<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Errors with MMM-Astronauts and MMM-HueLights]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
I am absolutely new in this game. Hope someone can give me an advise. I tried to start module MMM-Astronauts and received the following Error note:</p>
<p dir="auto">*WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/MMM-Astronauts/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js<br />
-*</li>
</ul>
<p dir="auto">I installed the Module like mentioned. Like every other module on my mirror. The others work fine except mmm-hue-lights.</p>
<p dir="auto">There I get the following message:</p>
<p dir="auto">*[ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘request’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/mmm-hue-lights/node_helper.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js*</li>
</ul>
<p dir="auto">Maybe someone of you has an advice.<br />
Thank you very much :-)</p>
<p dir="auto">Meralith</p>
]]></description><link>https://forum.magicmirror.builders/topic/16394/errors-with-mmm-astronauts-and-mmm-huelights</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 20:52:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16394.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 21 Feb 2022 11:26:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Errors with MMM-Astronauts and MMM-HueLights on Mon, 21 Feb 2022 13:25:26 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Everything is working fine now.</p>
]]></description><link>https://forum.magicmirror.builders/post/99832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99832</guid><dc:creator><![CDATA[meralith]]></dc:creator><pubDate>Mon, 21 Feb 2022 13:25:26 GMT</pubDate></item><item><title><![CDATA[Reply to Errors with MMM-Astronauts and MMM-HueLights on Mon, 21 Feb 2022 12:48:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/meralith" aria-label="Profile: meralith">@<bdi>meralith</bdi></a> see<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/99830</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/99830</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Feb 2022 12:48:52 GMT</pubDate></item></channel></rss>
