<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[comments Module corrupted !]]></title><description><![CDATA[<p dir="auto">my comments are not showing up on my mirror even tho the module is there,<br />
is there a way to recover  default modules on MM (comments module ).</p>
]]></description><link>https://forum.magicmirror.builders/topic/16466/comments-module-corrupted</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 15:31:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16466.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Mar 2022 00:36:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to comments Module corrupted ! on Tue, 08 Mar 2022 01:43:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/100168">comments Module corrupted !</a>:</p>
<p dir="auto">cd ~/MagicMirror<br />
git checkout modules/default/compliments/compliments.js</p>
<p dir="auto">thanks much. that worked</p>
]]></description><link>https://forum.magicmirror.builders/post/100169</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100169</guid><dc:creator><![CDATA[delta 1]]></dc:creator><pubDate>Tue, 08 Mar 2022 01:43:33 GMT</pubDate></item><item><title><![CDATA[Reply to comments Module corrupted ! on Tue, 08 Mar 2022 00:51:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/delta-1" aria-label="Profile: delta-1">@<bdi>delta-1</bdi></a> u mean compliments?</p>
<p dir="auto">1st never edit the module source code</p>
<p dir="auto">all config changes go in config/config.js</p>
<p dir="auto">to restore the original code do</p>
<pre><code>cd ~/MagicMirror
<p dir="auto">read the two topics in my signature below</p>
]]></description><link>https://forum.magicmirror.builders/post/100168</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100168</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Mar 2022 00:51:11 GMT</pubDate></item></channel></rss>
