<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Exiting GPU process due to errors during initialization]]></title><description><![CDATA[<p dir="auto">Hi all! I have installed a fresh copy of MagicMirror. It runs with the default config for testing purposes. However every other minute, the app restarts and that is what I see in the logs.</p>
<p dir="auto">Has anybody else had the same issue?</p>
<pre><code>0|MagicMirror  | [22.03.2022 08:05.49.841] [LOG]   Shutting down server...
0|MagicMirror  | [22.03.2022 08:05.49.846] [LOG]   Stopping module helper: updatenotification
0|MagicMirror  | [22.03.2022 08:05.49.848] [LOG]   Stopping module helper: calendar
0|MagicMirror  | [22.03.2022 08:05.49.851] [LOG]   Stopping module helper: newsfeed
0|MagicMirror  | [3597:0322/080549.911892:ERROR:network_service_instance_impl.cc(916)] Network service crashed, restarting service.
0|MagicMirror  | [3597:0322/080549.948086:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
0|MagicMirror  | [3597:0322/080549.951955:ERROR:zygote_communication_linux.cc(276)] Failed to send GetTerminationStatus message to zygote
0|MagicMirror  | [3597:0322/080549.991850:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
0|MagicMirror  | [3597:0322/080549.998793:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
0|MagicMirror  | [3597:0322/080550.004524:ERROR:gpu_process_host.cc(962)] GPU process launch failed: error_code=1002
0|MagicMirror  | &gt; magicmirror@2.18.0 start
0|MagicMirror  | &gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
0|MagicMirror  | [22.03.2022 08:05.58.334] [LOG]
0|MagicMirror  | Starting MagicMirror: v2.18.0
0|MagicMirror  | [22.03.2022 08:05.58.358] [LOG]
0|MagicMirror  | Loading config ...
0|MagicMirror  | [22.03.2022 08:05.58.375] [LOG]
0|MagicMirror  | Loading module helpers ...
0|MagicMirror  | [22.03.2022 08:05.58.385] [LOG]
0|MagicMirror  | No helper found for module: alert.
0|MagicMirror  | [22.03.2022 08:05.58.425] [LOG]
0|MagicMirror  | Initializing new module helper ...
0|MagicMirror  | [22.03.2022 08:05.58.433] [LOG]
0|MagicMirror  | Module helper loaded: updatenotification
0|MagicMirror  | [22.03.2022 08:05.58.443] [LOG]
0|MagicMirror  | No helper found for module: clock.
0|MagicMirror  | [22.03.2022 08:05.58.738] [LOG]
0|MagicMirror  | [22.03.2022 08:05.58.746] [LOG]
0|MagicMirror  | Module helper loaded: calendar
0|MagicMirror  | [22.03.2022 08:05.58.749] [LOG]   No helper found for module: compliments.
0|MagicMirror  | [22.03.2022 08:05.58.753] [LOG]   No helper found for module: weather.
0|MagicMirror  | [22.03.2022 08:05.58.797] [LOG]
0|MagicMirror  | [22.03.2022 08:05.58.798] [LOG]   Module helper loaded: newsfeed
0|MagicMirror  | [22.03.2022 08:05.58.800] [LOG]   All module helpers loaded.
0|MagicMirror  | [22.03.2022 08:05.59.004] [LOG]
0|MagicMirror  | Starting server on port 8080 ...
0|MagicMirror  | [22.03.2022 08:05.59.033] [LOG]
0|MagicMirror  | Server started ...
0|MagicMirror  | [22.03.2022 08:05.59.036] [LOG]   Connecting socket for: updatenotification
0|MagicMirror  | [22.03.2022 08:05.59.038] [LOG]   Starting module helper: updatenotification
0|MagicMirror  | [22.03.2022 08:05.59.041] [LOG]   Connecting socket for: calendar
0|MagicMirror  | [22.03.2022 08:05.59.043] [LOG]   Starting node helper for: calendar
0|MagicMirror  | [22.03.2022 08:05.59.044] [LOG]   Connecting socket for: newsfeed
0|MagicMirror  | [22.03.2022 08:05.59.047] [LOG]   Starting node helper for: newsfeed
0|MagicMirror  | [22.03.2022 08:05.59.048] [LOG]   Sockets connected &amp; modules started ...
