<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-GoogleSheets Not loading]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am having issues with getting the module working. I have followed the instructions as per <a href="https://github.com/ryan-d-williams/MMM-GoogleSheets" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/ryan-d-williams/MMM-GoogleSheets</a>.</p>
<p dir="auto">However when loading all it says is “loading…”.</p>
<p dir="auto">Looking in the log it says:<br />
28.02.2022 21:37.41.094] [LOG]   Connecting socket for: MMM-GoogleSheets<br />
[28.02.2022 21:37.41.096] [LOG]   ====================== Starting node_helper for module [MMM-GoogleSheets]<br />
[28.02.2022 21:37.41.097] [LOG]   Sockets connected &amp; modules started …<br />
[28.02.2022 21:37.41.617] [LOG]   Launching application.<br />
[28.02.2022 21:37.44.794] [ERROR] Whoops! There was an uncaught exception…<br />
[28.02.2022 21:37.44.810] [ERROR] SyntaxError: Unexpected token &lt; in JSON at position 1<br />
at JSON.parse ()<br />
at Request._callback (/home/pi/MagicMirror/modules/MMM-GoogleSheets/node_helper.js:47:27)<br />
at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)<br />
at Request.emit (events.js:315:20)<br />
at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1154:10)<br />
at IncomingMessage. (/home/pi/MagicMirror/node_modules/request/request.js:1076:12)<br />
at Object.onceWrapper (events.js:421:28)<br />
at IncomingMessage.emit (events.js:327:22)<br />
at endReadableNT (_stream_readable.js:1220:12)<br />
[28.02.2022 21:37.44.815] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
[28.02.2022 21:37.44.817] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a></p>
<p dir="auto">Any help would be appreciated.</p>
<p dir="auto">Best wishes</p>
<p dir="auto">Matthew</p>
]]></description><link>https://forum.magicmirror.builders/topic/16425/mmm-googlesheets-not-loading</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 15:00:58 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16425.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Feb 2022 21:40:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-GoogleSheets Not loading on Sat, 10 Aug 2024 14:56:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mlm198" aria-label="Profile: mlm198">@<bdi>mlm198</bdi></a> This error is usually caused by not deploying the google apps script correctly. I have updated the README with pictures to hopefully make the deployment easier. Feel free to add an issue to the repo if you are still having problems.</p>
]]></description><link>https://forum.magicmirror.builders/post/119207</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119207</guid><dc:creator><![CDATA[ryandwilliams]]></dc:creator><pubDate>Sat, 10 Aug 2024 14:56:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleSheets Not loading on Mon, 28 Feb 2022 22:27:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mlm198" aria-label="Profile: mlm198">@<bdi>mlm198</bdi></a> I see he does this a different way. did u do all of step 1?</p>
<p dir="auto"><img src="/assets/uploads/files/1646087232794-screenshot_20220228-152628_chrome.jpg" alt="Screenshot_20220228-152628_Chrome.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/100010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100010</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Feb 2022 22:27:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleSheets Not loading on Mon, 28 Feb 2022 22:17:28 GMT]]></title><description><![CDATA[<p dir="auto">I couldn’t work out how to run the script in full for the fix blacl screen.</p>
<p dir="auto">I got up to "npm install ??? " but then I don’t have a module to install.</p>
<p dir="auto">Can you point me in the right direction of authenticating the API and downloading credentials. Also where do I put that?</p>
<p dir="auto">THanks for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/100009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100009</guid><dc:creator><![CDATA[mlm198]]></dc:creator><pubDate>Mon, 28 Feb 2022 22:17:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleSheets Not loading on Mon, 28 Feb 2022 21:52:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> I don’t think that is the problem.</p>
<p dir="auto">I think the Google API isn’t authenticated.<br />
and downloaded credentials file</p>
]]></description><link>https://forum.magicmirror.builders/post/100008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100008</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Feb 2022 21:52:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-GoogleSheets Not loading on Mon, 28 Feb 2022 21:46:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mlm198" aria-label="Profile: mlm198">@<bdi>mlm198</bdi></a></p>
<p dir="auto">see <a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/100007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100007</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Mon, 28 Feb 2022 21:46:09 GMT</pubDate></item></channel></rss>
