<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Avoidance of Troubleshooting Q]]></title><description><![CDATA[<p dir="auto">I’ve been out of loop for a good stretch between Covid &amp; a sick elderly parent but ready to dive back in.</p>
<p dir="auto">I saved different config and customCSS files which date on hard drive I saved them to are all dated around July 2021.</p>
<p dir="auto">I have downloaded the base setup on to Pi 4B with the 64 bit Pi OS and it appears to be functioning alright. That was an initial concern and still is an open question as to whether all modules will function correctly.</p>
<p dir="auto">My other question is whether I can copy/paste my 7/21 dated config.js and custom.css over or am I going to run in to version conflicts with modules that are making calls to 2021 vintage helper modules and other parts.  Based on reading the forum email I get I think the answer is probably yes.</p>
<p dir="auto">To avoid pulling of hair and gnashing of teeth is there a good/easy way to work through the 3rd Party modules I have configured to avoid wasted time and the dreaded “You messed up” screen.<br />
Seems like the default modules should fine as they would have come when I did install script last week.<br />
Issue might be with 3rd party modules that were fine a year ago  might be a problem today.</p>
]]></description><link>https://forum.magicmirror.builders/topic/16531/avoidance-of-troubleshooting-q</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 14:24:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16531.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Mar 2022 17:10:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Sun, 24 Apr 2022 10:55:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> same here, oops…  just snap the cover on…</p>
]]></description><link>https://forum.magicmirror.builders/post/101386</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101386</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 24 Apr 2022 10:55:11 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Sun, 24 Apr 2022 03:29:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Found a new way scorch a Pi on this project.<br />
Had a snap together case I put Pi in, snapped closed and I’ll admit, it to some muscle to snap case closed.<br />
Shortly thereafter I caught the unmistakable odor of burning electronics.<br />
I snapped the SD card so it was bent like 90°<br />
The Pi did not like that.</p>
]]></description><link>https://forum.magicmirror.builders/post/101376</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101376</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Sun, 24 Apr 2022 03:29:03 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Sat, 26 Mar 2022 01:06:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Found my first 3rd party module lacking “request”. Your tutorial worked like a charm</p>
]]></description><link>https://forum.magicmirror.builders/post/100538</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100538</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Sat, 26 Mar 2022 01:06:03 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Thu, 24 Mar 2022 21:30:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> u can run the backup script on your sd folder… it takes a -s parm for source<br />
(-h shows the syntax)</p>
<p dir="auto">this would create the 3 files…</p>
<p dir="auto">then u could run the restore on the new system  by copying the backup folder to the new system<br />
(and -h shows syntax)</p>
<p dir="auto">this reinstalls the modules from github… not copies any of their files…</p>
]]></description><link>https://forum.magicmirror.builders/post/100526</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100526</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 24 Mar 2022 21:30:51 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Thu, 24 Mar 2022 21:22:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I was just reading the topic about fix for black screen and while I need to read several more times to get my arms around it, I  was wondering if I can do those scripts on  the files before I copy them over.  Instead of ssh’ing in to Pi open terminal go  to  drive and see if they are problematic before moving?<br />
I would back up exiting files in case I blew something up.</p>
]]></description><link>https://forum.magicmirror.builders/post/100525</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100525</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Thu, 24 Mar 2022 21:22:17 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Sun, 10 Apr 2022 12:07:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> that should work…</p>
<p dir="auto">u might want to look at my backup/restore  scripts.</p>
<p dir="auto">they backup config.js and custom.css and the URLs of all the modules u have installed</p>
<p dir="auto">so 3 small files.</p>
<p dir="auto">and then on restore copies back the 2 files and uses the URLs to reinstall all the modules and (fix the missing dependencies too)…</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
<p dir="auto">I need to make them so they can be executed from the repo…  but haven’t done that yet…</p>
<p dir="auto">i made it so the 3 files are in a git repo, so you version them  and then can restore any particular version…<br />
and push the git repo to your github (in a private repo)</p>
]]></description><link>https://forum.magicmirror.builders/post/100522</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100522</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 10 Apr 2022 12:07:39 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Thu, 24 Mar 2022 20:42:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I did use your install script  for the core installation and that is all fine and functional.  I decided to give 64 bit a try because figured if the base MM didn’t like it, just reformat card and do 32 bit.<br />
Hoping I can put MM SD card in laptop card reader and portable drive with files plug in to USB on laptop and it just be a copy/paste exercise in VSC.</p>
<p dir="auto">Most of modules I use are pretty basic. I had found a setup I liked and hoping it’s plug and play.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Glad you made it out of hospital.</p>
]]></description><link>https://forum.magicmirror.builders/post/100521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100521</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Thu, 24 Mar 2022 20:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Thu, 24 Mar 2022 17:34:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> good catch</p>
<p dir="auto">also the direct reference<br />
<a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/100520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100520</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 24 Mar 2022 17:34:13 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Thu, 24 Mar 2022 17:28:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> SO I believe a few things have changed since. Some deprecated modules they got rid off i.e. request and some others. Modules that use them would be a problem.  My suggestion would be to use Sam’s upgrade script which would check each module directory and fixup the missing dependencies for you.</p>
]]></description><link>https://forum.magicmirror.builders/post/100519</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100519</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Thu, 24 Mar 2022 17:28:57 GMT</pubDate></item><item><title><![CDATA[Reply to Avoidance of Troubleshooting Q on Thu, 24 Mar 2022 17:27:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a>  should not be any issues w config.js or custom.css</p>
<p dir="auto">I havent tried the 64 bit myself yet.</p>
<p dir="auto">glad to hear you are back from COVID.  I spent 7 weeks in hospital early last year …</p>
]]></description><link>https://forum.magicmirror.builders/post/100518</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100518</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 24 Mar 2022 17:27:28 GMT</pubDate></item></channel></rss>