0|MagicMirror  | Fontconfig warning: ignoring UTF-8: not a valid region tag
0|MagicMirror  | [22.03.2022 08:05.59.496] [LOG]
0|MagicMirror  | Launching application.
0|MagicMirror  | [3805:0322/080600.430740:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
0|MagicMirror  | [3847:0322/080600.709029:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
0|MagicMirror  | [22.03.2022 08:06.03.253] [LOG]
0|MagicMirror  | Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
0|MagicMirror  | [22.03.2022 08:06.03.349] [LOG]
0|MagicMirror  | Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
0|MagicMirror  | [22.03.2022 08:06.03.438] [INFO]
0|MagicMirror  | Checking git for module: default
0|MagicMirror  | [22.03.2022 08:06.04.245] [INFO]
0|MagicMirror  | Newsfeed-Fetcher: Broadcasting 62 items.
0|MagicMirror  | [22.03.2022 08:06.04.525] [INFO]
0|MagicMirror  | Calendar-Fetcher: Broadcasting 10 events.
0|MagicMirror  | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGTERM
0|MagicMirror  | [22.03.2022 08:07.29.120] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.145] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.162] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.173] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.212] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.220] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.230] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.529] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.538] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.547] [LOG]
0|MagicMirror  | No helper found for module: compliments.
0|MagicMirror  | [22.03.2022 08:07.29.555] [LOG]
0|MagicMirror  | No helper found for module: weather.
0|MagicMirror  | [22.03.2022 08:07.29.600] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.601] [LOG]   Module helper loaded: newsfeed
0|MagicMirror  | [22.03.2022 08:07.29.603] [LOG]   All module helpers loaded.
0|MagicMirror  | [22.03.2022 08:07.29.800] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.828] [LOG]
0|MagicMirror  | [22.03.2022 08:07.29.831] [LOG]
0|MagicMirror  | Connecting socket for: updatenotification
0|MagicMirror  | [22.03.2022 08:07.29.833] [LOG]   Starting module helper: updatenotification
0|MagicMirror  | [22.03.2022 08:07.29.835] [LOG]   Connecting socket for: calendar
0|MagicMirror  | [22.03.2022 08:07.29.837] [LOG]   Starting node helper for: calendar
0|MagicMirror  | [22.03.2022 08:07.29.839] [LOG]   Connecting socket for: newsfeed
0|MagicMirror  | [22.03.2022 08:07.29.841] [LOG]   Starting node helper for: newsfeed
0|MagicMirror  | [22.03.2022 08:07.29.843] [LOG]   Sockets connected &amp; modules started ...
0|MagicMirror  | [22.03.2022 08:07.30.266] [LOG]
0|MagicMirror  | [3972:0322/080731.149506:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
0|MagicMirror  | [4012:0322/080731.425367:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
0|MagicMirror  | [22.03.2022 08:07.33.874] [LOG]
0|MagicMirror  | [22.03.2022 08:07.33.945] [LOG]
0|MagicMirror  | [22.03.2022 08:07.34.020] [INFO]
0|MagicMirror  | [22.03.2022 08:07.35.040] [INFO]
0|MagicMirror  | [22.03.2022 08:07.35.333] [INFO]
0|MagicMirror  | [22.03.2022 08:08.59.890] [LOG]
0|MagicMirror  | [22.03.2022 08:08.59.903] [LOG]   Loading config ...
0|MagicMirror  | [22.03.2022 08:08.59.915] [LOG]
0|MagicMirror  | [22.03.2022 08:08.59.920] [LOG]   No helper found for module: alert.
0|MagicMirror  | [22.03.2022 08:08.59.953] [LOG]
0|MagicMirror  | [22.03.2022 08:08.59.956] [LOG]   Module helper loaded: updatenotification
0|MagicMirror  | [22.03.2022 08:08.59.959] [LOG]   No helper found for module: clock.
0|MagicMirror  | [22.03.2022 08:09.00.255] [LOG]
0|MagicMirror  | [22.03.2022 08:09.00.258] [LOG]
0|MagicMirror  | [22.03.2022 08:09.00.262] [LOG]
0|MagicMirror  | [22.03.2022 08:09.00.265] [LOG]   No helper found for module: weather.
0|MagicMirror  | [22.03.2022 08:09.00.308] [LOG]
0|MagicMirror  | [22.03.2022 08:09.00.310] [LOG]   Module helper loaded: newsfeed
0|MagicMirror  | [22.03.2022 08:09.00.311] [LOG]   All module helpers loaded.
