<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PIR Sensor doesnt detect movement]]></title><description><![CDATA[<p dir="auto">Hey guys,<br />
I am currently working on my Magic Mirror and want to add an PIR Sensor to it.<br />
I use the MMM-PIRModule to turn the monitor off and on.</p>
<p dir="auto">When I run the program by <code>npm run start</code> the mirror starts but the minotor instantly turns off and never on again. I dont`t know if the sensor is broken or if I just configured something wrong.</p>
<p dir="auto">The config looks like this:</p>
<pre><code>{
	module: 'MMM-PIR-Sensor',
		sensorPIN: 14,
		powerSaving: true,
		offDelay: 30000,
<p dir="auto">If you need more information tell me.</p>
]]></description><link>https://forum.magicmirror.builders/topic/16552/pir-sensor-doesnt-detect-movement</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 02:02:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16552.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Apr 2022 12:06:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 16:05:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1blaunitrox" aria-label="Profile: 1BlauNitrox">@<bdi>1BlauNitrox</bdi></a> it’s 28 inch lcd monitor.  Few years old. Don’t know the model</p>
]]></description><link>https://forum.magicmirror.builders/post/100693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100693</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Fri, 01 Apr 2022 16:05:24 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 15:45:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> can you send me a link to your monitor?</p>
]]></description><link>https://forum.magicmirror.builders/post/100691</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100691</guid><dc:creator><![CDATA[1BlauNitrox]]></dc:creator><pubDate>Fri, 01 Apr 2022 15:45:07 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 14:53:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> lucky… pre-energystar</p>
]]></description><link>https://forum.magicmirror.builders/post/100688</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100688</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Apr 2022 14:53:38 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 14:52:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1blaunitrox" aria-label="Profile: 1BlauNitrox">@<bdi>1BlauNitrox</bdi></a> I used AOC monitor and it doesn’t do it.  After hdmi power cut it shows no signal and go to sleep straight away.  No blue screen.</p>
]]></description><link>https://forum.magicmirror.builders/post/100687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100687</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Fri, 01 Apr 2022 14:52:30 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 14:48:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> I think every monitor has the same behaviour. When you cut the hdmi signal there will be a blue screen “No input signal”.</p>
]]></description><link>https://forum.magicmirror.builders/post/100686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100686</guid><dc:creator><![CDATA[1BlauNitrox]]></dc:creator><pubDate>Fri, 01 Apr 2022 14:48:00 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 14:26:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> my monitors (multiple brands) put up the no input panel for 15 minutes (the energystar  spec defined timeout)<br />
not able to change it…</p>
]]></description><link>https://forum.magicmirror.builders/post/100684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100684</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Apr 2022 14:26:59 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 14:01:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1blaunitrox" aria-label="Profile: 1BlauNitrox">@<bdi>1BlauNitrox</bdi></a> I don’t think you can fix it. Looks like it’s monitor settings. After 30 seconds raspberry cut the hdmi power then your monitor should go to sleep straight away.  But it’s delaying 5 ses. Try the monitor settings if you can find a option that goes to sleep straight away.</p>
]]></description><link>https://forum.magicmirror.builders/post/100682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100682</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Fri, 01 Apr 2022 14:01:27 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 12:25:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tanvir586" aria-label="Profile: tanvir586">@<bdi>tanvir586</bdi></a> Yeah, I worked. Thank you.</p>
<p dir="auto">But there is one issue. When the monitor turns off, there is a blue screen for about 5 seconds…<br />
How can I fix this?</p>
]]></description><link>https://forum.magicmirror.builders/post/100679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100679</guid><dc:creator><![CDATA[1BlauNitrox]]></dc:creator><pubDate>Fri, 01 Apr 2022 12:25:40 GMT</pubDate></item><item><title><![CDATA[Reply to PIR Sensor doesnt detect movement on Fri, 01 Apr 2022 12:18:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/1blaunitrox" aria-label="Profile: 1BlauNitrox">@<bdi>1BlauNitrox</bdi></a> try pin 22 and use this configuration.</p>
<pre><code>     	{
    			sensorPin: 22,
                            powerSaving: true,
                            powerSavingDelay: 30,
]]></description><link>https://forum.magicmirror.builders/post/100678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100678</guid><dc:creator><![CDATA[tanvir586]]></dc:creator><pubDate>Fri, 01 Apr 2022 12:18:12 GMT</pubDate></item></channel></rss>
