarineWeather module]]></title><description><![CDATA[<p dir="auto">I’m very new to this so please bear with me.</p>
<p dir="auto">I have successfully added the above module to Magic Mirror and it’s working! However, I want to change units from Celsius to Fahrenheit. The module’s readme file says I can do this by coding config.units = imperial.  I’m not exactly sure how to actually put this into the config.js file though.</p>
<p dir="auto">I tried typing it out right after the last line of code, which was apid: XXXX and ended up crashing mm.  little help?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16381/question-about-mmm-marineweather-module</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 02:19:26 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16381.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Feb 2022 17:52:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to question about MMM-MarineWeather module on Tue, 22 Feb 2022 16:42:28 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 Thank you. I changed it globally. This was very helpful. What did you mean by start a github?</p>
]]></description><link>https://forum.magicmirror.builders/post/99860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99860</guid><dc:creator><![CDATA[r3d6]]></dc:creator><pubDate>Tue, 22 Feb 2022 16:42:28 GMT</pubDate></item><item><title><![CDATA[Reply to question about MMM-MarineWeather module on Sat, 19 Feb 2022 06:39:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/r3d6" aria-label="Profile: r3d6">@<bdi>r3d6</bdi></a> you have two options.</p>
<p dir="auto">Either you change it globally for your mirror here (recommended, because it also controls the units for other modules):</p>
<p dir="auto"><img src="/assets/uploads/files/1645252585107-c9dfec93-e69b-4e47-a281-41c6d9bcc8b7-image.png" alt="c9dfec93-e69b-4e47-a281-41c6d9bcc8b7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Or only for this module specifically:</p>
<p dir="auto"><img src="/assets/uploads/files/1645252724850-fb2c2ee1-9674-40e8-91d9-0821b82e99c0-image.png" alt="fb2c2ee1-9674-40e8-91d9-0821b82e99c0-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/99737</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99737</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 19 Feb 2022 06:39:20 GMT</pubDate></item></channel></rss>
