<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[ERROR] Moment Timezone has no data for Customized Time Zone]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I just updated to 2.19.0 and since then the logfile is flooded every 10th of a second with the above error messages.</p>
<p dir="auto">how can I stop these errors?</p>
<p dir="auto">I have already read <a href="https://forum.magicmirror.builders/topic/15803/error-moment-timezone-has-no-data-for-customized-time-zone?_=1649673058687">this  thread</a> . Does this also apply to version 2.19.0 <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ?</p>
<p dir="auto">Thanks in advance</p>
<p dir="auto">Greetings<br />
Sepp</p>
]]></description><link>https://forum.magicmirror.builders/topic/16617/error-moment-timezone-has-no-data-for-customized-time-zone</link><generator>RSS for Node</generator><lastBuildDate>Sat, 13 Jun 2026 21:24:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/16617.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Apr 2022 10:40:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [ERROR] Moment Timezone has no data for Customized Time Zone on Mon, 11 Apr 2022 12:33:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a> no way to stop them unfortunately.  a lower library is emitting the error cause the timezone value is unexpected.</p>
<p dir="auto">this is usually caused by a Microsoft 365 calendar where they create custom timezones  which none else in the world uses.</p>
]]></description><link>https://forum.magicmirror.builders/post/101038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101038</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Apr 2022 12:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Moment Timezone has no data for Customized Time Zone on Mon, 11 Apr 2022 14:41:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a> the errors should only be  when we fetch the ics file,   once every 10 or 15 minutes (for each such entry to process)</p>
]]></description><link>https://forum.magicmirror.builders/post/101043</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101043</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Apr 2022 14:41:26 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Moment Timezone has no data for Customized Time Zone on Mon, 11 Apr 2022 13:07:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">ok, then i have to erase the log files often, so that the file system doesn’t crash … :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/101040</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101040</guid><dc:creator><![CDATA[spitzlbergerj]]></dc:creator><pubDate>Mon, 11 Apr 2022 13:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Moment Timezone has no data for Customized Time Zone on Mon, 11 Apr 2022 12:33:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spitzlbergerj" aria-label="Profile: spitzlbergerj">@<bdi>spitzlbergerj</bdi></a> no way to stop them unfortunately.  a lower library is emitting the error cause the timezone value is unexpected.</p>
]]></description><link>https://forum.magicmirror.builders/post/101038</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/101038</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Apr 2022 12:33:58 GMT</pubDate></item></channel></rss>
