<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM Modules not loading]]></title><description><![CDATA[<p dir="auto">I am new to MagicMirror. I have downloaded 3 modules to utilize in my config.js. They are not loading and I cannot figure out why. I have attempted to fix it on my own but to no avail. What am I doing incorrectly for it not to load? All the prebuilt modules are working fine. Any clues to get me debugging this? Thank you.</p>
<pre><code>let config = {
	address: "localhost", 	// Address to listen on, can be:
	port: 8080,
	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
	language: "en",
	locale: "en-US",
	timeFormat: 12,
	units: "imperial",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
				timeFormat: "12",
				timezone: "America/New_York"
			header: "US Holidays",
						symbol: "calendar-check",
						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
			module: "weather",
			header: "Weather Forecast",
				type: "forecast",
				units: "imperial",
				locationID: "4155966", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				apiKey: "xxxx"
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "CNN",
						url: "http://rss.cnn.com/rss/cnn_latest.rss"
				showSourceTitle: true,
				showPublishDate: true
			module: "newsfeed",
				feeds: [
						title: "New York Times",
			module: "MMM-PNews",
				key: "xxxx",
				maxWidth: "100%",
				//newsSource: "the-wall-street-journal",
				//newsSource: "reuters",
				newsSource: "techradar"
			module: "MMM-RAIN-MAP",
			position: "bottom_right",
				animationSpeedMs: 400,
				colorScheme: 2,
				colorizeTime: true,
				defaultZoomLevel: 8,
				displayTime: true,
				displayTimeline: true,
				displayClockSymbol: true,
				displayOnlyOnRain: false,
				extraDelayLastFrameMs: 1000,
				extraDelayCurrentFrameMs: 3000,
				markers: [
					{ lat: 26.143, lng: -80.128, color: "red" },
					{ lat: 26.12, lng: -80.13, color: "green" },
				mapPositions: [
					{ lat: 26.143, lng: -80.128, zoom: 9, loops: 1 },
					{ lat: 26.143, lng: -80.128, zoom: 6, loops: 2 },
					{ lat: 26.12, lng: -80.13, zoom: 5, loops: 2 },
					{ lat: 26.109, lng: -80.233, zoom: 3, loops: 2 },
				mapUrl: "https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png",
				mapHeight: "420px", // must be a pixel value (no percent)
				mapWidth: "420px", // must be a pixel value (no percent)
				maxHistoryFrames: -1,
				maxForecastFrames: -1,
				substitudeModules: [],
				updateIntervalInSeconds: 300
			module: "MMM-OpenWeatherForecast",
			header: "Forecast",
						apikey: "xxxx", //SUPER SECRET
						latitude: 26.124161,
						longitude: -80.143593,
						units: "imperial",
						iconset: "3c",
						colored: true,
						concise: true,
						requestDelay: "2000",
						showFeelsLikeTemp: true,
						showCurrentConditions: true,
						showSummary: true,
						showExtraCurrentConditions: true,
						extraCurrentConditions: {
													highLowTemp: true,
													precipitation: true,
													sunrise: true,
													sunset: true,
													wind: true,
													barometricPressure: false,
													humidity: true,
													dewPoint: false,
													uvIndex: true,
													visibility: false
						forecastLayout: "table",
						forecastHeaderText: "",
						hourlyForecastTableHeaderText: "By the hour",
						showHourlyForecast: true,
						showHourlyTableHeaderRow: true,
						hourlyForecastInterval: 1,
						maxHourliesToShow: 10,
						hourlyExtras: {
											wind: true,
											humidity: false,
											dewPoint: false,
											uvIndex: false,
											visibility: false
						dailyForecastTableHeaderText: "Throughout the week",
						showDailyForecast: true,
						showDailyTableHeaderRow: true,
						maxDailiesToShow: 5,
						dailyExtras: {
										sunrise: false,
										sunset: false,
										wind: true,
										humidity: false,
										dewPoint: false,
										uvIndex: false
]]></description><link>https://forum.magicmirror.builders/topic/16431/mmm-modules-not-loading</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 16:55:24 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16431.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Mar 2022 13:41:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM Modules not loading on Tue, 01 Mar 2022 15:54:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank for the links. It really helped. My issue was not installing the modules within the modules folder. I reinstalled MagicMirror entirely as the program was acting buggy when I manually deleted the folders. Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/100031</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100031</guid><dc:creator><![CDATA[cwong79]]></dc:creator><pubDate>Tue, 01 Mar 2022 15:54:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM Modules not loading on Tue, 01 Mar 2022 14:20:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cwong79" aria-label="Profile: cwong79">@<bdi>cwong79</bdi></a> where did u install them?</p>
<p dir="auto">see the topics in my signature below</p>
<p dir="auto">also, see theessages where u start mm<br />
either with</p>
<p dir="auto">npm start</p>
<p dir="auto">or</p>
<p dir="auto">pm2 logs<br />
of using pm 2</p>
]]></description><link>https://forum.magicmirror.builders/post/100027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100027</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Mar 2022 14:20:07 GMT</pubDate></item></channel></rss>
