<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Raspberry pi performance]]></title><description><![CDATA[<p dir="auto">I’ve been modifying my mirror for a little while now, and have my config file pretty cleaned up.  But have a question.</p>
<p dir="auto">I’ve noticed after a fresh restart of the pi, everything runs very smoothly.  Modules update perfectly and on time.  The clock modules seconds display is perfectly in time.  However, over time, the modules start lagging on their refresh rates.  The clock modules “seconds” display - instead of every second, starts updating every other second.  And after being on for a full day or two,  every 5-10 seconds.<br />
I only mention the clock module because it is the most noticeable, but other modules are also experiencing similar refresh issues.</p>
<p dir="auto">This seems like a fixable issue, but I’m not positive where to being looking.</p>
<p dir="auto">Hopefully I’ve described the problem correctly.</p>
<p dir="auto">Can anyone offer any suggestions?</p>
<p dir="auto">Thank you so much</p>
<p dir="auto">Nick</p>
]]></description><link>https://forum.magicmirror.builders/topic/16546/raspberry-pi-performance</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 13:11:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16546.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Mar 2022 14:24:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Raspberry pi performance on Sun, 03 Apr 2022 17:03:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/uros76" aria-label="Profile: uros76">@<bdi>uros76</bdi></a></p>
<p dir="auto">Pi4</p>
]]></description><link>https://forum.magicmirror.builders/post/100783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100783</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Sun, 03 Apr 2022 17:03:27 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi performance on Sun, 03 Apr 2022 09:22:03 GMT]]></title><description><![CDATA[<p dir="auto">Which rPi are you using?</p>
]]></description><link>https://forum.magicmirror.builders/post/100757</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100757</guid><dc:creator><![CDATA[uros76]]></dc:creator><pubDate>Sun, 03 Apr 2022 09:22:03 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi performance on Wed, 30 Mar 2022 15:12:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a></p>
<p dir="auto">Thank you for the response.  I only looked at the link quickly, but I’m not sure that its the issue.  Unless I am misunderstanding syncing time as described.</p>
<p dir="auto">My issue is more about the pi taking incrementally longer to refresh each module,   I only mention the clock module because the seconds display is the most noticeable.  Still very much open to any thoughts or suggestions</p>
]]></description><link>https://forum.magicmirror.builders/post/100640</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100640</guid><dc:creator><![CDATA[Nneuland]]></dc:creator><pubDate>Wed, 30 Mar 2022 15:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to Raspberry pi performance on Wed, 30 Mar 2022 14:35:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nneuland" aria-label="Profile: Nneuland">@<bdi>Nneuland</bdi></a><br />
Check this; <a href="https://raspberrytips.com/time-sync-raspberry-pi/" target="_blank" rel="noopener noreferrer nofollow ugc">https://raspberrytips.com/time-sync-raspberry-pi/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/100638</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100638</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Wed, 30 Mar 2022 14:35:56 GMT</pubDate></item></channel></rss>
