<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Black screen after updating to 2.19]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">just updated my MM from 2.18 to 2.19, <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>’s update script threw no errors.</p>
<p dir="auto">Now I get a black screen with mouse pointer only.</p>
<p dir="auto">pm2 logs --lines=50 output:</p>
<pre><code>0|MagicMir | [02.04.2022 09:09.59.133] [WARN]  [yahoo-finance2] Please upgrade to yahoo-finance2@latest, i.e. 2.x.  The only breaking change is a fix in quoteSummary to correctly return Date objects instead of numerical timestamps in these submodules: defaultKeyStatistics, earningsHistory, insiderHolders. For more info see: https://github.com/gadicc/node-yahoo-finance2/commit/4cf1f624d55d92f80db4b36b3afe9414f5eb5a3c
0|MagicMir | [02.04.2022 09:09.59.764] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
0|MagicMir | Require stack:
0|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCommute/node_helper.js
0|MagicMir | - /home/pi/MagicMirror/js/app.js
0|MagicMir | - /home/pi/MagicMirror/js/electron.js
0|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
0|MagicMir | -
0|MagicMir | [02.04.2022 09:09.59.774] [ERROR] App threw an error during load
0|MagicMir | [02.04.2022 09:09.59.780] [ERROR] Error: Cannot find module 'request'
0|MagicMir | -
0|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
0|MagicMir |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1105)
0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
0|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
0|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
0|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
0|MagicMir |     at require (node:internal/modules/cjs/helpers:102:18)
0|MagicMir |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-MyCommute/node_helper.js:9:17)
0|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
0|MagicMir | [02.04.2022 09:09.59.783] [ERROR] Whoops! There was an uncaught exception...
0|MagicMir | [02.04.2022 09:09.59.795] [ERROR] Error: Cannot find module 'request'
0|MagicMir | -
0|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
0|MagicMir |   code: 'MODULE_NOT_FOUND',
0|MagicMir |   requireStack: [
0|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCommute/node_helper.js',
0|MagicMir |     '/home/pi/MagicMirror/js/app.js',
0|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
0|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
0|MagicMir |     undefined
0|MagicMir |   ]
0|MagicMir | }
0|MagicMir | [02.04.2022 09:09.59.798] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMir | [02.04.2022 09:09.59.800] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
0|MagicMir | [3003:0402/091001.395115:ERROR:viz_main_impl.cc(188)] Exiting GPU process due to errors during initialization
0|MagicMir | [3030:0402/091001.541186:ERROR:sandbox_linux.cc(377)] InitializeSandbox() called with multiple threads in process gpu-process.
<p dir="auto">The pi has a internet connection.</p>
<p dir="auto">Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/topic/16559/black-screen-after-updating-to-2-19</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 16:46:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16559.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Apr 2022 07:14:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Black screen after updating to 2.19 on Sat, 02 Apr 2022 08:57:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/requiemmg" aria-label="Profile: requiemmg">@<bdi>requiemmg</bdi></a><br />
Go down to modules/MMM-MyCommute and run:</p>
<pre><code>npm install request
<p dir="auto">restart MM</p>
]]></description><link>https://forum.magicmirror.builders/post/100706</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100706</guid><dc:creator><![CDATA[mickecarlsson]]></dc:creator><pubDate>Sat, 02 Apr 2022 08:57:32 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after updating to 2.19 on Sun, 03 Apr 2022 06:51:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/requiemmg" aria-label="Profile: requiemmg">@<bdi>requiemmg</bdi></a><br />
Can you mark this as solved?</p>
]]></description><link>https://forum.magicmirror.builders/post/100753</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100753</guid><dc:creator><![CDATA[mickecarlsson]]></dc:creator><pubDate>Sun, 03 Apr 2022 06:51:47 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after updating to 2.19 on Sat, 02 Apr 2022 09:42:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickecarlsson" aria-label="Profile: mickecarlsson">@<bdi>mickecarlsson</bdi></a> Thanks, “request” had to be installed there and for another module, now my mirror is working again.</p>
]]></description><link>https://forum.magicmirror.builders/post/100708</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100708</guid><dc:creator><![CDATA[requiemmg]]></dc:creator><pubDate>Sat, 02 Apr 2022 09:42:49 GMT</pubDate></item><item><title><![CDATA[Reply to Black screen after updating to 2.19 on Sat, 02 Apr 2022 08:57:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/requiemmg" aria-label="Profile: requiemmg">@<bdi>requiemmg</bdi></a><br />
]]></description><link>https://forum.magicmirror.builders/post/100706</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100706</guid><dc:creator><![CDATA[mickecarlsson]]></dc:creator><pubDate>Sat, 02 Apr 2022 08:57:32 GMT</pubDate></item></channel></rss>