0|MagicMirror  | [22.03.2022 08:09.00.505] [LOG]
0|MagicMirror  | [22.03.2022 08:09.00.534] [LOG]
0|MagicMirror  | [22.03.2022 08:09.00.536] [LOG]   Connecting socket for: updatenotification
0|MagicMirror  | [22.03.2022 08:09.00.538] [LOG]   Starting module helper: updatenotification
0|MagicMirror  | [22.03.2022 08:09.00.540] [LOG]
0|MagicMirror  | Connecting socket for: calendar
0|MagicMirror  | [22.03.2022 08:09.00.542] [LOG]   Starting node helper for: calendar
0|MagicMirror  | [22.03.2022 08:09.00.543] [LOG]   Connecting socket for: newsfeed
0|MagicMirror  | [22.03.2022 08:09.00.544] [LOG]   Starting node helper for: newsfeed
0|MagicMirror  | [22.03.2022 08:09.00.545] [LOG]   Sockets connected &amp; modules started ...
0|MagicMirror  | [22.03.2022 08:09.00.962] [LOG]
0|MagicMirror  | [4127:0322/080901.889231:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
0|MagicMirror  | [4168:0322/080902.203933:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
0|MagicMirror  | [22.03.2022 08:09.04.598] [LOG]
0|MagicMirror  | [22.03.2022 08:09.04.664] [LOG]
0|MagicMirror  | [22.03.2022 08:09.04.733] [INFO]
0|MagicMirror  | [22.03.2022 08:09.05.534] [INFO]
0|MagicMirror  | [22.03.2022 08:09.05.791] [INFO]
]]></description><link>https://forum.magicmirror.builders/topic/16523/exiting-gpu-process-due-to-errors-during-initialization</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 22:44:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16523.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Mar 2022 06:10:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Exiting GPU process due to errors during initialization on Mon, 28 Mar 2022 19:24:21 GMT]]></title><description><![CDATA[<p dir="auto">this seems to be an electron bug which is already fixed but not released, see <a href="https://github.com/electron/electron/issues/31675" target="_blank" rel="noopener noreferrer nofollow ugc">this issue</a> for more info.</p>
]]></description><link>https://forum.magicmirror.builders/post/100598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100598</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Mon, 28 Mar 2022 19:24:21 GMT</pubDate></item><item><title><![CDATA[Reply to Exiting GPU process due to errors during initialization on Sun, 27 Mar 2022 22:03:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gernst48" aria-label="Profile: gernst48">@<bdi>gernst48</bdi></a> said in <a href="/post/100579">Exiting GPU process due to errors during initialization</a>:</p>
<p dir="auto">and no one is willing to give an answer about this problem.</p>
<p dir="auto">no one KNOWS what the answer IS…</p>
<p dir="auto">you can try to turn off use of the gpu</p>
<p dir="auto">by adding --disable_gpu<br />
like this in package.json<br />
on the start clause</p>
<pre><code> "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron --disable-gpu js/electron.js",
]]></description><link>https://forum.magicmirror.builders/post/100580</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100580</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 27 Mar 2022 22:03:13 GMT</pubDate></item><item><title><![CDATA[Reply to Exiting GPU process due to errors during initialization on Sun, 27 Mar 2022 21:44:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gernst48" aria-label="Profile: gernst48">@<bdi>gernst48</bdi></a><br />
Why do you think this problem is solved ?<br />
Yes, it is not the cause of reset, but it is still a open question<br />
]]></description><link>https://forum.magicmirror.builders/post/100579</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100579</guid><dc:creator><![CDATA[gernst48]]></dc:creator><pubDate>Sun, 27 Mar 2022 21:44:53 GMT</pubDate></item><item><title><![CDATA[Reply to Exiting GPU process due to errors during initialization on Tue, 22 Mar 2022 08:48:36 GMT]]></title><description><![CDATA[<p dir="auto">Seems that this is a know bug and not the cause of the restart.</p>
]]></description><link>https://forum.magicmirror.builders/post/100485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100485</guid><dc:creator><![CDATA[Ivanov_d]]></dc:creator><pubDate>Tue, 22 Mar 2022 08:48:36 GMT</pubDate></item></channel></rss>
