<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After install, two npm modules went missing]]></title><description><![CDATA[<p dir="auto">After doing a <code>git pull</code> and then running <code>npm install</code>, it seems that two modules <code>valid-url</code> and <code>request</code> went missing (they were used by <code>MMM-CalendarExt</code>.  I tried to navigate back to the MMM-CalendarExt module and run <code>npm install</code> there but that didn’t help. I had to go to the root directory for MM and actually run <code>npm install request</code> and <code>npm install valid-url</code>. Not sure if anyone else is exhibiting this, but I through id’ throw it out there.</p>
]]></description><link>https://forum.magicmirror.builders/topic/16583/after-install-two-npm-modules-went-missing</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 10:47:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16583.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 05 Apr 2022 22:37:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After install, two npm modules went missing on Tue, 05 Apr 2022 22:39:00 GMT]]></title><description><![CDATA[<p dir="auto">see <a href="https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later">https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later</a></p>
]]></description><link>https://forum.magicmirror.builders/post/100854</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/100854</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Tue, 05 Apr 2022 22:39:00 GMT</pubDate></item></channel></rss>
